    Calendar shows "no entries" after MM Update
    37 Posts 12 Posters 27.3k Views 16 Watching
    • P Offline
      Peter_van_Evert
      Hello everybody,
      the MM works fine, everything was shown and so on. After installing the update 2.1.1 the calender module shows that there were no entries in the calendar, but there are a lot. I controlled the config file - everything ok. I updated the Raspi - the error is already there. Can anyone help me ? The Calendar is very important for me.
      Peter
      • yawnsY Offline
        yawns Moderator
        Did you try to reload your MagicMirror? From time to time I experience the same trouble with an outlook.com calendar. Reloaded the MagicMirror (refreshing the website) - some times several times - resolves this.
        • P Offline
          Peter_van_Evert
          Hello yawns,
          thanks for your fast answer. But I tried several times. Start the Raspi new, start the MM with Control-R , but the error is the same. First it displays “load” over a long time and then it displays “no entries” (Keine Termine - because I’m german).
          • yawnsY Offline
            yawns Moderator
            Ok. Could you try to copy the url of your calendar config and paste it into any browser to see if this loads?
            Did you try to stop the magicmirror process, start it with npm start dev and look for any error entries in console?
            • P Offline
              Peter_van_Evert
              Hello yawns,
              the url is a google calendar ics url and when I paste the url in my browser it load.
              This are the error Messages after i type npm start dev.0_1491207962679_Bildschirmfoto vom 2017-04-03 10-21-56.jpg
              • yawnsY Offline
                yawns Moderator
                you are in the wrong directory, you need to change with cd MagicMirror
                Are you working on your pi? Or are you connected via ssh? If you use ssh then you need to run DISPLAY=:0 npm start dev instead
                • P Offline
                  Peter_van_Evert
                  Hello yawns,
                  this are the Terminal messages after i follow your advice. I log into over ssh. 0_1491221260182_Bildschirmfoto vom 2017-04-03 14-05-30.jpg
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @Peter_van_Evert
                    @Peter_van_Evert take a look here https://forum.magicmirror.builders/topic/2209/error-listen-eaddrinuse-help-plox
                    • P Offline
                      Peter_van_Evert
                      Thank for your help but I think there is no other Application who listen on 8080. This is the result on your idea and I think electron.js is an app of MagicMirror isn’t it ?0_1491223517493_Bildschirmfoto vom 2017-04-03 14-38-29.jpg
                        @Peter_van_Evert yes, but this shows that there is an instance of MagicMirror still running, if you dont know how to kill it the easiest solution would be to restart the pi
                        • 1 / 4
