    update package list
    45 Posts 2 Posters 11.3k Views 2 Watching
      sdetweil @pat59
      @pat59 so, you already have an instance running, probably under pm2
      when I said stop MM I meant in whatever way running…
      pm2’s JOB is to start and KEEP MM running… no matter what
      you ctrl-Q
      pm2 says, oops, app crashed, restart…
      so, you have to use the pm2 commands to tell it what to do
      pm2 status
      will show the managed apps, one line per
      you can control the app, by using the name or number of the app in a row
      pm2 stop 0
      pm2 stop MagicMirror
      could both be for the same app
      once stopped, THEN you can go to the MM folder and do the npm start to see the possible errors easier…
      once you fix the errors, you can stop the temp MM with ctrl-q (as you started it manually)
      and then tell pm2 to manage it again
      pm2 start 0/MagicMirror
        pat59
        pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
        pi@raspberrypi:~/MagicMirror $ npm install
        magicmirror@2.27.0 postinstall
        npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
        magicmirror@2.27.0 install-vendor
        echo "Installing vendor files …
        " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        up to date in 3s
        magicmirror@2.27.0 install-fonts
        echo "Installing fonts …
        " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        Installing fonts …
        up to date in 3s
        magicmirror@2.27.0 prepare
        [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
        added 976 packages in 8m
        205 packages are looking for funding
        run npm fund for details
          sdetweil @pat59
          @pat59 and now
          npm start
            pat59
            I don’t know how to thank you, it’s working again, thank you, thank you
              pat59
              Well, it’s working normally again. I don’t know how to thank you. Thank you, thank you.
                pat59
                Hello, I must have missed a step. I started my mirror this morning, same problem.
                pi@raspberrypi:~/MagicMirror $ pm2 stop MagicMirror
                [PM2] Applying action stopProcessId on app [MagicMirror](ids: [ 1 ])
                [PM2] MagicMirror ✓
                │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                │ 1 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b │
                │ 0 │ mm │ fork │ 0 │ online │ 0% │ 2.4mb │
                magicmirror@2.27.0 start
                [2025-09-12 07:06:24.742] [LOG] Starting MagicMirror: v2.27.0
                [2025-09-12 07:06:24.863] [LOG] Loading config …
                [2025-09-12 07:06:24.888] [LOG] config template file not exists, no envsubst
                [2025-09-12 07:06:24.899] [LOG] Loading module helpers …
                [2025-09-12 07:06:25.265] [LOG] Initializing new module helper …
                [2025-09-12 07:06:25.269] [LOG] Module helper loaded: MMM-Remote-Control
                [2025-09-12 07:06:25.273] [LOG] No helper found for module: alert.
                [2025-09-12 07:06:25.286] [LOG] Initializing new module helper …
                [2025-09-12 07:06:25.290] [LOG] Module helper loaded: MMM-Saint
                [2025-09-12 07:06:25.299] [LOG] Initializing new module helper …
                [2025-09-12 07:06:25.301] [LOG] Module helper loaded: MMM-BME280
                [2025-09-12 07:06:25.303] [LOG] No helper found for module: MMM-FlipClock.
                [2025-09-12 07:06:25.467] [LOG] Initializing new module helper …
                [2025-09-12 07:06:25.469] [LOG] Module helper loaded: MMM-network-signal
                [2025-09-12 07:06:26.004] [LOG] Initializing new module helper …
                [2025-09-12 07:06:26.005] [LOG] Module helper loaded: calendar
                [2025-09-12 07:06:27.471] [LOG] Initializing new module helper …
                [2025-09-12 07:06:27.474] [LOG] Module helper loaded: MMM-Jast
                [2025-09-12 07:06:28.921] [LOG] Initializing new module helper …
                [2025-09-12 07:06:28.923] [LOG] Module helper loaded: MMM-GooglePhotos
                [2025-09-12 07:06:28.926] [LOG] No helper found for module: MMM-WiFiPassword.
                [2025-09-12 07:06:28.929] [LOG] No helper found for module: MMM-OpenmapWeather.
                [2025-09-12 07:06:28.931] [LOG] No helper found for module: MMM-WeatherOrNot.
                [2025-09-12 07:06:28.933] [WARN] No /home/pi/MagicMirror/js/…/modules/MMM-Linky/MMM-Linky.js found for module: MMM-Linky.
                [2025-09-12 07:06:28.935] [LOG] No helper found for module: MMM-Linky.
                [2025-09-12 07:06:29.442] [LOG] Initializing new module helper …
                [2025-09-12 07:06:29.444] [LOG] Module helper loaded: newsfeed
                [2025-09-12 07:06:29.446] [LOG] All module helpers loaded.
                [2025-09-12 07:06:29.475] [LOG] Starting server on port 8080 …
                [2025-09-12 07:06:29.494] [WARN] You’re using a full whitelist configuration to allow for all IPs
                [2025-09-12 07:06:31.407] [ERROR] Whoops! There was an uncaught exception…
                [2025-09-12 07:06:31.452] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                at Server.setupListenHandle [as _listen2] (node:net:1872:16)
                at listenInCluster (node:net:1920:12)
                at doListen (node:net:2069:7)
                at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
                code: ‘EADDRINUSE’,
                errno: -98,
                syscall: ‘listen’,
                address: ‘0.0.0.0’,
                port: 8080
                [2025-09-12 07:06:31.459] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2025-09-12 07:06:31.461] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                [2025-09-12 07:06:44.850] [INFO] System information:
                SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
                OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 6.12.45-v7+
                VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
                OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
                [PM2] MagicMirror ✓
                code: ‘EADDRINUSE’,
                errno: -98,
                syscall: ‘listen’,
                address: ‘0.0.0.0’,
                port: 8080
                  sdetweil @pat59
                  @pat59
                  Did you stop it manually ctrl-q
                  Yesterday after we finished testing?
                  pm2 status
                  Is anything listed as running?
                  If not then do this
                  ps -ef| grep MagicMirror
                  You should only get one line of output
                    pat59
                    pi@raspberrypi:~/MagicMirror $ pm2 status
                    │ 1  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.5mb    │
                    │ 0  │ mm                 │ fork     │ 0    │ online    │ 0%       │ 2.3mb    │
                    so you have two instances
                    pi@raspberrypi:~/MagicMirror $ ps -ef|grep MagicMirror
                    pi        1037   818  0 14:29 ?        00:00:00 bash /home/pi/MagicMirror/installers/mm.sh
                    pi        1096  1075 26 14:29 ?        00:00:56 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
                    pi        1097  1077 24 14:29 ?        00:00:52 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
                    pi        1102  1097  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox
                    pi        1103  1096  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox
                    pi        1104  1096  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                    pi        1106  1097  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                    pi        1109  1104  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                    pi        1110  1106  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                    pi        1407  1103  1 14:31 ?        00:00:01 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --use-gl=angle --use-angle=swiftshader-webgl --shared-files --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                    pi        1408  1102  0 14:31 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --use-gl=angle --use-angle=swiftshader-webgl --shared-files --field-trial-handle=0,i,4975378740503322807,8852675362163135929,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                    pi        1478  1097  0 14:31 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,4975378740503322807,8852675362163135929,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                    pi        1498  1096  1 14:31 ?        00:00:01 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                    pi        1517  1109  4 14:31 ?        00:00:04 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=renderer --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --app-path=/home/pi/MagicMirror/js --enable-sandbox --autoplay-policy=no-user-gesture-required --disable-gpu-compositing --lang=fr --num-raster-threads=2 --enable-main-frame-before-activation --renderer-client-id=4 --time-ticks-at-unix-epoch=-1757680110193681 --launch-time-ticks=192347868 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                    pi        1662  1367  0 14:33 pts/1    00:00:00 grep --color=auto MagicMirror
                      pat59
                      Hello, I stopped it with smartphone remote control.
                        sdetweil @pat59
                        @pat59 you have two instances… pick one… delete the other
                        pm2 --help
                        will give you the command options
                        what is the remote control function to stop it?
                        • 1 / 5
