    MM won't update after config file changes
    8 Posts 2 Posters 3.2k Views 2 Watching
    • G
      GRR
      hello, new user here
      I installed MM and attempted to add modules. After I updated and saved the config file, I restarted MM to find the default modules still present. None of my config file changes appeared on the MM. I searched the troubleshooting forum and ran ‘npm run config:check’ and it said there were no syntax errors on the configuration and modules portion. Any thoughts? Thanks everyone!
      • G
        GRR @sdetweil
        @sdetweil Hi sam, thanks for the reply, I think I figured out my problem with the config file and I’m starting to see changes take effect. Thank you so much for your timely response.
          sdetweil @GRR
          @GRR can you show the messages produced by
          npm start
          in the MagicMirror folder
          You can capture the output by using the redirect symbols
          npm start >sonefile.txt 2>&1
          Wait 15 seconds
          Press ctrl-c
          And then you can examine the contents of somefile.txt
          Note: if you are using pm2 to autolaunch at boot
          You may need to use the pm2 command to restart MagicMirror
          pm2 status
          Will show you the state of the managed apps
          pm2 stop xx
          pm2 start xx
          pm2 restart xx
          xx is the name or number of the row displayed in the output of pm2 status
          How did you install the apps and edit config.js
          G 2 Replies Last reply
          • G
            GRR @sdetweil
              sdetweil @GRR
              @GRR can you tell us generally what it was, that way we might know for other users that encounter the same issue…
              thanks for the feedback regardless…
              • G
                GRR @sdetweil
                @sdetweil embarrassingly, I was editing the wrong config file. I was editing a copy and dummy me didn’t update the config file being used by MM.
                  sdetweil @GRR
                  @GRR I’ve been there many times.
                  amazing how you dont see it.
                  thanks for sharing that.
                  G 1 Reply Last reply
                  • G
                    GRR @sdetweil
                    @sdetweil Thanks for your patience and understanding and for your willingness to help. When I read your thread about which editor I was using for the config file something hit me mentally to check those config files and there it was, hit me like a frying pan. ha ha.
                      sdetweil @GRR
                      @GRR lol, yeh does whack you.
                      im the moderator here. as well as user. module author
