    MMM-Swipe - Hand gestures
    45 Posts 17 Posters 51.8k Views 16 Watching
      BeLuGe
      @mochman I have delete the directory and install the packages with npm install
      And I have reinstall the complete Raspberry and install only your module.
      The error is still there
      • mochmanM
        mochman Module Developer
        I can’t help you then. That was my last option. I don’t receive that error nor do I know what that error means.
          bob123bob
          @mochman and @BeLuGe can you tell us what are the versions you are using :
          Raspbian Jessie or Wheezy, which version of nodes, npm … ?
          From where are you running npm start (local, ssh) using sudo or not ?
          I have the same issue as @BeLuGe and I would like to debug/understand what’s is the problem.
          I already red it could be a nodejs version issue (compiling vs running version)
          So guys tell us what are your configuration
          Here is mine :
          Rpi 3 updated firmware with rpi-update
          Raspbian Jessie last version (apt-get update && upgrade && dist-upgrade)
          Nodejs last version 6.5.0 ARM version (not sure if it’s 64 bit or 32 bit) from https://nodejs.org
          Then install of MM and packages
          MM is working fine until I add MMM-Swipe module configuration then got same error message about
          Error: Module version mismatch. Expected 49, got 48.
          Hope we will find the solution …
            BeLuGe
            @bob123bob I use Raspbian Jessie last version, Nodejs 6.5.0.
            I have test it with Nodejs 5.11.1, the same issue.
            I run MM without sudo.
            • mochmanM
              I’m running:
              RasPi 3 with Jessie
              NodeJs 6.7.0
              Fully updated with
              sudo apt-get update
              sudo apt-get dist-upgrade
              sudo rpi-update
              I just removed the entire MMM-Swipe Folder
              cd ~/MagicMirror/modules/
              git clone https://github.com/mochman/MMM-Swipe
              cd MMM-Swipe/
              npm install
              cd ~/MagicMirror/
              sudo npm start
              I don’t get any of those errors. I don’t know what module version 49 is?
              J 1 Reply Last reply
                Jopyth Moderator @mochman
                @mochman Similar issue here. They changed the package.json to fix it. Seems to be a problem with a new Electron version.
                You would only get this error if you newly install Magic Mirror (npm install in the MagicMirror folder gets the new package, if you want to reproduce it).
                • mochmanM
                  @Jopyth Thanks! I was able to reproduce the error. I updated the package.json file and it runs correctly.
                    DirkS
                    Did you try to use the HR-SR04 behind the mirror glas? I would like to use it like that but don’t know if the ultrasonic sensor will work behind the glas.
                    • mochmanM
                      No, I have some speakers behind some speaker mesh. I put the sensors behind the mesh.
                        DirkS
                        Ok thanks for the info. I will try it.
                          Blamer
                          I have just installed the MMM-Swipe module and wired up the sensors to the Raspberry for tests. Right now I still do not understand how this modul communicates with the other Magic Mirror modules. How do I have to config e.g. the calender module or the clock module to swipe left or right? Or does it just work with special modules?
                          That´s the only information I found on Github:
                          This module will use the sendNotification(notification, payload) to send:
                          notification = ‘MOVEMENT’
                          payload = ‘Swipe Left’, ‘Swipe Right’, or ‘Press’
                          Please use as appropriate in your module using notificationReceived(notification, payload, sender)
                          • mochmanM
                            @Blamer Yeah, this isn’t created with a certain module in mind. It sends that notification so you can use it in a module you create if you want. I haven’t been really using this too much after I made it so I don’t have any other modules that would utilize the notifications.
                              bibi
                              hi @mochman - i don’t really get what is the use of your module… could you please give me some use case pls? thx a lot
                              • SnilleS
                                Snille Module Developer
                                Hi, I’m trying out your module.
                                I’m not running the Mirror with sudo, is there no other way to get your module to work?
                                I’m getting this:
                                { Error: EACCES, Permission denied
                                    at Error (native)
                                    at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-gpio/lib/gpio.js:32:18
                                    at ChildProcess.exithandler (child_process.js:209:7)
                                    at emitTwo (events.js:106:13)
                                    at ChildProcess.emit (events.js:191:7)
                                    at maybeClose (internal/child_process.js:877:16)
                                    at Socket. (internal/child_process.js:334:11)
                                    at emitOne (events.js:96:13)
                                    at Socket.emit (events.js:188:7)
                                    at Pipe._handle.close [as _onclose] (net.js:493:12) errno: 13, code: 'EACCES', syscall: 'init' }
                                I’m guessing it have to do with the mirror not running as root…
                                the pi user is a member of the gpio group at least. :)
                                Thank you.
                                Best regards Snille
                                • mochmanM
                                  @Snille Yeah, this module requires root access. I haven’t developed it since I first made it so I’m not sure if it still works with all the updates the pi & MM have gotten. Sorry.
                                  SnilleS M 2 Replies Last reply
                                  • SnilleS
                                    Snille Module Developer @mochman
                                    @mochman No worries, thank you for letting me know. :)
                                      Michii_M @mochman
                                      @mochman
                                      Hey
                                      Since this module does not work anymore, I would like to try to get it running again.
                                      Can you tell me which file or parameters probably need to be adjusted?
                                      yawnsY 1 Reply Last reply
                                      • yawnsY
                                        yawns Moderator @Michii_M
                                        @Michii_M
                                        maybe you could explain that a bit more. What is not working any more? Do you have any error messages? Did you log an issue on github with the developer @mochman ?
                                        M 1 Reply Last reply
                                          Michii_M @yawns
                                          @yawns
                                          @mochman said that he did not develop the module any more. Probably the error messages come by updates from the PI and MM. The error messages I can upload later after the work.
                                          From GitHub I have unfortunately no idea at all about the errors, how does it work?
                                          • yawnsY
                                            @Michii_M
                                            On github you can log issues (problems you might have found): https://github.com/mochman/MMM-Swipe/issues
                                            However if mochman is not continuing development of this module then it is not really helpful to log the issue any way. Let’s wait for your error logs and maybe we can find another developer who could jump in
                                            • 2 / 3
