    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.1m Views 68 Watching
    • K Offline
      KumarTRD @sdetweil
      @sdetweil Have you had any success with this module?
        sdetweil @KumarTRD
        @KumarTRD I don’t have a need, so haven’t really tried. a year or so ago
        • BKeyportB Offline
          BKeyport Module Developer @KumarTRD
          @KumarTRD Honestly, I run OMXPlayer direct, and have a custom built module to cut out the space for it.
          • K Offline
            KumarTRD @BKeyport
            @BKeyport ahhh gotcha… i kinda got the module working last night but cant get t the configuration of it
            that is the wall ive been running into.
            • Cr4z33C Offline
              Cr4z33 @BKeyport
              @BKeyport said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              @Cr4z33 Good answer. 🤣🤣
              Then, again, I’m not sure how MMM-FreeboxTV is supposed to help with RTSP streaming - wanna comment, @Bugsounet ?
              It is VERY similar to MMM-RTSPStream therefore you add the IP and options in a similar way. :)
              I’ve got some hacked Xiaomi IP cams around the house and so far so good with MMM-FreeboxTV.
              • G Offline
                goprojojo @Cr4z33
                @Cr4z33 That sounds great. Could you share a screenshot how these camera’s looks like on the monitor/mirror?
                • Cr4z33C Offline
                  Cr4z33 @goprojojo
                  @goprojojo I am away from home, but it is nothing different from how it looks in MMM-RTSPStream. ;)
                  • H Offline
                    Hram2008 @evroom
                    @evroom
                    Please see below.
                    Any thoughts would be appreciated.
                    evroomE BKeyportB 2 Replies Last reply Reply Quote 0
                    • evroomE Offline
                      evroom @Hram2008
                      @Hram2008 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                      I am not able to respond to your settings right now, please remind me when I do not answer in a few days.
                      MagicMirror version: 2.35.0
                      Test environment:
                      MagicMirror version: 2.36.0-develop
                      • BKeyportB Offline
                        BKeyport Module Developer @Hram2008
                        @Hram2008 Honestly, if it’s gonna work, you’ve got a good config. I don’t think “port” is valid (you’d put it on the URI)
                        Other than that…
                        Did you check the URI through https://www.ispyconnect.com/sources.aspx ?
                        iSpy is a great resource to get accurate URIs.
                          sdetweil
                          I’ve got a good one, just playing with RTPStream module… my MM is on a second monitor, and the box is shown on the MM screen, but the ffmpeg video is displayed in the same position on the 1st screen… oops…
                          • BKeyportB Offline
                            @sdetweil whoops!
                              raf
                              on my other two rpi I use the rpisurv program which has been doing great for a number of years
                              you can find it in ipcamtalk forum
                              • H Offline
                                Hram2008 @BKeyport
                                @BKeyport
                                I used Ispy to generate the URL… when tested in the VLC player it works. Just wont show on the MM screen. I only get Loading RTSP Stream displayed or a black box.
                                • evroomE Offline
                                  evroom
                                  Please see below.
                                  I would first disable the module (disabled: true,) and restart MM.
                                  Check if there are no omx_streams running (pm2 status).
                                  Stop them when present (pm2 stop omx_stream1 / pm2 delete omx_stream1).
                                  Then verify if omxplayer works standalone (use your own user & password & IP address).
                                  If it does not work standalone, then there is no need to continue trying the module.
                                  $ omxplayer --avdict rtsp_transport:tcp --win 85,65,725,425 --live --video_queue 4 --fps 30 --no-osd rtsp://user:password@192.168.178.55/axis-media/media.amp?resolution=640x360
                                  If that works you can try this verified config (use your own user & password & IP address):
                                  $ vi ~/MagicMirror/config/config.js
                                      module: "MMM-RTSPStream",
                                      //disabled: false,
                                      disabled: true,
                                      position: "middle_center",
                                      header: "Axis Security Monitor",
                                        autoStart: true,
                                        rotateStreams: false,
                                        moduleWidth: 640,
                                        moduleHeight: 360,
                                        localPlayer: 'omxplayer',
                                        remotePlayer: 'none',
                                        showSnapWhenPaused: false,
                                        remoteSnaps: false,
                                        stream1: {
                                          url: 'rtsp://user:password@192.168.178.55/axis-media/media.amp?resolution=640x360',
                                          frameRate: "30",
                                          protocol: "tcp",
                                          width: 640,
                                          height: 360,
                                          omxRestart: 1,
                                          hwAccel: true,
                                  This works for Axis P1448-LE, M2026-LE Mk II and M1125-E.
                                  Good luck.
                                  Test environment:
                                  H W 2 Replies Last reply Reply Quote 0
                                  • H Offline
                                    Hram2008 @evroom
                                    @evroom
                                    Thank you for the details, I am happy to report that the shared config also works for the Axis
                                    Q3615. Thank you assist.
                                    • W Offline
                                      warrendt @evroom
                                      @evroom thanks for this, I am trying to get my vivotek cameras working,
                                      omxplayer --avdict rtsp_transport:tcp --win 85,65,725,425 --live --video_queue 4 --fps 30 --no-osd rtsp://user:password@192.168.1.###/live1s3.sdp
                                      This works great, and I see the feed perfect in the OMX player,
                                      However, my config in the plugin doesn’t. I just get a black box. Any ideas would be appreciated.
                                      			//disabled: false,
                                      			//disabled: true,
                                      			header: "Cameras",
                                      				autoStart: true,
                                      				moduleWidth: 640,
                                      				moduleHeight: 480,
                                      				remoteSnaps: false,
                                      				stream1: {
                                      					url: 'rtsp://user:password@192.168.1.###/live1s3.sdp',
                                      					frameRate: "30",
                                      					protocol: "tcp",
                                      					width: 640,
                                      					height: 480,
                                      					omxRestart: 1,
                                      					hwAccel: true,
                                      evroomE 1 Reply Last reply Reply Quote 0
                                      • evroomE Offline
                                        evroom @warrendt
                                        @warrendt
                                        Can you check following ?
                                        Process omx_stream1 present:
                                        $ pm2 status
                                        $ ps -eaf | grep -v grep | grep omxplayer
                                        Entries in pm2 log:
                                        $ pm2 logs --lines 100
                                        Might need to flush the logs and restart MM in order to show new RTSPStream log entries:
                                        $ pm2 flush
                                        $ pm2 restart MagicMirror
                                        omxplayer version:
                                        $ omxplayer -version
                                        MMM-RTSPStream git status
                                        $ cd ~/MagicMirror/modules/MMM-RTSPStream
                                        $ git status
                                        I am on the develop branch, you might need o switch to that too.
                                        $ git checkout develop
                                        $ npm install
                                        Test environment:
                                          rhopkins7428 @Hram2008
                                          @Hram2008
                                          TLDR, I switched from VLC to omxplayer and my previously working config started working again
                                          I’m using hikvision cameras,
                                          I was having a similar issue, migrating from an working configuration on an old PI3 to a new fresh image on PI4,
                                          fresh Magic Mirror/ and MMM-RTSPStream install, copied original config over but both VLC windows black.
                                          You can click pause on each window, (then shows correct window name) but when you resume it’s just black windows. I confirmed running VLC standalone, using the open network URL, pasted same URL in config and it worked fine. (Like I mentioned running on an older PI no problems)
                                          Anyway, I changed player to omxplayer in the config and it worked immediately, not sure why VLC in MM not working…
                                          my config:
                                          module: “MMM-RTSPStream”,
                                          position: “top_left”,
                                          autoStart: true,
                                          rotateStreamTimeout: 10,
                                          moduleWidth: 354,
                                          moduleHeight: 240,
                                          localPlayer: ‘omxplayer’,
                                          remotePlayer: ‘none’,
                                          showSnapWhenPaused: true,
                                          remoteSnaps: false,
                                          shutdownDelay: 12,
                                          stream1: {
                                          url: ‘rtsp://admin:secret@10.99.98.101:554//Streaming/Channels/2’,
                                          frameRate: ‘undefined’,
                                          snapshotType: ‘url’,
                                          snapshotRefresh: 10,
                                          width: undefined,
                                          height: undefined,
                                          stream2: {
                                          url: ‘rtsp://admin:secret@10.99.98.37:554//Streaming/Channels/2’,
                                          width: undefined,
                                          height: undefined,
                                          • BKeyportB Offline
                                            Sometimes with this app you gotta jiggle the handle.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 29 / 31
