    Black screen + access Denied trough web
    11 Posts 4 Posters 5.6k Views 3 Watching
    • N Offline
      n8ms
      I am getting the same issue with the black screen. When I access via localhost:8080, I get the default screen that tells you to create a config file. I was using a config.js file from an old build I did that worked, but I replaced it with the config file posted above and I get the same issue.
      pi@n8MM:~/MagicMirror $ npm start
      > magicmirror@2.1.1 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.1.1
      Loading config ...
      Loading module helpers ...
      All module helpers loaded.
      Starting server op port 8080 ...
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      Launching application.
      ^C
      pi@n8MM:~/MagicMirror $ node -v
      v7.9.0
      pi@n8MM:~/MagicMirror $ electron -v
      v1.3.15
