(Solved) PM2 does not start on reboot
15 Posts 4 Posters 12.7k Views 6 Watching
  • X Offline
    xbmcnut
    Hi there. I have MM running but the auto start feature is not working. See below.
    0_1489442964694_upload-015b7538-a813-476d-936c-8b0cfcc3645a
    PM2 is version 2.4.2 and the MM install was built on Jessie Lite (2017-03-02) on a Pi2. I can start the script with PM2 start mm.sh and use PM2 save when it’s running but PM2 list after a reboot shows nothing running. How do I debug this?
    I noted that when following the auto start instructions, chmod +x mm.sh returned a permissions error. Is that normal? Does that have to be run as sudo? I changed the permissions to the ‘Pi’ user using WinSCP but it made no difference.
    0_1489443276731_upload-dad08d4d-bdc7-4e6a-96ff-a6eef7c12ae5
    • X Offline
      xbmcnut
      OK, I started again with a clean install of the full Jessie build now then leaned it out using this guide. As before, once I start going through with the PM2 stuff, everything seems to work OK until a reboot and MM does not start. Surely someone else has seen this? Am I making a simple NOOB mistake here or does it just not work?
      0_1489547666665_upload-72de88bb-d0f6-46ed-884c-38ce64503343
      A 1 Reply Last reply Mar 16, 2017, 4:05 AM Reply Quote 0
        amanzimdwini @xbmcnut
        @xbmcnut Hey - I’m not the only one any more… Same problem: used to work on an OLD installation, and now - nothing. I am just working on a brand new one tonight.
        BTW: does you screensaver stay off? I had to work quite a bit at getting that working in the new distro.
        A X 2 Replies Last reply Mar 16, 2017, 5:55 AM Reply Quote 0
          amanzimdwini @amanzimdwini
          @amanzimdwini @xbmcnut
          Clean installation onto a Pi3 works… (and I have NO idea why it works on this one: my last pi3 gave me the same problem you had). So you might want to look at a different Pi?
          Best of luck!
          • X Offline
            xbmcnut @amanzimdwini
            @amanzimdwini I have resolved it now as I posted a bug. Turns out it’s related to the timeout setting for the PM2 service. Developers are going to remove timeout in next release but for now it can be tweaked. And no, had no joy with screensaver either. Disabled it in GUI and it seems to be gone now.
            https://github.com/Unitech/pm2/issues/2765#issuecomment-286778941
            A 1 Reply Last reply Mar 16, 2017, 6:25 AM Reply Quote 0
              @xbmcnut Just read your post - now MY installation wont run PM2. Argh. Where do you change the timeout settings?
              ps - Re: screensaver: I had to resort to’
              sudo apt-get install xscreensaver
              and the disable it.
              X 1 Reply Last reply Mar 16, 2017, 6:40 AM Reply Quote 0
              • X Offline
                @amanzimdwini said in (Solved) PM2 does not start on reboot:
                /etc/systemd/system/pm2-root.service
                I changed mine from 8 to 15s using WinSCP with the SCP/Shell set to sudo su -
                A R 2 Replies Last reply Mar 16, 2017, 3:38 PM Reply Quote 0
                  @xbmcnut took me a good 10 seconds to find pm2-pi.service for the raspberry
                  And another 5 to change it.
                  YOU ARE A GENIUS!
                  thanks
                    rmohsen @xbmcnut
                    @xbmcnut Hello
                    total noob here and i have the same problem , how do i do that ?
                    ps : i’m not a developer or anything , i’m just a regular user so i kinda need step by step
                    thanks
                    X 1 Reply Last reply Mar 20, 2017, 10:16 PM Reply Quote 0
                    • X Offline
                      xbmcnut @rmohsen
                      @rmohsen Do you know how to access your mirror with either PuTTy or WinSCP?
                      R 1 Reply Last reply Mar 20, 2017, 10:20 PM Reply Quote 0
