    MMM-NOAAForecast install fails
    5 Posts 2 Posters 79 Views 2 Watching
      RonR
      I’ve tried several times to install MMM-NOAAForecast and it has failed every time. When I restart MM it shows “Loading” and that is all. I went back in the logs for this last try and found the following:
      [2025-11-08 16:30:50.514] [LOG]   Initializing new module helper ...
      [2025-11-08 16:30:50.514] [LOG]   Module helper loaded: calendar
      [2025-11-08 16:30:50.514] [ERROR] Error when loading MMM-NOAAForecast: Cannot find module 'needle'
      Require stack:
      - /opt/magic_mirror/modules/MMM-NOAAForecast/node_helper.js
      - /opt/magic_mirror/js/app.js
      - /opt/magic_mirror/serveronly/index.js
      [2025-11-08 16:30:50.516] [LOG]   Initializing new module helper ...
      I was using MMM-CONFIG installer to do the install. This is MM on Docker. Dell Inspiron running Ubuntu 24.02.
        sdetweil @RonR
        @RonR yes, this is a module problem… the module does not document that it NEEDS needle
        it has no package.json, which documents the dependencies…
        this highlights a gap in the MMM-Config installer…
        I have some code in the upgrade script that checks for KNOWN missing requires…
        I opened issue https://github.com/sdetweil/MMM-Config/issues/77
        to fix this on the current setup
        ssh to the docker host
        docker exec -it mm bash
        cd modules/MMM-NOAAForecast
        npm install needle
        exit
        then restart the docker container
        cd ~/magicmirror/run
        docker compose up -d
        exit
        the module should be working now
        • R RonR has marked this topic as solved
          RonR
          That did it. Had to do a “docker restart mm” also before the screen updated correctly. Thanks for your help.
            sdetweil @RonR
            @RonR docker compose up should force a restart, but you got it
              sdetweil @RonR
              @RonR I have completed the fixes for this problem as a general solution… thanks for pointing it out.
              git pull in the module folder to get the fix
              (on docker you have to docker exec into the container first)
