    MMM-Swipe - Hand gestures
    45 Posts 17 Posters 50.0k Views 16 Watching
      BeLuGe
      @bob123bob I use Raspbian Jessie last version, Nodejs 6.5.0.
      I have test it with Nodejs 5.11.1, the same issue.
      I run MM without sudo.
        mochman Module Developer
        I’m running:
        RasPi 3 with Jessie
        NodeJs 6.7.0
        Fully updated with
        sudo apt-get update
        sudo apt-get dist-upgrade
        sudo rpi-update
        I just removed the entire MMM-Swipe Folder
        cd ~/MagicMirror/modules/
        git clone https://github.com/mochman/MMM-Swipe
        cd MMM-Swipe/
        npm install
        cd ~/MagicMirror/
        sudo npm start
        I don’t get any of those errors. I don’t know what module version 49 is?
          Jopyth Moderator @mochman
          @mochman Similar issue here. They changed the package.json to fix it. Seems to be a problem with a new Electron version.
          You would only get this error if you newly install Magic Mirror (npm install in the MagicMirror folder gets the new package, if you want to reproduce it).
          Helpful sticky: How to troubleshoot
            @Jopyth Thanks! I was able to reproduce the error. I updated the package.json file and it runs correctly.
              DirkS
              Did you try to use the HR-SR04 behind the mirror glas? I would like to use it like that but don’t know if the ultrasonic sensor will work behind the glas.
                No, I have some speakers behind some speaker mesh. I put the sensors behind the mesh.
                  DirkS
                  Ok thanks for the info. I will try it.
                    Blamer
                    I have just installed the MMM-Swipe module and wired up the sensors to the Raspberry for tests. Right now I still do not understand how this modul communicates with the other Magic Mirror modules. How do I have to config e.g. the calender module or the clock module to swipe left or right? Or does it just work with special modules?
                    That´s the only information I found on Github:
                    This module will use the sendNotification(notification, payload) to send:
                    notification = ‘MOVEMENT’
                    payload = ‘Swipe Left’, ‘Swipe Right’, or ‘Press’
                    Please use as appropriate in your module using notificationReceived(notification, payload, sender)
                      @Blamer Yeah, this isn’t created with a certain module in mind. It sends that notification so you can use it in a module you create if you want. I haven’t been really using this too much after I made it so I don’t have any other modules that would utilize the notifications.
                        bibi
                        hi @mochman - i don’t really get what is the use of your module… could you please give me some use case pls? thx a lot
                        • SnilleS Offline
                          Snille Module Developer
                          Hi, I’m trying out your module.
                          I’m not running the Mirror with sudo, is there no other way to get your module to work?
                          I’m getting this:
                          { Error: EACCES, Permission denied
                              at Error (native)
                              at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-gpio/lib/gpio.js:32:18
                              at ChildProcess.exithandler (child_process.js:209:7)
                              at emitTwo (events.js:106:13)
                              at ChildProcess.emit (events.js:191:7)
                              at maybeClose (internal/child_process.js:877:16)
                              at Socket. (internal/child_process.js:334:11)
                              at emitOne (events.js:96:13)
                              at Socket.emit (events.js:188:7)
                              at Pipe._handle.close [as _onclose] (net.js:493:12) errno: 13, code: 'EACCES', syscall: 'init' }
                          I’m guessing it have to do with the mirror not running as root…
                          the pi user is a member of the gpio group at least. :)
                          Thank you.
                          Best regards Snille
                          If you cant find it, make it and share it
                          MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
                            @Snille Yeah, this module requires root access. I haven’t developed it since I first made it so I’m not sure if it still works with all the updates the pi & MM have gotten. Sorry.
                            SnilleS M 2 Replies Last reply Reply Quote 0
                            • SnilleS Offline
                              Snille Module Developer @mochman
                              @mochman No worries, thank you for letting me know. :)
                                Michii_M @mochman
                                @mochman
                                Hey
                                Since this module does not work anymore, I would like to try to get it running again.
                                Can you tell me which file or parameters probably need to be adjusted?
                                • Y Offline
                                  yawns Moderator @Michii_M
                                  @Michii_M
                                  maybe you could explain that a bit more. What is not working any more? Do you have any error messages? Did you log an issue on github with the developer @mochman ?
                                    Michii_M @yawns
                                    @yawns
                                    @mochman said that he did not develop the module any more. Probably the error messages come by updates from the PI and MM. The error messages I can upload later after the work.
                                    From GitHub I have unfortunately no idea at all about the errors, how does it work?
                                    • Y Offline
                                      @Michii_M
                                      On github you can log issues (problems you might have found): https://github.com/mochman/MMM-Swipe/issues
                                      However if mochman is not continuing development of this module then it is not really helpful to log the issue any way. Let’s wait for your error logs and maybe we can find another developer who could jump in
                                        Michii_M @yawns
                                        @yawns
                                        pi@raspberrypi:~/MagicMirror/modules/MMM-swipe $ npm install
                                        > MMM-Swipe@1.1.1 postinstall /home/pi/MagicMirror/modules/MMM-swipe
                                        > electron-rebuild -e ../../node_modules/electron-prebuilt
                                        An unhandled error occurred inside electron-rebuild
                                        Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                                        Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                                            at _callee$ (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/electron-rebuild/lib/cli.js:74:17)
                                            at tryCatch (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                                            at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                                            at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                                            at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/bluebird/js/release/util.js:16:23)
                                            at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/bluebird/js/release/generators.js:97:49)
                                            at /home/pi/MagicMirror/modules/MMM-swipe/node_modules/bluebird/js/release/generators.js:201:15
                                            at Object. (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/electron-rebuild/lib/cli.js:197:4)
                                            at Module._compile (module.js:570:32)
                                            at Object.Module._extensions..js (module.js:579:10)
                                            at Module.load (module.js:487:32)
                                            at tryModuleLoad (module.js:446:12)
                                            at Function.Module._load (module.js:438:3)
                                            at Module.runMain (module.js:604:10)
                                            at run (bootstrap_node.js:393:7)
                                            at startup (bootstrap_node.js:150:9)
                                        npm ERR! Linux 4.4.50-v7+
                                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                                        npm ERR! node v6.10.1
                                        npm ERR! npm  v3.10.10
                                        npm ERR! code ELIFECYCLE
                                        npm ERR! MMM-Swipe@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
                                        npm ERR! Exit status 255
                                        npm ERR!
                                        npm ERR! Failed at the MMM-Swipe@1.1.1 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
                                        npm ERR! If you do, this is most likely a problem with the MMM-Swipe package,
                                        npm ERR! not with npm itself.
                                        npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                                        npm ERR!     npm bugs MMM-Swipe
                                        npm ERR! Or if that isn't available, you can get their info via:
                                        npm ERR!     npm owner ls MMM-Swipe
                                        npm ERR!     /home/pi/MagicMirror/modules/MMM-swipe/npm-debug.log
                                        • T Offline
                                          trisfoz
                                          Hello everybody,
                                          After installing the module, when I run it as sudo. I get an error message :
                                          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 48, got 53.
                                          Loading module helpers ...
                                              at Error (native)
                                              at Object.Module._extensions..node (module.js:597:18)
                                              at Module.require (module.js:497:17)
                                              at require (internal/module.js:20:19)
                                              at Object. (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/lib/usonic.js:5:14)
                                          (node:2253) DeprecationWarning: sys is deprecated. Use util instead.
                                          Does anyone know how I can get this module to work?
                                          Thank you.
                                          • T Offline
                                            trisfoz
                                            Hi eveerbody,
                                            Got magic mirror to boot up but with a new error with the MMM-Swipe module
                                            Error: please call `usonic.init()` first
                                                at Object.createSensor (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/lib/usonic.js:57:15)
                                                at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Swipe/node_helper.js:48:29)
                                                at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:103:10)
                                                at Socket.emit (events.js:191:7)
                                                at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:503:12
                                                at _combinedTickCallback (internal/process/next_tick.js:73:7)
                                                at process._tickCallback (internal/process/next_tick.js:104:9)
                                            Thanks for any help given.
                                            • 2 / 3
