    Facial Recognition - customize your mirror for every user!
    215 Posts 55 Posters 506.8k Views 57 Watching
      benkej @YourhighnessLeender
      @YourhighnessLeender unfortunately yes :angry:
      I try to reinstall the whole system
      • Y Offline
        YourhighnessLeender @benkej
        @benkej oke, please update on your progress. Good luck. Im very close to giving up.
        • paviroP Offline
          paviro @PointPubMedia
          @PointPubMedia Well sure but you could also write your own module listening for the notifications from my module :)
          @bhepler said in Facial Recognition - customize your mirror for every user!:
          @YourhighnessLeender Check your capitalization. Your training script output was ‘Johannes’ and your config.js has ‘johannes’.
          This does not make any difference :)
          @benkej said in Facial Recognition - customize your mirror for every user!:
          @YourhighnessLeender only for trial but I changed everything back to the default. I’m using raspberry pi 3 model b, here is part of my config:
          Read 3 positive images and 400 negative images.
          You should definitely use more than 3 pictures! I use around 200 :D
          We're all stories in the end. Just make it a good one, eh?
          – The Doctor
          Y B 2 Replies Last reply Reply Quote 0
          • Y Offline
            YourhighnessLeender @paviro
            @paviro 200 pictures - aha! Maybe my 13 isnt enough. I can’t use the capture script since i’m on webcam so I took em with my phone and transferred them to the pi. I’ll add more and cross my fingers.
            • paviroP Offline
              paviro
              Well that could also be a cause. You should use the same camera for best results!
              Why shouldn’t you be able to use a webcam with the capture script? I never used it with anything else to be honest :D
              – The Doctor
              Y 1 Reply Last reply Reply Quote 1
              • Y Offline
                @paviro hmm. Just can’t get it working for some reason… will try again. It complaind about no picam. Maybe I have to change something in the script? I’ll du another try.
                • paviroP Offline
                  paviro
                  Well the capture script does not have an enforce webcam option. Try to uninstall the picam python module, it will fallback to webcam then.
                  To minimize recognition errors the MagicMirror module requires two identical recognitions to be accepted as current user. If your training data is not good enough it could happen that you are never recognized twice in two directly following images -> Always unknown user.
                  – The Doctor
                  • Y Offline
                    @paviro thanks for the help. How do I uninstall the picam? Is it just to remove picam.py?
                    • paviroP Offline
                      paviro
                      Nooo! Don’t mess with the module code! I just added an option to force webcam use, checkout the updated code on GitHub :)
                      – The Doctor
                      Y 2 Replies Last reply Reply Quote 2
                      • Y Offline
                        @paviro thanks paviro! Will do!
                        • 11
                        • 12
                        • 13
                        • 14
                        • 15
                        • 21
                        • 22
                        • 13 / 22
