    MMM-MyStanding not updating within MMM-Carousel
    11 Posts 2 Posters 4.4k Views 2 Watching
    • K
      khrusher
      MMM-MyScorboard and MMM-MyStandings configured within MMM-Carousel as ‘positional’ The bottom_left rotates these two modules.
      not sure if MMM-Carousel plays into this, just wanted to add
      I see in the server output the fetch on regular intervals
      [2025-07-22 11:24:18.047] ^[[44m[DEBUG]^[[49m [MMM-MyStandings] https://site.api.espn.com/apis/v2/sports/baseball/mlb/standings?level=3&sort=gamesbehind:asc,winpercent:desc fetched
      I have manually pulled the data and it looks correct, however the data on the screen is not updated. If I refresh the screen r, the data is updated.
        sdetweil @khrusher
        @khrusher can you try this temp fix
        https://forum.magicmirror.builders/post/127456
        • K
          khrusher
          Update applied, ill know tomorrow if it worked…thanks.
          • K
            khrusher @khrusher
            has not updated since patch and restart. I think ill try without carousel
            • K
              khrusher @khrusher
              ill check tomorrow
              • K
                khrusher
                without MMM-Carousel and with the manual updates in the referenced item above, MMM-MyStandings updated properly.
                MMM-Carousel was swapping MMM-MyStandings and MMM-MyScoreboard. all this time that standings was not updating, MMM-MyScoreboard was. Scores were updated along with the live game action.
                Feels like an issue combining MMM-Carousel and MMM-MyStandings, maybe some kind of notification crossup
                  sdetweil @khrusher
                  @khrusher can you show the config of the two modules?
                  what is the carousel rotation rate?
                  the standings default is 1 minute for multiple teams…
                  • K
                    khrusher @sdetweil
                    sure…
                             "module": "MMM-Carousel",
                             "position":"bottom_bar",
                             "showPageIndicators":true,
                             "config": {
                               "transitionInterval": 20000,
                               "mode": "positional",
                               "bottom_left": { "enabled": true, "ignoreModules": []  }
                              module: "MMM-MyScoreboard",
                              position: "bottom_left",
                              classes: "default everyone",
                                 showLeagueSeparators: true,
                                 colored: true,
                                 viewStyle: "smallLogos",
                                 rolloverHours: 11,
                                 teams: ["BOS"],
                                 sports: [
                                     league: "NHL",
                                       league: "MLB",
                                       teams: ["BOS"]
                                       league: "NFL",
                                       teams: ["NE"]
                             "module":"MMM-MyStandings",
                             "position":"bottom_left",
                             "config":{
                                "rotateInterval":2 * 60 * 1000,
                                "sports":[
                                      "league":"MLB",
                                      "groups":[
                                         "American League East"
                                      "league":"NFL",
                                      "groups":[
                                         "ACF East"
                      sdetweil @khrusher
                      @khrusher so carousel rotates every 20 (20*1000 milliseconds) seconds, and standings rotates every 2 minutes (2*60*1000)
                      Standings does not provide the suspend/resume methods, so it doesn’t know when its hidden or visible.
                      so it will keep rotating while hidden
                      • K
                        khrusher @sdetweil
                        is this breaking the update notification? is there something I can do? Or is the lack of suspend/resume methods ultimately a show stopper here for now?
                          sdetweil @khrusher
                          @khrusher I don’t know the effect. but given how fast you are cycling with carousel, I don’t think it should matter
