    update package list
    45 Posts 2 Posters 15.8k Views 2 Watching
      pat59
      pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
      pi@raspberrypi:~/MagicMirror $ npm install
      magicmirror@2.27.0 postinstall
      npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
      magicmirror@2.27.0 install-vendor
      echo "Installing vendor files …
      " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      up to date in 3s
      magicmirror@2.27.0 install-fonts
      echo "Installing fonts …
      " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      Installing fonts …
      up to date in 3s
      magicmirror@2.27.0 prepare
      [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
      added 976 packages in 8m
      205 packages are looking for funding
      run npm fund for details
        sdetweil @pat59
        @pat59 and now
        npm start
          pat59
          I don’t know how to thank you, it’s working again, thank you, thank you
            pat59
            Well, it’s working normally again. I don’t know how to thank you. Thank you, thank you.
              pat59
              Hello, I must have missed a step. I started my mirror this morning, same problem.
              pi@raspberrypi:~/MagicMirror $ pm2 stop MagicMirror
              [PM2] Applying action stopProcessId on app [MagicMirror](ids: [ 1 ])
              [PM2] MagicMirror ✓
              │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
              │ 1 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b │
              │ 0 │ mm │ fork │ 0 │ online │ 0% │ 2.4mb │
              magicmirror@2.27.0 start
              [2025-09-12 07:06:24.742] [LOG] Starting MagicMirror: v2.27.0
              [2025-09-12 07:06:24.863] [LOG] Loading config …
              [2025-09-12 07:06:24.888] [LOG] config template file not exists, no envsubst
              [2025-09-12 07:06:24.899] [LOG] Loading module helpers …
              [2025-09-12 07:06:25.265] [LOG] Initializing new module helper …
              [2025-09-12 07:06:25.269] [LOG] Module helper loaded: MMM-Remote-Control
              [2025-09-12 07:06:25.273] [LOG] No helper found for module: alert.
              [2025-09-12 07:06:25.286] [LOG] Initializing new module helper …
              [2025-09-12 07:06:25.290] [LOG] Module helper loaded: MMM-Saint
              [2025-09-12 07:06:25.299] [LOG] Initializing new module helper …
              [2025-09-12 07:06:25.301] [LOG] Module helper loaded: MMM-BME280
              [2025-09-12 07:06:25.303] [LOG] No helper found for module: MMM-FlipClock.
              [2025-09-12 07:06:25.467] [LOG] Initializing new module helper …
              [2025-09-12 07:06:25.469] [LOG] Module helper loaded: MMM-network-signal
              [2025-09-12 07:06:26.004] [LOG] Initializing new module helper …
              [2025-09-12 07:06:26.005] [LOG] Module helper loaded: calendar
              [2025-09-12 07:06:27.471] [LOG] Initializing new module helper …
              [2025-09-12 07:06:27.474] [LOG] Module helper loaded: MMM-Jast
              [2025-09-12 07:06:28.921] [LOG] Initializing new module helper …
              [2025-09-12 07:06:28.923] [LOG] Module helper loaded: MMM-GooglePhotos
              [2025-09-12 07:06:28.926] [LOG] No helper found for module: MMM-WiFiPassword.
              [2025-09-12 07:06:28.929] [LOG] No helper found for module: MMM-OpenmapWeather.
              [2025-09-12 07:06:28.931] [LOG] No helper found for module: MMM-WeatherOrNot.
              [2025-09-12 07:06:28.933] [WARN] No /home/pi/MagicMirror/js/…/modules/MMM-Linky/MMM-Linky.js found for module: MMM-Linky.
              [2025-09-12 07:06:28.935] [LOG] No helper found for module: MMM-Linky.
              [2025-09-12 07:06:29.442] [LOG] Initializing new module helper …
              [2025-09-12 07:06:29.444] [LOG] Module helper loaded: newsfeed
              [2025-09-12 07:06:29.446] [LOG] All module helpers loaded.
              [2025-09-12 07:06:29.475] [LOG] Starting server on port 8080 …
              [2025-09-12 07:06:29.494] [WARN] You’re using a full whitelist configuration to allow for all IPs
              [2025-09-12 07:06:31.407] [ERROR] Whoops! There was an uncaught exception…
              [2025-09-12 07:06:31.452] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
              at Server.setupListenHandle [as _listen2] (node:net:1872:16)
              at listenInCluster (node:net:1920:12)
              at doListen (node:net:2069:7)
              at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
              code: ‘EADDRINUSE’,
              errno: -98,
              syscall: ‘listen’,
              address: ‘0.0.0.0’,
              port: 8080
              [2025-09-12 07:06:31.459] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [2025-09-12 07:06:31.461] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
              [2025-09-12 07:06:44.850] [INFO] System information:
              SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
              OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 6.12.45-v7+
              VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
              OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
              [PM2] MagicMirror ✓
              code: ‘EADDRINUSE’,
              errno: -98,
              syscall: ‘listen’,
              address: ‘0.0.0.0’,
              port: 8080
                sdetweil @pat59
                @pat59
                Did you stop it manually ctrl-q
                Yesterday after we finished testing?
                pm2 status
                Is anything listed as running?
                If not then do this
                ps -ef| grep MagicMirror
                You should only get one line of output
                  pat59
                  pi@raspberrypi:~/MagicMirror $ pm2 status
                  │ 1  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.5mb    │
                  │ 0  │ mm                 │ fork     │ 0    │ online    │ 0%       │ 2.3mb    │
                  so you have two instances
                  pi@raspberrypi:~/MagicMirror $ ps -ef|grep MagicMirror
                  pi        1037   818  0 14:29 ?        00:00:00 bash /home/pi/MagicMirror/installers/mm.sh
                  pi        1096  1075 26 14:29 ?        00:00:56 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
                  pi        1097  1077 24 14:29 ?        00:00:52 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
                  pi        1102  1097  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox
                  pi        1103  1096  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox
                  pi        1104  1096  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                  pi        1106  1097  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                  pi        1109  1104  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                  pi        1110  1106  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                  pi        1407  1103  1 14:31 ?        00:00:01 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --use-gl=angle --use-angle=swiftshader-webgl --shared-files --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                  pi        1408  1102  0 14:31 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --use-gl=angle --use-angle=swiftshader-webgl --shared-files --field-trial-handle=0,i,4975378740503322807,8852675362163135929,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                  pi        1478  1097  0 14:31 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,4975378740503322807,8852675362163135929,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                  pi        1498  1096  1 14:31 ?        00:00:01 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                  pi        1517  1109  4 14:31 ?        00:00:04 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=renderer --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --app-path=/home/pi/MagicMirror/js --enable-sandbox --autoplay-policy=no-user-gesture-required --disable-gpu-compositing --lang=fr --num-raster-threads=2 --enable-main-frame-before-activation --renderer-client-id=4 --time-ticks-at-unix-epoch=-1757680110193681 --launch-time-ticks=192347868 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                  pi        1662  1367  0 14:33 pts/1    00:00:00 grep --color=auto MagicMirror
                    pat59
                    Hello, I stopped it with smartphone remote control.
                      sdetweil @pat59
                      @pat59 you have two instances… pick one… delete the other
                      pm2 --help
                      will give you the command options
                      what is the remote control function to stop it?
                        pat59
                        I used restart RPII used restart RPI
                          pat59
                          pi@raspberrypi:~/MagicMirror $ pm2 --help
                          Usage: pm2 [cmd] app
                          Options:
                          -V, --version                                                output the version number
                          -v --version                                                 print pm2 version
                          -s --silent                                                  hide all messages
                          --ext <extensions>                                           watch only this file extensions
                          -n --name <name>                                             set a name for the process in the process list
                          -m --mini-list                                               display a compacted list without formatting
                          --interpreter <interpreter>                                  set a specific interpreter to use for executing app, default: node
                          --interpreter-args <arguments>                               set arguments to pass to the interpreter (alias of --node-args)
                          --node-args <node_args>                                      space delimited arguments to pass to node
                          -o --output <path>                                           specify log file for stdout
                          -e --error <path>                                            specify log file for stderr
                          -l --log [path]                                              specify log file which gathers both stdout and stderr
                          --filter-env [envs]                                          filter out outgoing global values that contain provided strings (default: )
                          --log-type <type>                                            specify log output style (raw by default, json optional)
                          --log-date-format <date format>                              add custom prefix timestamp to logs
                          --time                                                       enable time logging
                          --disable-logs                                               disable all logs storage
                          --env <environment_name>                                     specify which set of environment variables from ecosystem file must be injected
                          -a --update-env                                              force an update of the environment with restart/reload (-a <=> apply)
                          -f --force                                                   force actions
                          -i --instances <number>                                      launch [number] instances (for networked app)(load balanced)
                          --parallel <number>                                          number of parallel actions (for restart/reload)
                          --shutdown-with-message                                      shutdown an application with process.send('shutdown') instead of process.kill(pid, SIGINT)
                          -p --pid <pid>                                               specify pid file
                          -k --kill-timeout <delay>                                    delay before sending final SIGKILL signal to process
                          --listen-timeout <delay>                                     listen timeout on application reload
                          --max-memory-restart <memory>                                Restart the app if an amount of memory is exceeded (in bytes)
                          --restart-delay <delay>                                      specify a delay between restarts (in milliseconds)
                          --exp-backoff-restart-delay <delay>                          specify a delay between restarts (in milliseconds)
                          -x --execute-command                                         execute a program using fork system
                          --max-restarts [count]                                       only restart the script COUNT times
                          -u --user <username>                                         define user when generating startup script
                          --uid <uid>                                                  run target script with <uid> rights
                          --gid <gid>                                                  run target script with <gid> rights
                          --namespace <ns>                                             start application within specified namespace
                          --cwd <path>                                                 run target script from path <cwd>
                          --hp <home path>                                             define home path when generating startup script
                          --wait-ip                                                    override systemd script to wait for full internet connectivity to launch pm2
                          --service-name <name>                                        define service name when generating startup script
                          -c --cron <cron_pattern>                                     restart a running process based on a cron pattern
                          -c --cron-restart <cron_pattern>                             (alias) restart a running process based on a cron pattern
                          -w --write                                                   write configuration in local folder
                          --no-daemon                                                  run pm2 daemon in the foreground if it doesn't exist already
                          --source-map-support                                         force source map support
                          --only <application-name>                                    with json declaration, allow to only act on one application
                          --disable-source-map-support                                 force source map support
                          --wait-ready                                                 ask pm2 to wait for ready event from your app
                          --merge-logs                                                 merge logs from different instances but keep error and out separated
                          --watch [paths]                                              watch application folder for changes (default: )
                          --ignore-watch <folders|files>                               List of paths to ignore (name or regex)
                          --watch-delay <delay>                                        specify a restart delay after changing files (--watch-delay 4 (in sec) or 4000ms)
                          --no-color                                                   skip colors
                          --no-vizion                                                  start an app without vizion feature (versioning control)
                          --no-autostart                                               add an app without automatic start
                          --no-autorestart                                             start an app without automatic restart
                          --stop-exit-codes <exit_codes...>                            specify a list of exit codes that should skip automatic restart
                          --no-treekill                                                Only kill the main process, not detached children
                          --no-pmx                                                     start an app without pmx
                          --no-automation                                              start an app without pmx
                          --trace                                                      enable transaction tracing with km
                          --disable-trace                                              disable transaction tracing with km
                          --sort <field_name:sort>                                     sort process according to field's name
                          --attach                                                     attach logging after your start/restart/stop/reload
                          --v8                                                         enable v8 data collecting
                          --event-loop-inspector                                       enable event-loop-inspector dump in pmx
                          --deep-monitoring                                            enable all monitoring tools (equivalent to --v8 --event-loop-inspector --trace)
                          -h, --help                                                   output usage information
                          Commands:
                          start [options] [name|namespace|file|ecosystem|id...]        start and daemonize an app
                          trigger <id|proc_name|namespace|all> <action_name> [params]  trigger process action
                          deploy <file|environment>                                    deploy your json
                          startOrRestart <json>                                        start or restart JSON file
                          startOrReload <json>                                         start or gracefully reload JSON file
                          pid [app_name]                                               return pid of [app_name] or all
                          create                                                       return pid of [app_name] or all
                          startOrGracefulReload <json>                                 start or gracefully reload JSON file
                          stop [options] <id|name|namespace|all|json|stdin...>         stop a process
                          restart [options] <id|name|namespace|all|json|stdin...>      restart a process
                          scale <app_name> <number>                                    scale up/down a process in cluster mode depending on total_number param
                          profile:mem [time]                                           Sample PM2 heap memory
                          profile:cpu [time]                                           Profile PM2 cpu
                          reload <id|name|namespace|all>                               reload processes (note that its for app using HTTP/HTTPS)
                          id <name>                                                    get process id by name
                          inspect <name>                                               inspect a process
                          delete|del <name|id|namespace|script|all|json|stdin...>      stop and delete a process from pm2 process list
                          sendSignal <signal> <pm2_id|name>                            send a system signal to the target process
                          ping                                                         ping pm2 daemon - if not up it will launch it
                          updatePM2                                                    update in-memory PM2 with local PM2
                          update                                                       (alias) update in-memory PM2 with local PM2
                          install|module:install [options] <module|git:/>              install or update a module and run it forever
                          module:update <module|git:/>                                 update a module and run it forever
                          module:generate [app_name]                                   Generate a sample module in current folder
                          uninstall|module:uninstall <module>                          stop and uninstall a module
                          package [target]                                             Check & Package TAR type module
                          publish|module:publish [options] [folder]                    Publish the module you are currently on
                          set [key] [value]                                            sets the specified config <key> <value>
                          multiset <value>                                             multiset eg "key1 val1 key2 val2
                          get [key]                                                    get value for <key>
                          conf [key] [value]                                           get / set module config values
                          config <key> [value]                                         get / set module config values
                          unset <key>                                                  clears the specified config <key>
                          report                                                       give a full pm2 report for https://github.com/Unitech/pm2/issues
                          link [options] [secret] [public] [name]                      link with the pm2 monitoring dashboard
                          unlink                                                       unlink with the pm2 monitoring dashboard
                          monitor [name]                                               monitor target process
                          unmonitor [name]                                             unmonitor target process
                          open                                                         open the pm2 monitoring dashboard
                          plus|register [options] [command] [option]                   enable pm2 plus
                          login                                                        Login to pm2 plus
                          logout                                                       Logout from pm2 plus
                          dump|save [options]                                          dump all processes for resurrecting them later
                          cleardump                                                    Create empty dump file
                          send <pm_id> <line>                                          send stdin to <pm_id>
                          attach <pm_id> [comman]                                      attach stdin/stdout to application identified by <pm_id>
                          resurrect                                                    resurrect previously dumped processes
                          unstartup [platform]                                         disable the pm2 startup hook
                          startup [platform]                                           enable the pm2 startup hook
                          logrotate                                                    copy default logrotate configuration
                          ecosystem|init [mode]                                        generate a process conf file. (mode = null or simple)
                          reset <name|id|all>                                          reset counters for process
                          describe <name|id>                                           describe all parameters of a process
                          desc <name|id>                                               (alias) describe all parameters of a process
                          info <name|id>                                               (alias) describe all parameters of a process
                          show <name|id>                                               (alias) describe all parameters of a process
                          env <id>                                                     list all environment variables of a process id
                          list|ls                                                      list all processes
                          l                                                            (alias) list all processes
                          ps                                                           (alias) list all processes
                          status                                                       (alias) list all processes
                          jlist                                                        list all processes in JSON format
                          sysmonit                                                     start system monitoring daemon
                          slist|sysinfos [options]                                     list system infos in JSON
                          prettylist                                                   print json in a prettified JSON
                          monit                                                        launch termcaps monitoring
                          imonit                                                       launch legacy termcaps monitoring
                          dashboard|dash                                               launch dashboard with monitoring and logs
                          flush [api]                                                  flush logs
                          reloadLogs                                                   reload all logs
                          logs [options] [id|name|namespace]                           stream logs file. Default stream all logs
                          kill                                                         kill daemon
                          pull <name> [commit_id]                                      updates repository for a given app
                          forward <name>                                               updates repository to the next commit for a given app
                          backward <name>                                              downgrades repository to the previous commit for a given app
                          deepUpdate                                                   performs a deep update of PM2
                          serve|expose [options] [path] [port]                         serve a directory over http via port
                          autoinstall
                          examples                                                     display pm2 usage examples
                            sdetweil @pat59
                            @pat59 said in update package list:
                            I don’t know what that means in reality under the covers
                            so, you need to delete one of the apps… unless you intentionally have two instances.
                            they show online, and no restarts, which is weird
                              pat59
                              Well, thank you, I’m going to stop now. I’m 65 years old and I don’t always understand what to do. I’m a novice. I don’t know which application to delete. Thanks again for your help.
                                sdetweil @pat59
                                @pat59 im 74… so its never too late
                                try this
                                pm2 stop mm
                                pm2 restart MagicMirror
                                  pat59
                                  pi@raspberrypi:~/MagicMirror $ pm2 stop mm
                                  [PM2] Applying action stopProcessId on app [mm](ids: [ 0 ])
                                  [PM2] mm ✓
                                  │ 1  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
                                  │ 0  │ mm                 │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                                  pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror
                                  [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 1 ])
                                  [PM2] MagicMirror ✓
                                  │ 1  │ MagicMirror        │ fork     │ 1    │ online    │ 0%       │ 2.4mb    │
                                    pat59
                                    Congratulations on your courage
                                    Do I have to restart after that?
                                      sdetweil @pat59
                                      @pat59 is it working? after the pm2 restart?
                                        pat59
                                        Hello
                                        No, I have the other apps working fine except for Calendar, which is still loading, and Newsfeed, which is also loading.
                                          sdetweil @pat59
                                          @pat59
                                          Ok,
                                          Because you are using pm2 makes getting log a little more interesting
                                          Do
                                          pm2 stop all
                                          pm2 flush
                                          pm2 start MagicMirror
                                          Wait til MagicMirror comes up and modules show loading
                                          Then do
                                          pm2 logs —lines=100.
                                          The n look thru the listing and see if there are any errors reported
                                          Also can you post the configuration from config.js for those two modules
                                          Note the calendar module url needs to be mangled, xxx part so it doesn’t expose the full url
                                            pat59
                                            Hello, here is the error it gives me.
                                            pi@raspberrypi:~/MagicMirror $ pm2 stop all
                                            [PM2] Applying action stopProcessId on app [all](ids: [ 0, 1 ])
                                            [PM2] mm ✓
                                            [PM2] MagicMirror ✓
                                            pi@raspberrypi:~/MagicMirror $ pm2 flush
                                            [PM2] Flushing /home/pi/.pm2/pm2.log
                                            [PM2] Flushing:
                                            [PM2] /home/pi/.pm2/logs/mm-out.log
                                            [PM2] /home/pi/.pm2/logs/mm-error.log
                                            [PM2] Flushing:
                                            [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                                            [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                                            [PM2] Logs flushed
                                            pi@raspberrypi:~/MagicMirror $ pm2 start MagicMirror
                                            [PM2] MagicMirror ✓
                                            [PM2] Process successfully started
                                            pi@raspberrypi:~/MagicMirror $ pm2 logs -lines=100.
                                            error: unknown option `-=’
