    MagicMirror-backup-restore
    7 Posts 2 Posters 615 Views 2 Watching
      rkorell Module Developer
      Dear Sam ( @sdetweil) ,
      Hope you’re doing well! I’ve been using your MagicMirror backup-restore scripts for quite a while
      now and they’ve been super helpful - thank you so much for maintaining them!
      I just ran into a small issue that I wanted to share. At some point in the past, I had used
      mm_restore.sh, which left my local backup repo on a branch called restore-branch. When I ran
      mm_backup.sh today (after a loooong time) , it committed the backup to restore-branch (since that was
      the checked-out branch), but the push command on line 511 explicitly pushes main:
      git push -u origin main refs/tags/$next_tagnumber
      So the tag got pushed correctly, but the actual backup commit never made it to main on GitHub -
      because the commit was on restore-branch while the push targeted main (which still pointed to the
      old commit).
      Easy fix on my end - I just merged restore-branch into main and pushed. But you might want to add
      a git checkout main (or git switch main) somewhere before the commit step in mm_backup.sh, so the
      script always commits to the right branch regardless of which branch happens to be checked out.
      Thanks again for all your work on this - and for all the help you are performing here for us!
      Ralf
      • R rkorell has marked this topic as solved on
        sdetweil @rkorell
        @rkorell thanks.
        Hm.
        If I git remote on the backup folder.
        And git branch on the folder and
        they are different what do you think I should do
        What is the right branch?
          Dear Sam, @sdetweil ,
          sorry for the late reply — time zones 😊 (it was night here in Germany when you posted).
          To answer your question: the right branch is main.
          That’s where mm_backup.sh pushes to
          (git push -f origin main) , and that’s where backups should live.
          The problem is that mm_restore.sh creates and checks out a “restore”-branch but never switches back (to main) or deletes “restore” afterwards. So after a restore, the local repo stays on restore-branch.
          When mm_backup.sh runs next, it does git add and git commit — which goes to the currently checked-out branch (restore-branch), but then pushes main. So the new backup commit is “lost” on the wrong branch.
          I think the simplest fix would be to add a git checkout main at the beginning of mm_backup.sh,
          before any git operations. That way it always commits to the right branch regardless of what
          happened before.
          Alternatively, mm_restore.sh could clean up after itself by switching back to main and deleting
          restore-branch when it’s done.
          Thanks for looking into it!
          Warmest regards,
          Ralf
            sdetweil @rkorell
            @rkorell no sorry needed. We all respond when we can
            Got it. Both scripts are broken
            Backup for not checking and correcting
            Restore for not cleaning up
              @sdetweil OK; cool! Thanks again for all your effort!
              Warmest regards,
              Ralf
                sdetweil @rkorell
                @rkorell I have pushed fixes for both scripts to handle this error in the previous versions…
                both backup and restore will handle the case where the restore-branch exists (as now)
                and cleanup after…
                thanks for the report and feedback
                  @sdetweil resolved in less than 24 hours :-) This is “responsive” !
                  Thanks again!
                  Ralf
