    (Solved) PM2 does not start on reboot
    15 Posts 4 Posters 14.3k Views 6 Watching
    • X Offline
      xbmcnut @amanzimdwini
      @amanzimdwini I have resolved it now as I posted a bug. Turns out it’s related to the timeout setting for the PM2 service. Developers are going to remove timeout in next release but for now it can be tweaked. And no, had no joy with screensaver either. Disabled it in GUI and it seems to be gone now.
      https://github.com/Unitech/pm2/issues/2765#issuecomment-286778941
        amanzimdwini @xbmcnut
        @xbmcnut Just read your post - now MY installation wont run PM2. Argh. Where do you change the timeout settings?
        ps - Re: screensaver: I had to resort to’
        sudo apt-get install xscreensaver
        and the disable it.
        X 1 Reply Last reply Reply Quote 0
        • X Offline
          @amanzimdwini said in (Solved) PM2 does not start on reboot:
          /etc/systemd/system/pm2-root.service
          I changed mine from 8 to 15s using WinSCP with the SCP/Shell set to sudo su -
          A R 2 Replies Last reply Reply Quote 0
            @xbmcnut took me a good 10 seconds to find pm2-pi.service for the raspberry
            And another 5 to change it.
            YOU ARE A GENIUS!
            thanks
              rmohsen @xbmcnut
              @xbmcnut Hello
              total noob here and i have the same problem , how do i do that ?
              ps : i’m not a developer or anything , i’m just a regular user so i kinda need step by step
              thanks
              • X Offline
                xbmcnut @rmohsen
                @rmohsen Do you know how to access your mirror with either PuTTy or WinSCP?
                  rmohsen @xbmcnut
                  @xbmcnut yes. Tried winscp but couldn’t edit the file , no permission
                  I managed to change it from 8 to 15 with another command on terminal but still not working
                  • X Offline
                    xbmcnut @rmohsen
                    @rmohsen Apologies. My install has died over the weekend and MM will no longer run. Getting to Desktop login screen on reboot and that’s it even though I told it to auto login, the desktop will not start. Have popped in ‘too hard bin’ for the moment, sorry.
                    • Sandy2503S Offline
                      Sandy2503
                      @xbmcnut :abcd:
                      where have you changed the Idle Time ???
                      Thats my pm2-root.service:
                      [Unit]
                      Description=PM2 process manager
                      Documentation=https://pm2.keymetrics.io/
                      After=network.target
                      [Service]
                      Type=forking
                      User=root
                      LimitNOFILE=infinity
                      LimitNPROC=infinity
                      LimitCORE=infinity
                      Environment=PATH=/usr/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                      Environment=PM2_HOME=/root/.pm2
                      PIDFile=/root/.pm2/pm2.pid
                      ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
                      ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
                      ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
                      [Install]
                      WantedBy=multi-user.target
                      Greetz Sandy2503
                      • X Offline
                        xbmcnut @Sandy2503
                        @Sandy2503 I believe in the latest version of PM2, this was removed.
