    MMM-NOAAForecast install fails
    6 Posts 2 Posters 2.4k Views 2 Watching
      RonR
      I’ve tried several times to install MMM-NOAAForecast and it has failed every time. When I restart MM it shows “Loading” and that is all. I went back in the logs for this last try and found the following:
      [2025-11-08 16:30:50.514] [LOG]   Initializing new module helper ...
      [2025-11-08 16:30:50.514] [LOG]   Module helper loaded: calendar
      [2025-11-08 16:30:50.514] [ERROR] Error when loading MMM-NOAAForecast: Cannot find module 'needle'
      Require stack:
      - /opt/magic_mirror/modules/MMM-NOAAForecast/node_helper.js
      - /opt/magic_mirror/js/app.js
      - /opt/magic_mirror/serveronly/index.js
      [2025-11-08 16:30:50.516] [LOG]   Initializing new module helper ...
      I was using MMM-CONFIG installer to do the install. This is MM on Docker. Dell Inspiron running Ubuntu 24.02.
        sdetweil @RonR
        @RonR yes, this is a module problem… the module does not document that it NEEDS needle
        it has no package.json, which documents the dependencies…
        this highlights a gap in the MMM-Config installer…
        I have some code in the upgrade script that checks for KNOWN missing requires…
        I opened issue https://github.com/sdetweil/MMM-Config/issues/77
        to fix this on the current setup
        ssh to the docker host
        docker exec -it mm bash
        cd modules/MMM-NOAAForecast
        npm install needle
        exit
        then restart the docker container
        cd ~/magicmirror/run
        docker compose up -d
        exit
        the module should be working now
        • R RonR has marked this topic as solved on
          RonR
          That did it. Had to do a “docker restart mm” also before the screen updated correctly. Thanks for your help.
            sdetweil @RonR
            @RonR docker compose up should force a restart, but you got it
              sdetweil @RonR
              @RonR I have completed the fixes for this problem as a general solution… thanks for pointing it out.
              git pull in the module folder to get the fix
              (on docker you have to docker exec into the container first)
                RonR
                Yes, that fixed it . Thanks for the help.
