    default Calender Two calender with different update time
    9 Posts 2 Posters 1.2k Views 2 Watching
      Blackmirror
      Hello,
      I’m having trouble with my garbage collection service blocking my calendar if I access the data more than once a day. However, I need frequent updates for entries with appointments and times. Can I configure the calendar so that it only updates once a day, while my Google Calendar continues to update every 5 minutes?
      Blackmirror
      S 1 Reply Last reply Reply Quote -2
        sdetweil @Blackmirror
        @Blackmirror i am wrong.
        based on the code (not the doc)
        you can have a unique fetchInterval by url to override the base config value
        so you only need one calendar instance
          @Blackmirror what is MMM-Calendar? the default calendar module?
          what is your Google calendar?
            Blackmirror @sdetweil
            Hello Sam,
            yes the standard calender modul.
            I mean the calender from my google account.
            This one should be updated regularly, while the ic for my garbage collection only once a day. So, both require different update times.
            Blackmirror
              @Blackmirror you can run multiple instances of the calendar with different refresh intervals…
                How?
                The fetchinverall is only in the config menu not for the menu of the differnet calenders.
                Blackmirror
                  @Blackmirror
                        module:"calendar",
                                config:{
                                         fetchInterval: yyyyyyy,
                                                        url:"cal1"
                        module:"calendar",
                                config:{
                                         fetchInterval:  xxxxx,
                                                        url:"cal2"
                    okay.
                    I was hoping there would be a solution to integrate this into a calendar
                    Blackmirror
                      @Blackmirror for the default calendar, all calendars:[] in the list use the same fetchInterval.
                      you could use one of the other calendar modules that display a wall type
                      MMM-CalendarMonthly, MMM-CalendarExt3 (or its siblings, Agenda, Timeline,…),
                      or others… search calendar on the 3rd party module list linked in the header above
                      those modules collect results from the default calendar and present them in different formats
