    Default weather module - only showing one location
    11 Posts 2 Posters 37 Views 2 Watching
      Ausnet
      Ok - so I tried the following - still said “Loading…”
      Replaced it with the same location as my local area and it came up.
      Restored it to the Australian location and now it’s working :/
      The only thing left is that it’s still displaying in Fahrenheit for Australia even though units are set to metric for those modules.
                              module: "weather",
                              position: "bottom_right",
                              header: "Current Weather",
                                      weatherProvider: "openmeteo",
                                      type: "current",
                                      lat: -27.24796,
                                      lon: 153.00886,
                                      showPrecipitationAmount: true,
                                      showPreciptitationProbability: true,
                                      degreeLabel: true,
                                      colored: true,
                                      units: "metric",
                              module: "weather",
                              header: "Forecast",
                                      type: "forecast",
                                      lat: -27.24796,
                                      lon: 153.00886,
                                      showUVIndex: true,
                                      fadePoint: 0.33,
                                      maxNumberOfDays: 7,
                                      degreeLabel: true,
                                      colored: true,
                                      units: "metric",
        sdetweil @Ausnet
        @Ausnet what is units: above the module list set to?
          Ausnet @sdetweil
          @sdetweil before the modules it’s set to imperial. Do the settings in the inner modules not override the outer setting?
                  timeFormat: 12,
                  showperiod: true,
                  units: "imperial",
            sdetweil @Ausnet
            @Ausnet I thought so, but this module looks at the global value for some reason
              sdetweil @Ausnet
              @Ausnet can you tell me what version of MM you are running
              grep version ~/MagicMirror/package.json
                also set tempUnits:“metric”
                from the doc
                tempUnits
                What units to use for temperature.
                If not specified, the module uses the units value from config.js. <-----
                Possible values: config.units = Specified by config.js, metric = Celsius, imperial = Fahrenheit
                Default value: config.units <-----
                  Ausnet @sdetweil
                  @sdetweil said in Default weather module - only showing one location:
                  It’s showing 2.34.0
                    Ausnet @sdetweil
                    @sdetweil That did it. Thanks!
