    MMM-Swipe - Hand gestures
    45 Posts 17 Posters 44.8k Views 16 Watching
    • SnilleS Offline
      Snille Module Developer
      Hi, I’m trying out your module.
      I’m not running the Mirror with sudo, is there no other way to get your module to work?
      I’m getting this:
      { Error: EACCES, Permission denied
          at Error (native)
          at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-gpio/lib/gpio.js:32:18
          at ChildProcess.exithandler (child_process.js:209:7)
          at emitTwo (events.js:106:13)
          at ChildProcess.emit (events.js:191:7)
          at maybeClose (internal/child_process.js:877:16)
          at Socket. (internal/child_process.js:334:11)
          at emitOne (events.js:96:13)
          at Socket.emit (events.js:188:7)
          at Pipe._handle.close [as _onclose] (net.js:493:12) errno: 13, code: 'EACCES', syscall: 'init' }
      I’m guessing it have to do with the mirror not running as root…
      the pi user is a member of the gpio group at least. :)
      Thank you.
      Best regards Snille
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
      • mochmanM Offline
        mochman Module Developer
        @Snille Yeah, this module requires root access. I haven’t developed it since I first made it so I’m not sure if it still works with all the updates the pi & MM have gotten. Sorry.
        SnilleS M 2 Replies Last reply Reply Quote 0
        • SnilleS Offline
          Snille Module Developer @mochman
          @mochman No worries, thank you for letting me know. :)
            Michii_M @mochman
            @mochman
            Hey
            Since this module does not work anymore, I would like to try to get it running again.
            Can you tell me which file or parameters probably need to be adjusted?
            yawnsY 1 Reply Last reply Reply Quote 0
            • yawnsY Offline
              yawns Moderator @Michii_M
              @Michii_M
              maybe you could explain that a bit more. What is not working any more? Do you have any error messages? Did you log an issue on github with the developer @mochman ?
                Michii_M @yawns
                @yawns
                @mochman said that he did not develop the module any more. Probably the error messages come by updates from the PI and MM. The error messages I can upload later after the work.
                From GitHub I have unfortunately no idea at all about the errors, how does it work?
                • yawnsY Offline
                  @Michii_M
                  On github you can log issues (problems you might have found): https://github.com/mochman/MMM-Swipe/issues
                  However if mochman is not continuing development of this module then it is not really helpful to log the issue any way. Let’s wait for your error logs and maybe we can find another developer who could jump in
                    Michii_M @yawns
                    @yawns
                    pi@raspberrypi:~/MagicMirror/modules/MMM-swipe $ npm install
                    > MMM-Swipe@1.1.1 postinstall /home/pi/MagicMirror/modules/MMM-swipe
                    > electron-rebuild -e ../../node_modules/electron-prebuilt
                    An unhandled error occurred inside electron-rebuild
                    Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                    Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                        at _callee$ (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/electron-rebuild/lib/cli.js:74:17)
                        at tryCatch (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                        at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                        at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                        at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/bluebird/js/release/util.js:16:23)
                        at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/bluebird/js/release/generators.js:97:49)
                        at /home/pi/MagicMirror/modules/MMM-swipe/node_modules/bluebird/js/release/generators.js:201:15
                        at Object. (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/electron-rebuild/lib/cli.js:197:4)
                        at Module._compile (module.js:570:32)
                        at Object.Module._extensions..js (module.js:579:10)
                        at Module.load (module.js:487:32)
                        at tryModuleLoad (module.js:446:12)
                        at Function.Module._load (module.js:438:3)
                        at Module.runMain (module.js:604:10)
                        at run (bootstrap_node.js:393:7)
                        at startup (bootstrap_node.js:150:9)
                    npm ERR! Linux 4.4.50-v7+
                    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                    npm ERR! node v6.10.1
                    npm ERR! npm  v3.10.10
                    npm ERR! code ELIFECYCLE
                    npm ERR! MMM-Swipe@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
                    npm ERR! Exit status 255
                    npm ERR!
                    npm ERR! Failed at the MMM-Swipe@1.1.1 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
                    npm ERR! If you do, this is most likely a problem with the MMM-Swipe package,
                    npm ERR! not with npm itself.
                    npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                    npm ERR!     npm bugs MMM-Swipe
                    npm ERR! Or if that isn't available, you can get their info via:
                    npm ERR!     npm owner ls MMM-Swipe
                    npm ERR!     /home/pi/MagicMirror/modules/MMM-swipe/npm-debug.log
                    • T Offline
                      trisfoz
                      Hello everybody,
                      After installing the module, when I run it as sudo. I get an error message :
                      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 48, got 53.
                      Loading module helpers ...
                          at Error (native)
                          at Object.Module._extensions..node (module.js:597:18)
                          at Module.require (module.js:497:17)
                          at require (internal/module.js:20:19)
                          at Object. (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/lib/usonic.js:5:14)
                      (node:2253) DeprecationWarning: sys is deprecated. Use util instead.
                      Does anyone know how I can get this module to work?
                      Thank you.
                      • T Offline
                        trisfoz
                        Hi eveerbody,
                        Got magic mirror to boot up but with a new error with the MMM-Swipe module
                        Error: please call `usonic.init()` first
                            at Object.createSensor (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/lib/usonic.js:57:15)
                            at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Swipe/node_helper.js:48:29)
                            at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:103:10)
                            at Socket.emit (events.js:191:7)
                            at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:503:12
                            at _combinedTickCallback (internal/process/next_tick.js:73:7)
                            at process._tickCallback (internal/process/next_tick.js:104:9)
                        Thanks for any help given.
                        • 4 / 5
