    602 Posts 67 Posters 2.1m Views 68 Watching
    • G Offline
      goprojojo @Cr4z33
      @Cr4z33 That sounds great. Could you share a screenshot how these camera’s looks like on the monitor/mirror?
      • Cr4z33C Offline
        Cr4z33 @goprojojo
        @goprojojo I am away from home, but it is nothing different from how it looks in MMM-RTSPStream. ;)
        • H Offline
          Hram2008 @evroom
          @evroom
          Please see below.
          Any thoughts would be appreciated.
          evroomE BKeyportB 2 Replies Last reply Reply Quote 0
          • evroomE Offline
            evroom @Hram2008
            @Hram2008 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            I am not able to respond to your settings right now, please remind me when I do not answer in a few days.
            MagicMirror version: 2.33.0
            Test environment:
            MagicMirror version: v2.33.0
            • BKeyportB Offline
              BKeyport Module Developer @Hram2008
              @Hram2008 Honestly, if it’s gonna work, you’ve got a good config. I don’t think “port” is valid (you’d put it on the URI)
              Other than that…
              Did you check the URI through https://www.ispyconnect.com/sources.aspx ?
              iSpy is a great resource to get accurate URIs.
                I’ve got a good one, just playing with RTPStream module… my MM is on a second monitor, and the box is shown on the MM screen, but the ffmpeg video is displayed in the same position on the 1st screen… oops…
                • BKeyportB Offline
                  @sdetweil whoops!
                    raf
                    on my other two rpi I use the rpisurv program which has been doing great for a number of years
                    you can find it in ipcamtalk forum
                    • H Offline
                      Hram2008 @BKeyport
                      @BKeyport
                      I used Ispy to generate the URL… when tested in the VLC player it works. Just wont show on the MM screen. I only get Loading RTSP Stream displayed or a black box.
                      • evroomE Offline
                        evroom
                        Please see below.
                        I would first disable the module (disabled: true,) and restart MM.
                        Check if there are no omx_streams running (pm2 status).
                        Stop them when present (pm2 stop omx_stream1 / pm2 delete omx_stream1).
                        Then verify if omxplayer works standalone (use your own user & password & IP address).
                        If it does not work standalone, then there is no need to continue trying the module.
                        $ omxplayer --avdict rtsp_transport:tcp --win 85,65,725,425 --live --video_queue 4 --fps 30 --no-osd rtsp://user:password@192.168.178.55/axis-media/media.amp?resolution=640x360
                        If that works you can try this verified config (use your own user & password & IP address):
                        $ vi ~/MagicMirror/config/config.js
                            module: "MMM-RTSPStream",
                            //disabled: false,
                            disabled: true,
                            position: "middle_center",
                            header: "Axis Security Monitor",
                              autoStart: true,
                              rotateStreams: false,
                              moduleWidth: 640,
                              moduleHeight: 360,
                              localPlayer: 'omxplayer',
                              remotePlayer: 'none',
                              showSnapWhenPaused: false,
                              remoteSnaps: false,
                              stream1: {
                                url: 'rtsp://user:password@192.168.178.55/axis-media/media.amp?resolution=640x360',
                                frameRate: "30",
                                protocol: "tcp",
                                width: 640,
                                height: 360,
                                omxRestart: 1,
                                hwAccel: true,
                        This works for Axis P1448-LE, M2026-LE Mk II and M1125-E.
                        Good luck.
                        Test environment:
                        H W 2 Replies Last reply Reply Quote 0
                        • 55
                        • 56
                        • 57
                        • 58
                        • 59
                        • 60
                        • 61
                        • 57 / 61
