    MMM-Swipe - Hand gestures
    45 Posts 17 Posters 50.6k Views 16 Watching
      mochman Module Developer
      No, I have some speakers behind some speaker mesh. I put the sensors behind the mesh.
        DirkS
        Ok thanks for the info. I will try it.
          Blamer
          I have just installed the MMM-Swipe module and wired up the sensors to the Raspberry for tests. Right now I still do not understand how this modul communicates with the other Magic Mirror modules. How do I have to config e.g. the calender module or the clock module to swipe left or right? Or does it just work with special modules?
          That´s the only information I found on Github:
          This module will use the sendNotification(notification, payload) to send:
          notification = ‘MOVEMENT’
          payload = ‘Swipe Left’, ‘Swipe Right’, or ‘Press’
          Please use as appropriate in your module using notificationReceived(notification, payload, sender)
            @Blamer Yeah, this isn’t created with a certain module in mind. It sends that notification so you can use it in a module you create if you want. I haven’t been really using this too much after I made it so I don’t have any other modules that would utilize the notifications.
              bibi
              hi @mochman - i don’t really get what is the use of your module… could you please give me some use case pls? thx a lot
              • SnilleS Offline
                Snille Module Developer
                Hi, I’m trying out your module.
                I’m not running the Mirror with sudo, is there no other way to get your module to work?
                I’m getting this:
                { Error: EACCES, Permission denied
                    at Error (native)
                    at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-gpio/lib/gpio.js:32:18
                    at ChildProcess.exithandler (child_process.js:209:7)
                    at emitTwo (events.js:106:13)
                    at ChildProcess.emit (events.js:191:7)
                    at maybeClose (internal/child_process.js:877:16)
                    at Socket. (internal/child_process.js:334:11)
                    at emitOne (events.js:96:13)
                    at Socket.emit (events.js:188:7)
                    at Pipe._handle.close [as _onclose] (net.js:493:12) errno: 13, code: 'EACCES', syscall: 'init' }
                I’m guessing it have to do with the mirror not running as root…
                the pi user is a member of the gpio group at least. :)
                Thank you.
                Best regards Snille
                  @Snille Yeah, this module requires root access. I haven’t developed it since I first made it so I’m not sure if it still works with all the updates the pi & MM have gotten. Sorry.
                  SnilleS M 2 Replies Last reply Reply Quote 0
                  • SnilleS Offline
                    Snille Module Developer @mochman
                    @mochman No worries, thank you for letting me know. :)
                      Michii_M @mochman
                      @mochman
                      Hey
                      Since this module does not work anymore, I would like to try to get it running again.
                      Can you tell me which file or parameters probably need to be adjusted?
                      • Y Offline
                        yawns Moderator @Michii_M
                        @Michii_M
                        maybe you could explain that a bit more. What is not working any more? Do you have any error messages? Did you log an issue on github with the developer @mochman ?
                          Michii_M @yawns
                          @yawns
                          @mochman said that he did not develop the module any more. Probably the error messages come by updates from the PI and MM. The error messages I can upload later after the work.
                          From GitHub I have unfortunately no idea at all about the errors, how does it work?
                          • Y Offline
                            @Michii_M
                            On github you can log issues (problems you might have found): https://github.com/mochman/MMM-Swipe/issues
                            However if mochman is not continuing development of this module then it is not really helpful to log the issue any way. Let’s wait for your error logs and maybe we can find another developer who could jump in
                              Michii_M @yawns
                              @yawns
                              pi@raspberrypi:~/MagicMirror/modules/MMM-swipe $ npm install
                              > MMM-Swipe@1.1.1 postinstall /home/pi/MagicMirror/modules/MMM-swipe
                              > electron-rebuild -e ../../node_modules/electron-prebuilt
                              An unhandled error occurred inside electron-rebuild
                              Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                              Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                                  at _callee$ (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/electron-rebuild/lib/cli.js:74:17)
                                  at tryCatch (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                                  at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                                  at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                                  at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/bluebird/js/release/util.js:16:23)
                                  at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/bluebird/js/release/generators.js:97:49)
                                  at /home/pi/MagicMirror/modules/MMM-swipe/node_modules/bluebird/js/release/generators.js:201:15
                                  at Object. (/home/pi/MagicMirror/modules/MMM-swipe/node_modules/electron-rebuild/lib/cli.js:197:4)
                                  at Module._compile (module.js:570:32)
                                  at Object.Module._extensions..js (module.js:579:10)
                                  at Module.load (module.js:487:32)
                                  at tryModuleLoad (module.js:446:12)
                                  at Function.Module._load (module.js:438:3)
                                  at Module.runMain (module.js:604:10)
                                  at run (bootstrap_node.js:393:7)
                                  at startup (bootstrap_node.js:150:9)
                              npm ERR! Linux 4.4.50-v7+
                              npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                              npm ERR! node v6.10.1
                              npm ERR! npm  v3.10.10
                              npm ERR! code ELIFECYCLE
                              npm ERR! MMM-Swipe@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
                              npm ERR! Exit status 255
                              npm ERR!
                              npm ERR! Failed at the MMM-Swipe@1.1.1 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
                              npm ERR! If you do, this is most likely a problem with the MMM-Swipe package,
                              npm ERR! not with npm itself.
                              npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                              npm ERR!     npm bugs MMM-Swipe
                              npm ERR! Or if that isn't available, you can get their info via:
                              npm ERR!     npm owner ls MMM-Swipe
                              npm ERR!     /home/pi/MagicMirror/modules/MMM-swipe/npm-debug.log
                              • T Offline
                                trisfoz
                                Hello everybody,
                                After installing the module, when I run it as sudo. I get an error message :
                                WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 48, got 53.
                                Loading module helpers ...
                                    at Error (native)
                                    at Object.Module._extensions..node (module.js:597:18)
                                    at Module.require (module.js:497:17)
                                    at require (internal/module.js:20:19)
                                    at Object. (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/lib/usonic.js:5:14)
                                (node:2253) DeprecationWarning: sys is deprecated. Use util instead.
                                Does anyone know how I can get this module to work?
                                Thank you.
                                • T Offline
                                  trisfoz
                                  Hi eveerbody,
                                  Got magic mirror to boot up but with a new error with the MMM-Swipe module
                                  Error: please call `usonic.init()` first
                                      at Object.createSensor (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/lib/usonic.js:57:15)
                                      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Swipe/node_helper.js:48:29)
                                      at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:103:10)
                                      at Socket.emit (events.js:191:7)
                                      at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:503:12
                                      at _combinedTickCallback (internal/process/next_tick.js:73:7)
                                      at process._tickCallback (internal/process/next_tick.js:104:9)
                                  Thanks for any help given.
                                    A Former User
                                    @trisfoz
                                    Hi, i don’t know if you are still trying but i had the same problem. I fixed it by adjusting the usonic.js file. If you check the git page of this project you can find a recent bugfix for the BCM2835.
                                    } else if (hardware === 'BCM2709') {
                                    chagned to
                                    } else if (hardware === 'BCM2709' || hardware === 'BCM2835') {
                                    Applying this fix brought me one step further.
                                    But now i’m stuck at starting MagicMirror as sudo.
                                    • T Offline
                                      trisfoz @Guest
                                      @Melnem
                                      Hi, thanks for your message. It fixed my problem.
                                      I do not know if you have managed to run in sudo at startup but I use PM2.
                                      In the start script :
                                      cd ~
                                      nano mm.sh
                                      In mm.sh I put
                                      DISPLAY=:0 sudo npm start
                                      and it seems to work fine.
                                      Thanks again for all your help !
                                        shbatm Module Developer
                                        To anyone still looking to continue development of this module or to adjust it so the Mirror does not need to be run as sudo: I started work on a fork to change to using the onoff node module which doesn’t require sudo.
                                        The new version is about 90% there and just needs some additional testing to make sure everything works as intended. Unfortunately, after I put the effort into re-writing a lot of the code, I realized that the sensors and my dog do not get along so I need to try something else.
                                        I’m putting the code out there in case anyone is interested in taking it any further… there are some development notes on the readme page to explain some of the differences in the two versions.
                                        Thank you to @mochman for the original development and inspiration.
                                        [card:shbatm/MMM-Swipe]
                                          StefanMe
                                          Hi!
                                          i rebuild all these fantastic stuff and installed the MMM-Swipe (Original from @mochman ) and now its starting fine ect.
                                          I can also see the two different sensors in the calibration mode detecting my hand act , but i can’t get any response in the verbose mode… it only shows me WAITING FOR MOVEMENT. Not more… is there any way to get more information for debugging?
                                            djtale
                                            Hello !
                                            I have ordered my HC-SR04 and I’m trying to understand how to setup this module.
                                            I have understand to setup of the GPIO but I don’t understand the notification stuff.
                                            Let’ say on first page I have those modules :
                                            “compliments”,“weatherforecast”,“newsfeed”,“MMM-SingleStock”
                                            And on second page, I want to have “MMM-CalendarExt”
                                            Where should I code the notification ?
                                            If someone can share a simple code to explain how we can switch from page 1 to page 2, I would highly appreciate.
                                            Thanks.
                                            • 2 / 3
