    (Solved) PM2 does not start on reboot
    15 Posts 4 Posters 15.1k Views 6 Watching
    • X Offline
      xbmcnut
      OK, I started again with a clean install of the full Jessie build now then leaned it out using this guide. As before, once I start going through with the PM2 stuff, everything seems to work OK until a reboot and MM does not start. Surely someone else has seen this? Am I making a simple NOOB mistake here or does it just not work?
      0_1489547666665_upload-72de88bb-d0f6-46ed-884c-38ce64503343
        amanzimdwini @xbmcnut
        @xbmcnut Hey - I’m not the only one any more… Same problem: used to work on an OLD installation, and now - nothing. I am just working on a brand new one tonight.
        BTW: does you screensaver stay off? I had to work quite a bit at getting that working in the new distro.
        A X 2 Replies Last reply Reply Quote 0
          amanzimdwini @amanzimdwini
          @amanzimdwini @xbmcnut
          Clean installation onto a Pi3 works… (and I have NO idea why it works on this one: my last pi3 gave me the same problem you had). So you might want to look at a different Pi?
          Best of luck!
          • X Offline
            xbmcnut @amanzimdwini
            @amanzimdwini I have resolved it now as I posted a bug. Turns out it’s related to the timeout setting for the PM2 service. Developers are going to remove timeout in next release but for now it can be tweaked. And no, had no joy with screensaver either. Disabled it in GUI and it seems to be gone now.
            https://github.com/Unitech/pm2/issues/2765#issuecomment-286778941
              @xbmcnut Just read your post - now MY installation wont run PM2. Argh. Where do you change the timeout settings?
              ps - Re: screensaver: I had to resort to’
              sudo apt-get install xscreensaver
              and the disable it.
              X 1 Reply Last reply Reply Quote 0
              • X Offline
                @amanzimdwini said in (Solved) PM2 does not start on reboot:
                /etc/systemd/system/pm2-root.service
                I changed mine from 8 to 15s using WinSCP with the SCP/Shell set to sudo su -
                A R 2 Replies Last reply Reply Quote 0
                  @xbmcnut took me a good 10 seconds to find pm2-pi.service for the raspberry
                  And another 5 to change it.
                  YOU ARE A GENIUS!
                  thanks
                    rmohsen @xbmcnut
                    @xbmcnut Hello
                    total noob here and i have the same problem , how do i do that ?
                    ps : i’m not a developer or anything , i’m just a regular user so i kinda need step by step
                    thanks
                    • X Offline
                      xbmcnut @rmohsen
                      @rmohsen Do you know how to access your mirror with either PuTTy or WinSCP?
                        rmohsen @xbmcnut
                        @xbmcnut yes. Tried winscp but couldn’t edit the file , no permission
                        I managed to change it from 8 to 15 with another command on terminal but still not working
                        • X Offline
                          xbmcnut @rmohsen
                          @rmohsen Apologies. My install has died over the weekend and MM will no longer run. Getting to Desktop login screen on reboot and that’s it even though I told it to auto login, the desktop will not start. Have popped in ‘too hard bin’ for the moment, sorry.
                          • Sandy2503S Offline
                            Sandy2503
                            @xbmcnut :abcd:
                            where have you changed the Idle Time ???
                            Thats my pm2-root.service:
                            [Unit]
                            Description=PM2 process manager
                            Documentation=https://pm2.keymetrics.io/
                            After=network.target
                            [Service]
                            Type=forking
                            User=root
                            LimitNOFILE=infinity
                            LimitNPROC=infinity
                            LimitCORE=infinity
                            Environment=PATH=/usr/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                            Environment=PM2_HOME=/root/.pm2
                            PIDFile=/root/.pm2/pm2.pid
                            ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
                            ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
                            ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
                            [Install]
                            WantedBy=multi-user.target
                            Greetz Sandy2503
                            • X Offline
                              xbmcnut @Sandy2503
                              @Sandy2503 I believe in the latest version of PM2, this was removed.
                                Sandy2503
                                today is install a fresh version of raspian pixel on my raspi 2 with the new version (2.1.1) of MagicMirror and the actual version of PM2 (2.4.5)
                                But the autostart function themes not to work and in the pm2-root.service is no part to set the idle time.
                                How can i fix the idle Problem ?
