    MM won't update after config file changes
    8 Posts 2 Posters 2.7k Views 2 Watching
      sdetweil @GRR
      @GRR can you show the messages produced by
      npm start
      in the MagicMirror folder
      You can capture the output by using the redirect symbols
      npm start >sonefile.txt 2>&1
      Wait 15 seconds
      Press ctrl-c
      And then you can examine the contents of somefile.txt
      Note: if you are using pm2 to autolaunch at boot
      You may need to use the pm2 command to restart MagicMirror
      pm2 status
      Will show you the state of the managed apps
      pm2 stop xx
      pm2 start xx
      pm2 restart xx
      xx is the name or number of the row displayed in the output of pm2 status
      How did you install the apps and edit config.js
      G 2 Replies Last reply Reply Quote 0
      • G Offline
        GRR @sdetweil
        @sdetweil Hi sam, thanks for the reply, I think I figured out my problem with the config file and I’m starting to see changes take effect. Thank you so much for your timely response.
          sdetweil @GRR
          @GRR can you tell us generally what it was, that way we might know for other users that encounter the same issue…
          thanks for the feedback regardless…
          • G Offline
            GRR @sdetweil
            @sdetweil embarrassingly, I was editing the wrong config file. I was editing a copy and dummy me didn’t update the config file being used by MM.
              sdetweil @GRR
              @GRR I’ve been there many times.
              amazing how you dont see it.
              thanks for sharing that.
              • G Offline
                GRR @sdetweil
                @sdetweil Thanks for your patience and understanding and for your willingness to help. When I read your thread about which editor I was using for the config file something hit me mentally to check those config files and there it was, hit me like a frying pan. ha ha.
                  sdetweil @GRR
                  @GRR lol, yeh does whack you.
                  im the moderator here. as well as user. module author
