    How to Troubleshoot
    12 Posts 10 Posters 49.9k Views 9 Watching
      Bangee Module Developer
      Hey there beginners like me :-)
      I would like to show you, where and how to find errors while installing, using or developing MagicMirror 2.
      What we need:
      MagicMirror2 from github -> https://github.com/MichMich/MagicMirror installed on a Raspberry Pi.
      Try to use the automatic install as described in the Readme.md.
      A really good tool to see whats going on behind your MM2 is Firebug -> http://getfirebug.com/
      If you run you MM2 as node serveronly you will have a lot of informations.
      Connect to your Raspberry using Putty -> http://www.putty.org/
      Username: pi
      Password: raspberry
      1. Start StandaloneServer: node serveronly
      2. open your FirefoxBrowser http://192.168.0.150:8080 (replace your Raspy’s IP adresse)
      3. Press F12 to start Firebug
      If you are using PM2 you will get informations running these command:
      pm2 info mm (replace mm whit your App Name)
      Output:
      pi@raspberrypi:~ $ pm2 info mm
       Describing process with id 0 - name mm
      │ status            │ online                            │
      │ name              │ mm                                │
      │ restarts          │ 5                                 │
      │ uptime            │ 3h                                │
      │ script path       │ /home/pi/mm.sh                    │
      │ script args       │ N/A                               │
      │ error log path    │ /home/pi/.pm2/logs/mm-error-0.log │
      │ out log path      │ /home/pi/.pm2/logs/mm-out-0.log   │
      │ pid path          │ /home/pi/.pm2/pids/mm-0.pid       │
      │ interpreter       │ bash                              │
      │ interpreter args  │ N/A                               │
      │ script id         │ 0                                 │
      │ exec cwd          │ /home/pi                          │
      │ exec mode         │ fork_mode                         │
      │ node.js version   │ N/A                               │
      │ watch & reload    │ ✘                                 │
      │ unstable restarts │ 0                                 │
      │ created at        │ 2016-05-13T08:30:59.308Z          │
       Add your own code metrics: http://bit.ly/code-metrics
       Use `pm2 logs mm (--lines 1000)` to display logs
       Use `pm2 monit` to monitor CPU and Memory usage mm
      Here you’ll find again a lot of informations where to find your error_log or your out_log.
      If you create a console.log("something"); debug message or output you’ll be able to see this info using the following command:
      tail -f /home/pi/.pm2/logs/mm-out-0.log (replace the path with your paht to log or error file)
      This will be continued…
      so long Bangee…
      P 1 Reply Last reply Reply Quote 2
      • MichMichM Offline
        MichMich
        Nice work! Feel free to add this to the wiki! :)
        • P Offline
          paviro @Bangee
          You could also use pm2 logs mm to get the logs! A bit easier than remembering the file path :)
          If you have any problems regarding a black screen, always make sure to use jslint.com to validate your config.js (just paste its content into the website). You can of course also use firebug as stated above.
          – The Doctor
          • Z Offline
            ZTA0796
            If I am debugging code I am writing, is the easiest way to:
            -save the module.js files
            -run “pm2 restart mm”
            -run “pm2 logs mm”
            Or is there a different command that will update the code and how the system in running on the fly without having to restart the mirror each time?
            Thanks!
              you can test your software in a browser using the webserver:
              http://mirror_ip_adress:8080
              install in firefox a tool called Firebug https://addons.mozilla.org/de/firefox/addon/firebug/
              it will show you errors on the fly.
              Changes in node_helper.js requires a restart of your mirror software.
                alberttwong
                Is there a way to see the log via a module?
                • L Offline
                  Lexingtonian
                  One command that has been a lifesaver for me when I’ve munged up the config.js is: “npm run config:check”. The key is to be in the MagicMirror directory when you run it. It’ll check out your config.js and is much more convenient than pasting into jslint.com.
                  For example here is one instance when I had multiple issues and even left the letter “v” at the bottom of my config.js file (on line 255). I would have never found that…The symptom was some modules would load and other would just say “loading” perpetually.
                  pi@raspberrypi:~/MagicMirror $ npm run config:check
                  magicmirror@2.1.3 config:check /home/pi/MagicMirror
                  node tests/configs/check_config.js
                  Checking file… /home/pi/MagicMirror/config/config.js
                  Line 201 col 24 Duplicate key ‘classes’.
                  Line 223 col 20 Duplicate key ‘classes’.
                  Line 255 col 1 Expected an assignment or function call and instead saw an expression.
                  Line 255 col 2 Missing semicolon.
                  E 1 Reply Last reply Reply Quote 3
                  • E Offline
                    E3V3A @Lexingtonian
                    @Lexingtonian Thank you for that tip with npm run config:check. Should be in the dev docs…
                    “Everything I do (here) is for free – altruism is the way!”
                    MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
                      https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
                      • E Offline
                        E3V3A
                        While trying to debug modules, I’ve been given quite mixed feedback regarding what to use to print messages to console, on either local system or in remote browser DevTools.
                        So far, I have found the only reliable way that always seem to print something in the browser, is using console.error(). The others have varied. I’m on MM v2.2.2 (master).
                          BiaGen @E3V3A
                          I was pulling my hair out trying to figure out why my modules weren’t loading. The npm run config:check tip is a total lifesaver - found a missing comma in two seconds.
                            sdetweil @BiaGen
                            @BiaGen the latest 2 releases run config check as part of startup, and fail if there is an error like that
                            I always recommend using manual start whenever changing config, for this very purpose
                            Stop pm2 mgmt if managing the app
                            Then
                            cd ~/MagicMirror
                            npm start
                            If any problems they are right there
                            Once good, ctrl-q MagicMirror
                            And then use pm2 to launch
