    Calendar shows "no entries" after MM Update
    37 Posts 12 Posters 35.1k Views 16 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Peter_van_Evert
      @Peter_van_Evert yes, but this shows that there is an instance of MagicMirror still running, if you dont know how to kill it the easiest solution would be to restart the pi
        Peter_van_Evert
        and before I install the Update of MM, everything works fine.
          Peter_van_Evert @strawberry 3.141
          @strawberry-3.141 what do you think is the second instance of MM ? There’s only one who listen on 8080 and when I kill this app, my MM close.
            jasondreher
            I am having the same issue. I have multiple calendars in one view and after the update one will not show up and there are current events on that calendar.
            I luckily had backed up my sd card before updating so I just went back to the prior version. This was after troubleshooting multiple items to get the new update to work.
              sacha81 @Peter_van_Evert
              Same here, I have two ICS from google calendar, on (from my wife) works fine (when I download ICS it’s 300Kb) and mine doesent work (download of ICS is 1.3MB)
              • Mitch1138M Offline
                Mitch1138
                I mentioned this in another post, but I am seeing the same behavior described here.
                  jasondreher
                  We need troubleshooting with this! Who can help? My MM was fantastic before the update.
                    Peter_van_Evert
                    Hello everybody - I know now, that the problem with the google calendar is. As sacha81 wrote : a small calender will be displayed, a big one ( my is 850k) not !! I tested it with a new calendar with 10 entrys. Is there a way to get the old version back ? The calendar is for me the most important item in the magic mirror. Nobody needs a buggy version of MagicMirror.
                      jasondreher
                      That makes sense, the only calendar that does not show is my largest one. And most important!!
                        Peter_van_Evert
                        Hello everybody. I come with very good News ! I find a solution without the people from MagicMirror.
                        1. My old google calendar was too big (850k) and I search earlier for a solution to delete my old calendar entries in the google calendar, e.g. everything before 2017, but there were no function or button at google.
                        2. I export my old and heavy ics File from google to my Computer.
                        3. I wrote a short python script, which takes the ics header from my ics file, delete everything that is older than 2017 and ended with the original ending from my ics file. The new file is 85k :)
                        4. I create an test calender to import the ics file - everything is ok.
                        5. I delete every !! entrie in my Maincalender (my heart goes up) and import the new light ics file - everything goes fine and the new calendar is shown in the MM calendar.
                        6. Delete the test calender
                          Another nice thing is, that there are now no old datas in the google calender. For further information, just contact me.
                          Yours
                          Peter
                          sacha81
                          Thank you Peter for this idea, it will help to mitigate the issue. But this is only a workaround and not a solution, I want to keep my old entires …
                            jasondreher
                            Is no one else having this issue? Besides the couple of us on this thread.
                              Peter_van_Evert @sacha81
                              @sacha81 thats no problem. Export your large an old calender on your PC. Create a new calender an import the data. Delete all the data in your main calender and import the small calender, sort by my Python Skript. So you got one calender with your old data and one small with your 2017 datas.
                                sacha81
                                I made a copy of my google calendar and cleaned out with https://chrome.google.com/webstore/detail/bulk-action-tool-for-goog/lkpgfdjgbcmeblffjfefgkhkneilhfnf now my ICS is 400kb but it still not load :(
                                  Mitch1138
                                  I am still having this problem, but it might not be total related to size. I have a 2.43MB calendar that works fine and a 1.38MB calendar that will not display, both worked before the update. Has anyone found anything that works?
                                  Thanks.
                                    Chadeus
                                      sacha81
                                      I removed all items until today, now my calendar (Google private ICS) has just events in the future and still does not load items on the mirror. Wondering whats changed in this version with the calendar :-(
                                      • tgeimerT Offline
                                        tgeimer
                                        I am experiencing the same issue since the update to the current MM version 2.1.1 . I should have checked for issues beforehand :-/
                                        EDIT: I have all my calendars on my owncloud on the same LAN. All of them work fine except a calendar with all birthdays.
                                        Since I have no time to troubleshoot myself for the next month, I will have to wait for an official fix…
                                        Let’s make MM great again ;-)
                                        tgeimerT 1 Reply Last reply Reply Quote 0
                                        • tgeimerT Offline
                                          tgeimer @tgeimer
                                          I fixed my issue. Some searching led me to this:
                                          https://github.com/MichMich/MagicMirror/issues/791#issuecomment-289306407
                                          No dates before 1970 are accepted - but in my birthday calendar I have created birthdays e.g. in 1946…
                                          Thank you @amcolash
                                          This is how you can check if this is why your calendar is not working:
                                          ssh to your pi
                                          cd /home/pi/MagicMirror
                                          DIAPLAY=:0 npm start dev
                                          If you see this in the output, you have dates in your calendar before 1970:
                                          Error: dates lower than Thu Jan 01 1970 00:00:00 GMT+0100 (CET) are not supported
                                              at Object.toOrdinal (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:105:15)
                                              at Iterinfo.rebuild (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:1409:35)
                                              at RRule._iter (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:978:10)
                                              at RRule.between (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:794:21)
                                              at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:122:24
                                              at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:5)
                                              at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:188:22)
                                              at emitTwo (events.js:106:13)
                                              at Request.emit (events.js:191:7)
                                              at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1171:10)
                                          What I did to fix my birthday calendar: Edit this file
                                          Go to line 56 or search for the first occurance of “ORDINAL_BASE” and change this line:
                                          ORDINAL_BASE: new Date(1970, 0, 1),
                                          set it to a lower year like 1900.
                                          Then restart your magic mirror (pm2 restart mm)
                                          And it’s (hopefully) GREAT AGAIN :-D :clap:
                                            sacha81 @tgeimer
                                            @tgeimer for me thats working THANK YOU !!!
