    Calendar does not run on secondary screen
    14 Posts 2 Posters 3.0k Views 2 Watching
    • BKeyportB
      Multi-screen: https://docs.magicmirror.builders/configuration/introduction.html#a-couple-of-real-world-examples (remember, I re-wrote this?)
      Client/Server: https://docs.magicmirror.builders/getting-started/installation.html#server-only
      Calendar = default calendar module.
      Most of the calendars are in fact local, so timing don’t matter. The only problem I’m having is that this exact configuration works on the screen running as main monitor, but not on the screen running as secondary. Main monitor’s header info is this:
      var config = {
      	address: "0.0.0.0",
      	port: 8080,
      	ipWhitelist: [],
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      	//logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
      S 2 Replies Last reply
        sdetweil @BKeyport
        @BKeyport what browser are you using to connect to the MagicMirror instances?
        do you have one MagicMirror folder or two?
        two sep config files, so if one instance you use the MM_CONFIG_FILE env to launch the second
        just trying to get detail so i can repeat this
          sdetweil @BKeyport
          @BKeyport if you manually refresh the page where you are expecting the calendar to display, does it?
          we had/have bug where the socket send of the events from calendar module is not received at the client
          see
          https://github.com/MagicMirrorOrg/MagicMirror/issues/3380
          manual refresh works
          see this for a possible workaround
          https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/issues/393#issuecomment-3075487788
          BKeyportB 1 Reply Last reply
          • BKeyportB
            Browser is whatever node uses - same problem occurs on other sessions through chrome like browser on my Main PC (Brave)
            One magic mirror folder - all configs in MM/Config just numbered.
            Refresh does nothing. (Via Chrome/Brave).
            Start MM using this:
            export MM_CONFIG_FILE=config/config2.js
            export MM_PORT=8081
            export ELECTRON_DISABLE_GPU=1
            DISPLAY=:0 node clientonly --address mirrorserv.local --port 8081
              sdetweil @BKeyport
              @BKeyport ok, just fyi, node doesnt have a browser clientOnly uses electron same as full
              what os, and this is 2.32, right?
              can you install MMM-ViewNotifications on the second screen instance and see if the events are broadcast.
              or look in the output of npm run server to see the broadcast message from the parser…
              Calendar-Fetcher: Broadcasting 19 events from https://calendar.google.com/calendar/ical
              I’m running two instances now and they behave as expected…
              I only have 1 calendar
              • BKeyportB
                ViewNotification doesn’t show anything…
                When I load the mirror in chrome/brave I get this in console:
                BKeyportB S 2 Replies Last reply
                • BKeyportB
                  If the answer appears to be frank’s solution in that other thread, I don’t understand what to do or how to fix it. without knowledge of where he’s working I have no idea where to touch.
                    sdetweil @BKeyport
                    @BKeyport those look like browser side messages not server side
                    franks. i dont know either
                    but ill have something for you in the morning
                      sdetweil @BKeyport
                      @BKeyport
                      edit MagicMirror/js/server.js
                      add these two lines
                      				allowEIO3: true,   // line 45
                      				pingInterval: 120000,  // server → client ping every 2 mins   //add
                      				pingTimeout:  120000   // wait up to 2 mins for client pong   //add
                      edit MagicMirror/js/socketclient.js
                      add these two lines
                          this.socket = io(`/${this.moduleName}`, {  // line 15
                                      path: `${base}socket.io`,
                                      pingInterval: 120000,  // send pings every 2 mins     // add
                                      pingTimeout: 120000    // wait up to 2 mins for a pong  // add
                      • BKeyportB
                        @sdetweil Yep. that fixed it.
                          sdetweil @BKeyport
                          @BKeyport awesome!!!
                          • BKeyportB BKeyport has marked this topic as solved on
                            This fix is in the next release , Oct 1
