    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.0m Views 68 Watching
    • evroomE Offline
      evroom @evroom
      @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      Btw. Assuming you use omxplayer. Do not have experience with other players.
      I use omxplayer ‘standalone’, not within MM, but under control of pm2.
      When I restart my camera, the omxplayer is connecting to the stream automatically.
      No restart of the omxplayer stream needed.
      Just FYI.
      MagicMirror version: 2.30.0
      Test environment:
      MagicMirror version: v2.30.0
        dwburger @evroom
        @evroom Thanks! I haven’t been able to get OMXplayer to work, only VLC. However, if I can’t get the auto-restart to work with VLC, I’ll see if I can’t get OMXplayer to work.
        • BKeyportB Offline
          BKeyport Module Developer @dwburger
          @dwburger I was having a ton of trouble streaming anything on my Pi 4. if you’re on a Pi 4, make sure to install the May 2020 update. Streaming is rock solid now.
          https://www.raspberrypi.org/documentation/raspbian/updating.md
          I will note, I’m also using OMX Player independently from MM - the last releases of RTSPStream broke everything, and I couldn’t bother to get things working again. I wrote a little module I kept private because it’s not configurable to cut the desired space out of the MM workspace.
          S D BKeyportB 3 Replies Last reply Reply Quote 0
            sdetweil @BKeyport
            @BKeyport that link is for PI OS… does it apply to raspian buster?
              dwburger @BKeyport
              @BKeyport Yes, I’m using an RPi4. Thanks for the link for updating!
              • BKeyportB Offline
                @sdetweil If you read it, They’re renaming the OS.
                  sdetweil @BKeyport
                  @BKeyport yes, I knew they were renaming… but also that s mostly applied tot he 64 bit version.
                  whatever, commands in progress on my 4
                  • BKeyportB Offline
                    @sdetweil I read it as “Going forward” - meaning all releases after the date of announcement. But, as it’s still debian based under the hood, the commands would be the same (Or apt-get instead)
                    • BKeyportB Offline
                      BKeyport Module Developer @BKeyport
                      You know, it figures… I say it’s stable, and it’s back to pre-PI 4 tricks. It’ll run for about two days before crashing, but that’s a lot better than pre-may2020 Buster - which was 5 minutes at the most.
                        sdetweil @BKeyport
                        @BKeyport wow… my pi4 has been booted solid for weeks… (last manual update boot)
                        • 49
                        • 50
                        • 51
                        • 52
                        • 53
                        • 60
                        • 61
                        • 51 / 61
