    Help with Weather Modules!
    2 Posts 2 Posters 1.5k Views 2 Watching
    • T
      twosix
      For the weather modules, if I want to switch to Wunderground, do I hide the default and just keep Wunderground visible? If not, what do I do?
      • Y
        yawns Moderator @twosix
        @twosix
        you could use both modules or you could remove the default ones.
        Either you remove the whole module entries:
        			module: "currentweather",
        				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
        				appid: "YOUR_OPENWEATHER_API_KEY"
        			module: "weatherforecast",
        			header: "Weather Forecast",
        				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
        or you add disabled: true, like this:
        			disabled: true,
        			disabled: true,
