    Calendar does not run on secondary screen
    14 Posts 2 Posters 2.8k Views 2 Watching
      sdetweil @BKeyport
      @BKeyport i dont understand what you are saying
      multi screen
      client server
      calendar
      MagicMirror is a browser, it runs on a logical screen
      on a desktop, multiple displays are all one screen
      so are you saying you are vnc’d in with two sessions? two displays?
      multiple web browsers to same MagicMirror server/port will get the same stuff
      multiple web browsers to same server/ different ports will get different stuff ( as configured)
      multiple browsers will appear on the remote system per the system design
      1 minute refresh might not be enough time to get all the entries processed
      • BKeyportB
        Multi-screen: https://docs.magicmirror.builders/configuration/introduction.html#a-couple-of-real-world-examples (remember, I re-wrote this?)
        Client/Server: https://docs.magicmirror.builders/getting-started/installation.html#server-only
        Calendar = default calendar module.
        Most of the calendars are in fact local, so timing don’t matter. The only problem I’m having is that this exact configuration works on the screen running as main monitor, but not on the screen running as secondary. Main monitor’s header info is this:
        var config = {
        	address: "0.0.0.0",
        	port: 8080,
        	ipWhitelist: [],
        	language: "en",
        	timeFormat: 12,
        	units: "imperial",
        	//logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
          sdetweil @BKeyport
          @BKeyport what browser are you using to connect to the MagicMirror instances?
          do you have one MagicMirror folder or two?
          two sep config files, so if one instance you use the MM_CONFIG_FILE env to launch the second
          just trying to get detail so i can repeat this
            sdetweil @BKeyport
            @BKeyport if you manually refresh the page where you are expecting the calendar to display, does it?
            we had/have bug where the socket send of the events from calendar module is not received at the client
            see
            https://github.com/MagicMirrorOrg/MagicMirror/issues/3380
            manual refresh works
            see this for a possible workaround
            https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/issues/393#issuecomment-3075487788
            • BKeyportB
              Browser is whatever node uses - same problem occurs on other sessions through chrome like browser on my Main PC (Brave)
              One magic mirror folder - all configs in MM/Config just numbered.
              Refresh does nothing. (Via Chrome/Brave).
              Start MM using this:
              export MM_CONFIG_FILE=config/config2.js
              export MM_PORT=8081
              export ELECTRON_DISABLE_GPU=1
              DISPLAY=:0 node clientonly --address mirrorserv.local --port 8081
                sdetweil @BKeyport
                @BKeyport ok, just fyi, node doesnt have a browser clientOnly uses electron same as full
                what os, and this is 2.32, right?
                can you install MMM-ViewNotifications on the second screen instance and see if the events are broadcast.
                or look in the output of npm run server to see the broadcast message from the parser…
                Calendar-Fetcher: Broadcasting 19 events from https://calendar.google.com/calendar/ical
                I’m running two instances now and they behave as expected…
                I only have 1 calendar
                • BKeyportB
                  ViewNotification doesn’t show anything…
                  When I load the mirror in chrome/brave I get this in console:
                  BKeyportB S 2 Replies Last reply Reply Quote 0
                  • BKeyportB
                    If the answer appears to be frank’s solution in that other thread, I don’t understand what to do or how to fix it. without knowledge of where he’s working I have no idea where to touch.
                      sdetweil @BKeyport
                      @BKeyport those look like browser side messages not server side
                      franks. i dont know either
                      but ill have something for you in the morning
                        sdetweil @BKeyport
                        @BKeyport
                        edit MagicMirror/js/server.js
                        add these two lines
                        				allowEIO3: true,   // line 45
                        				pingInterval: 120000,  // server → client ping every 2 mins   //add
                        				pingTimeout:  120000   // wait up to 2 mins for client pong   //add
                        edit MagicMirror/js/socketclient.js
                        add these two lines
                            this.socket = io(`/${this.moduleName}`, {  // line 15
                                        path: `${base}socket.io`,
                                        pingInterval: 120000,  // send pings every 2 mins     // add
                                        pingTimeout: 120000    // wait up to 2 mins for a pong  // add
                        • BKeyportB
                          @sdetweil Yep. that fixed it.
                            sdetweil @BKeyport
                            @BKeyport awesome!!!
                            • BKeyportB BKeyport has marked this topic as solved on
                              This fix is in the next release , Oct 1
