    Calendar does not run on secondary screen
    14 Posts 2 Posters 3.0k Views 2 Watching
      sdetweil @BKeyport
      @BKeyport what browser are you using to connect to the MagicMirror instances?
      do you have one MagicMirror folder or two?
      two sep config files, so if one instance you use the MM_CONFIG_FILE env to launch the second
      just trying to get detail so i can repeat this
        sdetweil @BKeyport
        @BKeyport if you manually refresh the page where you are expecting the calendar to display, does it?
        we had/have bug where the socket send of the events from calendar module is not received at the client
        see
        https://github.com/MagicMirrorOrg/MagicMirror/issues/3380
        manual refresh works
        see this for a possible workaround
        https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/issues/393#issuecomment-3075487788
        BKeyportB 1 Reply Last reply
        • BKeyportB
          Browser is whatever node uses - same problem occurs on other sessions through chrome like browser on my Main PC (Brave)
          One magic mirror folder - all configs in MM/Config just numbered.
          Refresh does nothing. (Via Chrome/Brave).
          Start MM using this:
          export MM_CONFIG_FILE=config/config2.js
          export MM_PORT=8081
          export ELECTRON_DISABLE_GPU=1
          DISPLAY=:0 node clientonly --address mirrorserv.local --port 8081
            sdetweil @BKeyport
            @BKeyport ok, just fyi, node doesnt have a browser clientOnly uses electron same as full
            what os, and this is 2.32, right?
            can you install MMM-ViewNotifications on the second screen instance and see if the events are broadcast.
            or look in the output of npm run server to see the broadcast message from the parser…
            Calendar-Fetcher: Broadcasting 19 events from https://calendar.google.com/calendar/ical
            I’m running two instances now and they behave as expected…
            I only have 1 calendar
            • BKeyportB
              ViewNotification doesn’t show anything…
              When I load the mirror in chrome/brave I get this in console:
              BKeyportB S 2 Replies Last reply
              • BKeyportB
                If the answer appears to be frank’s solution in that other thread, I don’t understand what to do or how to fix it. without knowledge of where he’s working I have no idea where to touch.
                  sdetweil @BKeyport
                  @BKeyport those look like browser side messages not server side
                  franks. i dont know either
                  but ill have something for you in the morning
                    sdetweil @BKeyport
                    @BKeyport
                    edit MagicMirror/js/server.js
                    add these two lines
                    				allowEIO3: true,   // line 45
                    				pingInterval: 120000,  // server → client ping every 2 mins   //add
                    				pingTimeout:  120000   // wait up to 2 mins for client pong   //add
                    edit MagicMirror/js/socketclient.js
                    add these two lines
                        this.socket = io(`/${this.moduleName}`, {  // line 15
                                    path: `${base}socket.io`,
                                    pingInterval: 120000,  // send pings every 2 mins     // add
                                    pingTimeout: 120000    // wait up to 2 mins for a pong  // add
                    • BKeyportB
                      @sdetweil Yep. that fixed it.
                        sdetweil @BKeyport
                        @BKeyport awesome!!!
                        • BKeyportB BKeyport has marked this topic as solved on
                          This fix is in the next release , Oct 1
