    MM_Withings module | Values are not being updated
    1 Posts 1 Posters 918 Views 2 Watching
    • F
      Fab2k
      Hey everyone,
      this is my first post, so hopefully this is the correct category.
      I have an issue with the MM_Withings module from john7002 . Access to the API works fine and I can see the extracted value in the Log.
      But unfortunately the table does not get updated accordingly.
      I am not a JavaScript expert and am kind of desperate.
      I stripped down the original MM_Withings.js to just handle the received weight. I attached the code.
      It would be great, if you could check the code and point me in the right direction.
      Thanks in advance for your efforts.
        // init method
        start: function() {
          this.α = 0;
          // set interval for reload timer
          this.t = this.config.updateInterval * 60 * 1000 / 360;
          this.weight=0;
          Log.info(this.name + " 1st step of execution.");
          this.updateLoad();
        updateLoad: function() {
          Log.info(this.name + "refresh triggered");
          var that = this;
          return Q.fcall(
            this.load.get_URL.bind(that,'weight'),
            Log.info("URL LOADED"),
            this.renderError.bind(that)
          ).then(
              this.extractweight.bind(that), //weight
      	Log.info("WEIGHT EXTRACTED"),
          ).done(
      	this.updateWait.bind(that),
      	Log.info("BIND UPDATE WEIGHT")
        updateWait: function() {
          this.α++;
          this.α %= 360;
          var r = (this.α * Math.PI / 180);
          if (r === 0) {
            // refresh data
            this.updateLoad();
          } else {
            // wait further
            setTimeout(this.updateWait.bind(this), this.t);
        load: {
          get_URL: function(data_type) {
            switch(data_type){
              case 'weight':
                base= this.config.api.base;
                base2=this.config.api.measure_weight;
                end=this.config.api.authPayload_weight;
                break;
              default:
                return '';
              return Q($.ajax({
                type: 'POST',
                url: base+base2,
                data: this.config.api.authPayload.format(
                    this.config.oauth_consumer_key,
                    Array(32+1).join((Math.random().toString(36)+'00000000000000000').slice(2, 18)).slice(0, 32),
                    this.config.oauth_signature)+
                    this.config.api.authPayload2.format(
                    Date.now(),
                    this.config.oauth_token,
                    this.config.api.authPayload3.format(
                    this.config.clientID)+end
        extractweight: function(data) {
          var var2=data;
          var obj = JSON.parse(data);
          Log.info("status=" + obj.status);
          Log.info("time=" +obj.body.measuregrps[0].date);
          this.weight=obj.body.measuregrps[0].measures[0].value*Math.pow(10,obj.body.measuregrps[0].measures[0].unit);
          this.dateweight=obj.body.measuregrps[0].date;
          Log.info("poids=" +this.weight + "; date=" + this.dateweight);
        renderError: function(reason) {
          console.log("error " + reason);
        getScripts: function() {
          return [
            'String.format.js',
            '//cdnjs.cloudflare.com/ajax/libs/jquery/2.2.2/jquery.js',
            'jquery-2.2.2.js',
            'q.min.js',
            'moment.js'
        getDom: function() {
          Log.info("UPDATE WEIGHT: " +this.weight + " DOM");
          return $('<div>' + '<table> <tr><td> Gewicht: ' + this.weight +' kg</td></tr></table></div>')[0];
