    update package list
    45 Posts 2 Posters 11.3k Views 2 Watching
      pat59
      After updating the package list,
      sudo apt-get update
      sudo apt-get dist-uprade
      and updating Raspbian
      sudo rpi-update
      I no longer have Calendar and Newsfeed, it says “loading” but nothing appears.
      What should I do? Thank you.
        pat59
        Hello
        Thank you for what you did for me. Now it’s bothering me. We’ll stop there and close the session. Thank you again. Thank you for your help. You are a fantastic person. Thank you for your time spent on our problems. Thank you and thank you again.
          sdetweil @pat59
          @pat59 show the output of npm start
          But when you change the os under an app, it’s recommended to reset it too
          Stop MagicMirror
          rm -rf node_modules
          npm install
          Start MagicMirror
            pat59
            Hello, I did the manipulation, it doesn’t work. To stop Magic Mirror, I have to press Ctrl+M.
            pi@raspberrypi:~ $ npm start
            npm ERR! Missing script: “start”
            npm ERR!
            npm ERR! Did you mean one of these?
            npm ERR! npm star # Mark your favorite packages
            npm ERR! npm stars # View packages marked as favorites
            npm ERR!
            npm ERR! To see a list of scripts, run:
            npm ERR! npm run
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2025-09-11T14_07_45_151Z-debug-0.log
            pi@raspberrypi:~ $
              sdetweil @pat59
              @pat59 all MM commands require you to be IN the MagicMirror folder
              you are still in the users home folder
              pi@raspberrypi:~
                pat59
                magicmirror@2.27.0 start
                [2025-09-11 16:56:55.039] [LOG] Starting MagicMirror: v2.27.0
                [2025-09-11 16:56:55.176] [LOG] Loading config …
                [2025-09-11 16:56:55.192] [LOG] config template file not exists, no envsubst
                [2025-09-11 16:56:55.206] [LOG] Loading module helpers …
                [2025-09-11 16:56:55.858] [LOG] Initializing new module helper …
                [2025-09-11 16:56:55.860] [LOG] Module helper loaded: MMM-Remote-Control
                [2025-09-11 16:56:55.863] [LOG] No helper found for module: alert.
                [2025-09-11 16:56:55.885] [LOG] Initializing new module helper …
                [2025-09-11 16:56:55.887] [LOG] Module helper loaded: MMM-Saint
                [2025-09-11 16:56:55.913] [LOG] Initializing new module helper …
                [2025-09-11 16:56:55.915] [LOG] Module helper loaded: MMM-BME280
                [2025-09-11 16:56:55.933] [LOG] No helper found for module: MMM-FlipClock.
                [2025-09-11 16:56:56.121] [LOG] Initializing new module helper …
                [2025-09-11 16:56:56.122] [LOG] Module helper loaded: MMM-network-signal
                [2025-09-11 16:56:56.827] [LOG] Initializing new module helper …
                [2025-09-11 16:56:56.828] [LOG] Module helper loaded: calendar
                [2025-09-11 16:56:58.426] [LOG] Initializing new module helper …
                [2025-09-11 16:56:58.427] [LOG] Module helper loaded: MMM-Jast
                [2025-09-11 16:57:00.066] [LOG] Initializing new module helper …
                [2025-09-11 16:57:00.069] [LOG] Module helper loaded: MMM-GooglePhotos
                [2025-09-11 16:57:00.088] [LOG] No helper found for module: MMM-WiFiPassword.
                [2025-09-11 16:57:00.093] [LOG] No helper found for module: MMM-OpenmapWeather.
                [2025-09-11 16:57:00.107] [LOG] No helper found for module: MMM-WeatherOrNot.
                [2025-09-11 16:57:00.122] [WARN] No /home/pi/MagicMirror/js/…/modules/MMM-Linky/MMM-Linky.js found for module: MMM-Linky.
                [2025-09-11 16:57:00.124] [LOG] No helper found for module: MMM-Linky.
                [2025-09-11 16:57:00.569] [LOG] Initializing new module helper …
                [2025-09-11 16:57:00.571] [LOG] Module helper loaded: newsfeed
                [2025-09-11 16:57:00.573] [LOG] All module helpers loaded.
                [2025-09-11 16:57:00.599] [LOG] Starting server on port 8080 …
                [2025-09-11 16:57:00.649] [WARN] You’re using a full whitelist configuration to allow for all IPs
                [2025-09-11 16:57:03.916] [ERROR] Whoops! There was an uncaught exception…
                [2025-09-11 16:57:03.930] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                at Server.setupListenHandle [as _listen2] (node:net:1872:16)
                at listenInCluster (node:net:1920:12)
                at doListen (node:net:2069:7)
                at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
                code: ‘EADDRINUSE’,
                errno: -98,
                syscall: ‘listen’,
                address: ‘0.0.0.0’,
                port: 8080
                [2025-09-11 16:57:03.933] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2025-09-11 16:57:03.936] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                [2025-09-11 16:57:40.629] [INFO] System information:
                SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
                OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 6.12.45-v7+
                VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
                OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
                  sdetweil @pat59
                  @pat59 so, you already have an instance running, probably under pm2
                  when I said stop MM I meant in whatever way running…
                  pm2’s JOB is to start and KEEP MM running… no matter what
                  you ctrl-Q
                  pm2 says, oops, app crashed, restart…
                  so, you have to use the pm2 commands to tell it what to do
                  pm2 status
                  will show the managed apps, one line per
                  you can control the app, by using the name or number of the app in a row
                  pm2 stop 0
                  pm2 stop MagicMirror
                  could both be for the same app
                  once stopped, THEN you can go to the MM folder and do the npm start to see the possible errors easier…
                  once you fix the errors, you can stop the temp MM with ctrl-q (as you started it manually)
                  and then tell pm2 to manage it again
                  pm2 start 0/MagicMirror
                    pat59
                    pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                    pi@raspberrypi:~/MagicMirror $ npm install
                    magicmirror@2.27.0 postinstall
                    npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                    magicmirror@2.27.0 install-vendor
                    echo "Installing vendor files …
                    " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    up to date in 3s
                    magicmirror@2.27.0 install-fonts
                    echo "Installing fonts …
                    " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    Installing fonts …
                    up to date in 3s
                    magicmirror@2.27.0 prepare
                    [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                    added 976 packages in 8m
                    205 packages are looking for funding
                    run npm fund for details
                      sdetweil @pat59
                      @pat59 and now
                      npm start
                        pat59
                        I don’t know how to thank you, it’s working again, thank you, thank you
                          pat59
                          Well, it’s working normally again. I don’t know how to thank you. Thank you, thank you.
                          • 1 / 5
