    MMM-Swipe - Hand gestures
    45 Posts 17 Posters 46.7k Views 16 Watching
    • mochmanM Offline
      mochman Module Developer
      No, I have some speakers behind some speaker mesh. I put the sensors behind the mesh.
        DirkS
        Ok thanks for the info. I will try it.
          Blamer
          I have just installed the MMM-Swipe module and wired up the sensors to the Raspberry for tests. Right now I still do not understand how this modul communicates with the other Magic Mirror modules. How do I have to config e.g. the calender module or the clock module to swipe left or right? Or does it just work with special modules?
          That´s the only information I found on Github:
          This module will use the sendNotification(notification, payload) to send:
          notification = ‘MOVEMENT’
          payload = ‘Swipe Left’, ‘Swipe Right’, or ‘Press’
          Please use as appropriate in your module using notificationReceived(notification, payload, sender)
          • mochmanM Offline
            @Blamer Yeah, this isn’t created with a certain module in mind. It sends that notification so you can use it in a module you create if you want. I haven’t been really using this too much after I made it so I don’t have any other modules that would utilize the notifications.
              bibi
              hi @mochman - i don’t really get what is the use of your module… could you please give me some use case pls? thx a lot
              • SnilleS Offline
                Snille Module Developer
                Hi, I’m trying out your module.
                I’m not running the Mirror with sudo, is there no other way to get your module to work?
                I’m getting this:
                { Error: EACCES, Permission denied
                    at Error (native)
                    at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-gpio/lib/gpio.js:32:18
                    at ChildProcess.exithandler (child_process.js:209:7)
                    at emitTwo (events.js:106:13)
                    at ChildProcess.emit (events.js:191:7)
                    at maybeClose (internal/child_process.js:877:16)
                    at Socket. (internal/child_process.js:334:11)
                    at emitOne (events.js:96:13)
                    at Socket.emit (events.js:188:7)
                    at Pipe._handle.close [as _onclose] (net.js:493:12) errno: 13, code: 'EACCES', syscall: 'init' }
                I’m guessing it have to do with the mirror not running as root…
                the pi user is a member of the gpio group at least. :)
                Thank you.
                Best regards Snille
                If you cant find it, make it and share it!
                Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                • mochmanM Offline
                  @Snille Yeah, this module requires root access. I haven’t developed it since I first made it so I’m not sure if it still works with all the updates the pi & MM have gotten. Sorry.
                  SnilleS M 2 Replies Last reply Reply Quote 0
                  • SnilleS Offline
                    Snille Module Developer @mochman
                    @mochman No worries, thank you for letting me know. :)
                      Michii_M @mochman
                      @mochman
                      Hey
                      Since this module does not work anymore, I would like to try to get it running again.
                      Can you tell me which file or parameters probably need to be adjusted?
                      • yawnsY Offline
                        yawns Moderator @Michii_M
                        @Michii_M
                        maybe you could explain that a bit more. What is not working any more? Do you have any error messages? Did you log an issue on github with the developer @mochman ?
                        • 3 / 5
