Default Weather module not loading and no error showing.
31 Posts 9 Posters 40.3k Views 8 Watching
    muaystan
    I know this is old but…my weather wasnt loading. I was trying to use the “forecast” option. Figured out (despite what @Mykle1 said above) that it does work with API keys but I needed to changed weatherEndpoint: in the weather.js file
                    apiKey: "YOUR-API-KEY",
                    apiSecret: "",
                    apiVersion: "2.5",
                    apiBase: "https://api.openweathermap.org/data/", // TODO: this should not be part of the weather.js $
                    weatherEndpoint: "/forecast",
    I had it set to forecast in the config/config.js (below) but that wasnt enough. After I changed the weatherEndpoint, it worked. The
                            module: "weather",
                            position: "bottom_right",
                                    type: "forecast"
    Hope this helps someone.
    • 4 / 4
    4 / 4
