Navigation
    • Search
    Updating SebTota's Pi0 Image stops MM
    Troubleshooting
    • K
      kellogg76 last edited by
      I’m using a Pi Zero image from the Magic Mirror forum for my mirror, but it gives a warning about being over 400 commits from the most recent version.
      I SSH in and try to update from the MagicMirror directory with the command
      git pull
      Then I get this displayed and then after reboot my no longer displays.
      If I then SSH in again, where I normally see this, I see this instead.
      Any ideas?
      • yawns
        yawns Moderator last edited by
        Did you run npm install after the git pull?
        • K
          kellogg76 @yawns last edited by kellogg76
          @yawns I did do that, and got this in the terminal window, now the screen goes black like it’s about to start but never does.
          Looks like I’ll need to copy the image again and try something else.
          • K
            kellogg76 @kellogg76 last edited by
            For anyone with the same issue, follow these steps.
            cd MagicMirror
            git pull
            sudo npm install
            sudo npm install colors -g
            cd vendor
            sudo npm install
            sudo reboot
            After the reboot you’ll be up and running again.
