    Cannot find module '#server_functions'
    18 Posts 3 Posters 1.0k Views 3 Watching
      sdetweil @chrisfr1976
      @chrisfr1976 can you do
      Stop MagicMirror
      cd -/MagicMirror
      rm -rf node_modules
      npm install
      Start MagicMirror
      npm start
      Also, can you send me the
      ~/MagicMirror/installers/upgrade.log
      My email is same user id as here, at gmail
        I don’t see that error in my test of npm run server.
        • C Offline
          chrisfr1976 @sdetweil
          @sdetweil and @karsten13, I think I solved my problem.
          In the beginning when I used the update script it stopped with the node-version but didn’t update. So I updated manually by using the original code from Node JS. So I installed node v22.20.0. Later I went again down to v22.18.0. Maybe this caused some trouble. But Maybe not. rm -rf node_modules and npm install I did already 3 times before.
          But now I modified the calendarfetcher.js and newsfeedfetcher.js:
          This was removed:
          const { getUserAgent } = require("#server_functions");
          const { scheduleTimer } = require("#module_functions");
          and replaced by this:
          const getUserAgent = () => "MagicMirror v2.33.0";
          const scheduleTimer = (timerRef, interval, callback) => {
              clearTimeout(timerRef);
              return setTimeout(callback, interval);
          No errors and Calendar/Newsfeed is displayed as before. I don’t know exactly if there are any new issues now but so far I’m happy.
          Regards, Chris.
            @chrisfr1976 I’d really like to see the upgrade.log file
            Email to Me , same userid as here at gmail
            • C Offline
              @sdetweil Hey, no problem generally but I‘m out until Thursday. I‘ll send it then.
              Regards, Chris.
                @chrisfr1976 when you have time
                • C Offline
                  Hi Sam,
                  After the update to MagicMirror v2.34.0 I had again this Cannot find module '#server_functions issue. See above.
                  I solved it again manually in the calendarfetcher.js and newsfeedfetcher.js with a relative path.
                  I replaced this:
                  const { scheduleTimer } = require("#module_functions"); //only in newsfeed
                  with
                  const { getUserAgent } = require("../../../js/server_functions");
                  const { scheduleTimer } = require("../../../js/module_functions"); //only in newsfeed
                  This time your update script worked fine without any error.
                  Maybe I’m alone with this behavior, but now everything works fine again as before the update. If anyone else discovers this problem, the code above might help.
                  Regards, Chris.
                  C S 3 Replies Last reply Reply Quote 0
                  • C Offline
                    chrisfr1976 @chrisfr1976
                    …and I’ll remove axios from my modules. This is causing this trouble.
                    Regards, Chris.
                      @chrisfr1976 but that means you dont have the correct node version or dependencies
                      Down level npm, see imports in package.json
                        @chrisfr1976 can you send me ~/MagicMirror/installers/upgrade.log
                        Same userid as here at gmail
