    resume()
    12 Posts 4 Posters 5.7k Views 3 Watching
      Anhalter42
      No intention to complain here, so no reason to argue about that.
      IMO, the two most obvious solutions are
      1. changing the behaviour, i.e. implement a check whether the module was visible before the call
      2. changing the description in the documentation so that it matches the behaviour
      The question is, how do you solve something like this here? Who decides which solution should be preferred and how do I trigger a fix (I dont want to dive into the main core code myself). Do you usually open an issue on github in such cases? Also, the author of this peace of code may have relevant information, but (as usual in open-source projects) its nearly impossible to find out who to contact…
      • brobergB Offline
        broberg Project Sponsor @Anhalter42
        @Anhalter42 Yes, open an issue on github or if you already have made changes to either the documentation or written code that does your first suggestion then you would suggest a Pull Request to implement the changes you’ve made
