    update package list
    45 Posts 2 Posters 11.4k Views 2 Watching
    • P Offline
      pat59
      magicmirror@2.27.0 start
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      [2025-09-11 16:56:55.039] [LOG] Starting MagicMirror: v2.27.0
      [2025-09-11 16:56:55.176] [LOG] Loading config …
      [2025-09-11 16:56:55.192] [LOG] config template file not exists, no envsubst
      [2025-09-11 16:56:55.206] [LOG] Loading module helpers …
      [2025-09-11 16:56:55.858] [LOG] Initializing new module helper …
      [2025-09-11 16:56:55.860] [LOG] Module helper loaded: MMM-Remote-Control
      [2025-09-11 16:56:55.863] [LOG] No helper found for module: alert.
      [2025-09-11 16:56:55.885] [LOG] Initializing new module helper …
      [2025-09-11 16:56:55.887] [LOG] Module helper loaded: MMM-Saint
      [2025-09-11 16:56:55.913] [LOG] Initializing new module helper …
      [2025-09-11 16:56:55.915] [LOG] Module helper loaded: MMM-BME280
      [2025-09-11 16:56:55.933] [LOG] No helper found for module: MMM-FlipClock.
      [2025-09-11 16:56:56.121] [LOG] Initializing new module helper …
      [2025-09-11 16:56:56.122] [LOG] Module helper loaded: MMM-network-signal
      [2025-09-11 16:56:56.827] [LOG] Initializing new module helper …
      [2025-09-11 16:56:56.828] [LOG] Module helper loaded: calendar
      [2025-09-11 16:56:58.426] [LOG] Initializing new module helper …
      [2025-09-11 16:56:58.427] [LOG] Module helper loaded: MMM-Jast
      [2025-09-11 16:57:00.066] [LOG] Initializing new module helper …
      [2025-09-11 16:57:00.069] [LOG] Module helper loaded: MMM-GooglePhotos
      [2025-09-11 16:57:00.088] [LOG] No helper found for module: MMM-WiFiPassword.
      [2025-09-11 16:57:00.093] [LOG] No helper found for module: MMM-OpenmapWeather.
      [2025-09-11 16:57:00.107] [LOG] No helper found for module: MMM-WeatherOrNot.
      [2025-09-11 16:57:00.122] [WARN] No /home/pi/MagicMirror/js/…/modules/MMM-Linky/MMM-Linky.js found for module: MMM-Linky.
      [2025-09-11 16:57:00.124] [LOG] No helper found for module: MMM-Linky.
      [2025-09-11 16:57:00.569] [LOG] Initializing new module helper …
      [2025-09-11 16:57:00.571] [LOG] Module helper loaded: newsfeed
      [2025-09-11 16:57:00.573] [LOG] All module helpers loaded.
      [2025-09-11 16:57:00.599] [LOG] Starting server on port 8080 …
      [2025-09-11 16:57:00.649] [WARN] You’re using a full whitelist configuration to allow for all IPs
      [2025-09-11 16:57:03.916] [ERROR] Whoops! There was an uncaught exception…
      [2025-09-11 16:57:03.930] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
      at Server.setupListenHandle [as _listen2] (node:net:1872:16)
      at listenInCluster (node:net:1920:12)
      at doListen (node:net:2069:7)
      at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
      code: ‘EADDRINUSE’,
      errno: -98,
      syscall: ‘listen’,
      address: ‘0.0.0.0’,
      port: 8080
      [2025-09-11 16:57:03.933] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2025-09-11 16:57:03.936] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
      [2025-09-11 16:57:40.629] [INFO] System information:
      SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
      OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 6.12.45-v7+
      VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
      OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
        sdetweil @pat59
        @pat59 so, you already have an instance running, probably under pm2
        when I said stop MM I meant in whatever way running…
        pm2’s JOB is to start and KEEP MM running… no matter what
        you ctrl-Q
        pm2 says, oops, app crashed, restart…
        so, you have to use the pm2 commands to tell it what to do
        pm2 status
        will show the managed apps, one line per
        you can control the app, by using the name or number of the app in a row
        pm2 stop 0
        pm2 stop MagicMirror
        could both be for the same app
        once stopped, THEN you can go to the MM folder and do the npm start to see the possible errors easier…
        once you fix the errors, you can stop the temp MM with ctrl-q (as you started it manually)
        and then tell pm2 to manage it again
        pm2 start 0/MagicMirror
        • P Offline
          pat59
          pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
          pi@raspberrypi:~/MagicMirror $ npm install
          magicmirror@2.27.0 postinstall
          npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          magicmirror@2.27.0 install-vendor
          echo "Installing vendor files …
          " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          up to date in 3s
          magicmirror@2.27.0 install-fonts
          echo "Installing fonts …
          " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          Installing fonts …
          up to date in 3s
          magicmirror@2.27.0 prepare
          [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
          added 976 packages in 8m
          205 packages are looking for funding
          run npm fund for details
            sdetweil @pat59
            @pat59 and now
            npm start
            • P Offline
              pat59
              I don’t know how to thank you, it’s working again, thank you, thank you
              • P Offline
                pat59
                Well, it’s working normally again. I don’t know how to thank you. Thank you, thank you.
                • P Offline
                  pat59
                  Hello, I must have missed a step. I started my mirror this morning, same problem.
                  pi@raspberrypi:~/MagicMirror $ pm2 stop MagicMirror
                  [PM2] Applying action stopProcessId on app [MagicMirror](ids: [ 1 ])
                  [PM2] MagicMirror ✓
                  │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                  │ 1 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b │
                  │ 0 │ mm │ fork │ 0 │ online │ 0% │ 2.4mb │
                  [2025-09-12 07:06:24.742] [LOG] Starting MagicMirror: v2.27.0
                  [2025-09-12 07:06:24.863] [LOG] Loading config …
                  [2025-09-12 07:06:24.888] [LOG] config template file not exists, no envsubst
                  [2025-09-12 07:06:24.899] [LOG] Loading module helpers …
                  [2025-09-12 07:06:25.265] [LOG] Initializing new module helper …
                  [2025-09-12 07:06:25.269] [LOG] Module helper loaded: MMM-Remote-Control
                  [2025-09-12 07:06:25.273] [LOG] No helper found for module: alert.
                  [2025-09-12 07:06:25.286] [LOG] Initializing new module helper …
                  [2025-09-12 07:06:25.290] [LOG] Module helper loaded: MMM-Saint
                  [2025-09-12 07:06:25.299] [LOG] Initializing new module helper …
                  [2025-09-12 07:06:25.301] [LOG] Module helper loaded: MMM-BME280
                  [2025-09-12 07:06:25.303] [LOG] No helper found for module: MMM-FlipClock.
                  [2025-09-12 07:06:25.467] [LOG] Initializing new module helper …
                  [2025-09-12 07:06:25.469] [LOG] Module helper loaded: MMM-network-signal
                  [2025-09-12 07:06:26.004] [LOG] Initializing new module helper …
                  [2025-09-12 07:06:26.005] [LOG] Module helper loaded: calendar
                  [2025-09-12 07:06:27.471] [LOG] Initializing new module helper …
                  [2025-09-12 07:06:27.474] [LOG] Module helper loaded: MMM-Jast
                  [2025-09-12 07:06:28.921] [LOG] Initializing new module helper …
                  [2025-09-12 07:06:28.923] [LOG] Module helper loaded: MMM-GooglePhotos
                  [2025-09-12 07:06:28.926] [LOG] No helper found for module: MMM-WiFiPassword.
                  [2025-09-12 07:06:28.929] [LOG] No helper found for module: MMM-OpenmapWeather.
                  [2025-09-12 07:06:28.931] [LOG] No helper found for module: MMM-WeatherOrNot.
                  [2025-09-12 07:06:28.933] [WARN] No /home/pi/MagicMirror/js/…/modules/MMM-Linky/MMM-Linky.js found for module: MMM-Linky.
                  [2025-09-12 07:06:28.935] [LOG] No helper found for module: MMM-Linky.
                  [2025-09-12 07:06:29.442] [LOG] Initializing new module helper …
                  [2025-09-12 07:06:29.444] [LOG] Module helper loaded: newsfeed
                  [2025-09-12 07:06:29.446] [LOG] All module helpers loaded.
                  [2025-09-12 07:06:29.475] [LOG] Starting server on port 8080 …
                  [2025-09-12 07:06:29.494] [WARN] You’re using a full whitelist configuration to allow for all IPs
                  [2025-09-12 07:06:31.407] [ERROR] Whoops! There was an uncaught exception…
                  [2025-09-12 07:06:31.452] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                  code: ‘EADDRINUSE’,
                  errno: -98,
                  syscall: ‘listen’,
                  address: ‘0.0.0.0’,
                  port: 8080
                  [2025-09-12 07:06:31.459] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2025-09-12 07:06:31.461] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                  [2025-09-12 07:06:44.850] [INFO] System information:
                  [PM2] MagicMirror ✓
                  code: ‘EADDRINUSE’,
                  errno: -98,
                  syscall: ‘listen’,
                  address: ‘0.0.0.0’,
                  port: 8080
                    sdetweil @pat59
                    @pat59
                    Did you stop it manually ctrl-q
                    Yesterday after we finished testing?
                    pm2 status
                    Is anything listed as running?
                    If not then do this
                    ps -ef| grep MagicMirror
                    You should only get one line of output
                    • P Offline
                      pat59
                      pi@raspberrypi:~ $ cd ~/MagicMirror
                      pi@raspberrypi:~/MagicMirror $ pm2 status
                      │ 1  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.5mb    │
                      │ 0  │ mm                 │ fork     │ 0    │ online    │ 0%       │ 2.3mb    │
                      so you have two instances
                      pi@raspberrypi:~/MagicMirror $ ps -ef|grep MagicMirror
                      pi        1037   818  0 14:29 ?        00:00:00 bash /home/pi/MagicMirror/installers/mm.sh
                      pi        1096  1075 26 14:29 ?        00:00:56 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
                      pi        1097  1077 24 14:29 ?        00:00:52 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
                      pi        1102  1097  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox
                      pi        1103  1096  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox
                      pi        1104  1096  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                      pi        1106  1097  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                      pi        1109  1104  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                      pi        1110  1106  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                      pi        1407  1103  1 14:31 ?        00:00:01 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --use-gl=angle --use-angle=swiftshader-webgl --shared-files --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                      pi        1408  1102  0 14:31 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --use-gl=angle --use-angle=swiftshader-webgl --shared-files --field-trial-handle=0,i,4975378740503322807,8852675362163135929,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                      pi        1478  1097  0 14:31 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,4975378740503322807,8852675362163135929,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                      pi        1498  1096  1 14:31 ?        00:00:01 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                      pi        1517  1109  4 14:31 ?        00:00:04 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=renderer --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --app-path=/home/pi/MagicMirror/js --enable-sandbox --autoplay-policy=no-user-gesture-required --disable-gpu-compositing --lang=fr --num-raster-threads=2 --enable-main-frame-before-activation --renderer-client-id=4 --time-ticks-at-unix-epoch=-1757680110193681 --launch-time-ticks=192347868 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                      pi        1662  1367  0 14:33 pts/1    00:00:00 grep --color=auto MagicMirror
                      • P Offline
                        pat59
                        Hello, I stopped it with smartphone remote control.
                        • 5 / 5
