Calendar module fetchInterval
12 Posts 4 Posters 7.5k Views 4 Watching
    Anhalter42 @cohron
    @cohron Just in case this helps you:
    If you want to change something / contribute to an existing project you have to fork it, change what you want to change and create a Pull-Request (which then gets reviewed and accepted/rejected).
    For developing your own module you just need to create a new project, i think. In case you didn’t see it, there is a handy template module you could use as base.
    C 1 Reply Last reply May 6, 2017, 1:37 PM Reply Quote 0
    • C Offline
      cohron @Anhalter42
      @Anhalter42 I spend some time going through the calendar module code, i can read it fairly well, for the syntax i dont understand there is always google. After review, I see why there are no separate fetchInterval’s for each calendar. Each calendar’s events are added to an array, then sorted together also the dom (html table) is created from scratch on each interval. Without a tremendous restructuring of code, setting up separate interval timers, persisting the ical events array, etc. the value to adding this is limited.
      Your comments help me immensely, thank you. I reviewed the template module, i’l start playing with that and do a Hello World module exercise when i return home at the end of the month.
      2 / 2
