    Calendar - not able top open particular Google Calendar
    7 Posts 3 Posters 4.5k Views 3 Watching
    • T Offline
      TmoTmo
      Hello everybody!
      First of all I would like to say Thank you for making this great project possible! It’s really awesome!
      Last week I started to build my own MagicMirror. So far so good, but I have been struggeling with the standard calendar module for two days now and couldn’t find a solution in this forum.
      I’m trying to add two Google Calendars (My personal and the one from my girlfriend). My girlfriends’ Calendar is working like a charm, but if I try it with my own calendar by just swapping the ical-adress, it gets stuck with the loading message. The ical adress should be right, because I am able to open it in my browser. I have already set back my private ical. Settings of both calenders seem to be identical.
      Any ideas what to do?
      Thank you very much for any kind of help!
      • T Offline
        TmoTmo
        I just tried it again and noticed the error message in the terminal. Maybe this helps:
        TypeError: curr.start.toISOString is not a function
            at Object.ical.objectHandlers.END (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:39:40)
            at Object.handleObject (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:257:41)
            at Object.parseICS (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:298:20)
            at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:24)
            at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:188:22)
            at emitTwo (events.js:106:13)
            at Request.emit (events.js:191:7)
            at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1171:10)
            at emitOne (events.js:96:13)
            at Request.emit (events.js:188:7)
        • T Offline
          TmoTmo
          Hello,
          I tried to make it work again today. But unfortunately (and despite the update) it still doesn’t work.
          Anyone an idea? Or should I open an issue?
          Thank you!
              at Object.ical.objectHandlers.END (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:40:40)
              at Object.handleObject (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:267:41)
              at Object.parseICS (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:308:20)
          Create new todo fetcher for list: Einkaufsliste - Interval: 60000
          • T Offline
            TmoTmo
            Interesting thing is:
            When I create a new Test Calendar with the same Google account, the MagicMirror is able to display it without any problems.
            • tgeimerT Offline
              tgeimer
              what version are you using? This might be an issue that came with the update to version 2.1.1, check these threads:
              https://github.com/MichMich/MagicMirror/issues/839
              https://forum.magicmirror.builders/topic/2221/after-upgrade-v2-1-1-multiple-calendars-not-displaying
              https://forum.magicmirror.builders/topic/2208/calendar-shows-no-entries-after-mm-update
              I am experiencing troubles with one of my owncloud calendars.
              • T Offline
                TmoTmo
                Hey,
                haven’t been at home for a while, so sorry for my late answer.
                I’m using v2.1.1. I checked those threads and replaced the ical.js and node.ical.js files, but it’s still the same issue.
                Thank you for your help!
                  smithkdj
                  I’m in the same boat. Some of my calendars will show up but others will not. Any new thoughts?
