    602 Posts 67 Posters 2.3m Views 68 Watching
      sdetweil @Cr4z33
      @Cr4z33 can u try this
      cd ~/MagicMirror/modules/shbatm/MMM-RTSPStream
      ls node_modules/node-rtsp-stream-es6
      rm -rf node_modules/node-rtsp-stream-es6
      rm package-lock.json
      npm install
      then try restarting MM
      • Cr4z33C Offline
        Cr4z33 @sdetweil
        @sdetweil thanks for helping! :)
        Last command showed an error that looks like (translated from Italian):
        cr4z33@Cr4z33-UbuntuDesktop-VM-Synology:~/MagicMirror/modules/MMM-RTSPStream$
        ls: Cannot access 'node_modules/node-rtsp-stream-es6': File or directory does not exist
        In fact looking in the node_modules folder there’s no node-rtsp-stream-es6 directory. :thinking_face:
        I then thought it was a good idea running npm install node-rtsp-stream-es6 in the MMM-RTSPStream directory.
        The folder was created at last, but then I kept getting errors at MM launch:
        cr4z33@Cr4z33-UbuntuDesktop-VM-Synology:~/MagicMirror$ npm start
        > magicmirror@2.12.0 start /home/cr4z33/MagicMirror
        [2020-07-15 08:58:08.182] [LOG]    Starting MagicMirror: v2.12.0
        [2020-07-15 08:58:08.184] [LOG]    Loading config ...
        [2020-07-15 08:58:08.186] [LOG]    Loading module helpers ...
        [2020-07-15 08:58:08.188] [LOG]    Initializing new module helper ...
        [2020-07-15 08:58:08.188] [LOG]    Module helper loaded: MMM-WatchDog
        [2020-07-15 08:58:08.231] [LOG]    Initializing new module helper ...
        [2020-07-15 08:58:08.232] [LOG]    Module helper loaded: MMM-Remote-Control
        [2020-07-15 08:58:08.354] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'datauri'
        Require stack:
        - /home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js
        - /home/cr4z33/MagicMirror/js/app.js
        - /home/cr4z33/MagicMirror/js/electron.js
        - /home/cr4z33/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
        [2020-07-15 08:58:08.354] [LOG]    Loading module helpers ...
        [2020-07-15 08:58:08.355] [LOG]    Initializing new module helper ...
        [2020-07-15 08:58:08.355] [LOG]    Module helper loaded: MMM-WatchDog
        [2020-07-15 08:58:08.355] [LOG]    Module helper loaded: MMM-Remote-Control
        [2020-07-15 08:58:08.356] [ERROR]  App threw an error during load
        [2020-07-15 08:58:08.356] [ERROR]  Error: Cannot find module 'datauri'
        Require stack:
            at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
            at Function.Module._resolveFilename (/home/cr4z33/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
            at Function.Module._resolveFilename (/home/cr4z33/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Function.Module._load (internal/modules/cjs/loader.js:531:27)
            at Module.require (internal/modules/cjs/loader.js:685:19)
            at require (internal/modules/cjs/helpers.js:16:16)
            at Object.<anonymous> (/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js:14:17)
            at Module._compile (internal/modules/cjs/loader.js:786:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
            at Module.load (internal/modules/cjs/loader.js:645:32)
        [2020-07-15 08:58:08.357] [ERROR]  Whoops! There was an uncaught exception...
        [2020-07-15 08:58:08.357] [ERROR]  Error: Cannot find module 'datauri'
        Require stack:
            at Module.load (internal/modules/cjs/loader.js:645:32) {
          code: 'MODULE_NOT_FOUND',
          requireStack: [
            '/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js',
            '/home/cr4z33/MagicMirror/js/app.js',
            '/home/cr4z33/MagicMirror/js/electron.js',
            '/home/cr4z33/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
            undefined
        [2020-07-15 08:58:08.359] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-07-15 08:58:08.359] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-07-15 08:58:08.412] [LOG]    Launching application.
        • Cr4z33C Offline
          Cr4z33
          Problem sorted by manually untarring the module from a previous (RPI4) backup.
          Basically the module installation in Ubuntu could not be completed properly and therefore a lot of stuff was missing. :)
          • Cr4z33C Offline
            Cr4z33
            Hmmm one more issue came out…
            While opting to go for Debian 10.x instead of Ubuntu I notice now that the stream window doesn’t go where it should.
            Basically I choosed to place it on bottom right, but it pops in a vlc titled window (and in the wrong position) instead. :confused_face:
            Here’s the screenshot:
            https://imgur.com/QUiumaA
            • BKeyportB Offline
              BKeyport Module Developer @Cr4z33
              @Cr4z33 RTSPStream uses an external utility to move VNC around the screen, it’s entirely possible that utility doesn’t work in Debian or isn’t installed in your version.
              • Cr4z33C Offline
                Cr4z33 @BKeyport
                • Cr4z33C Offline
                  Cr4z33
                  This module needs to be fixed asap.
                  The developer @shbatm seems to have abandoned the project since many weeks/months and the module was a real good add to MagicMirror.
                  After latest MM upgrades it has broken and now streams come up in weird huge size and in a wrong position (stream position config settings get COMPLETELY ignored).
                  If someone skilled enough would be willing to post please a fix?
                  I assume it’s just a matter of some node_helper.js edit, but I have zero knowledge of JavaScript language…
                  @BKeyport are you able to do that please? :smiling_face_with_open_mouth_cold_sweat:
                  • Cr4z33C Offline
                    Cr4z33
                    OK I solved the problem by replacing this module with MMM-FreeboxTV. 👋
                      jasim @Cr4z33
                      @Cr4z33
                      Do you have a link to the module: MMM-FreeboxTV
                      S Cr4z33C 2 Replies Last reply Reply Quote 0
                        sdetweil @jasim
                        @jasim Google is your friend
                        search with
                        modulename GitHub
                        will find it every time
                        • Cr4z33C Offline
                          Cr4z33 @jasim
                          @jasim https://github.com/bugsounet/MMM-FreeboxTV
                            jasim @Cr4z33
                            @Cr4z33
                            Can I display RTSPStream from an IP camera in the module?
                              costascontis
                              module still works for me using vlc at my rpi3b.I just need to find a way to restart the stream cause sometimes stream stops and need to manually press “pause” wait some seconds ,and press play again to start stream.Any ideas?Can i use pm2 somehow when this is happening?
                              • K Offline
                                KumarTRD @costascontis
                                @costascontis would you be willing to help get my RTSPStream up and running? Been trying for some time now but keep hitting walls.
                                BKeyportB Cr4z33C 2 Replies Last reply Reply Quote 0
                                • BKeyportB Offline
                                  BKeyport Module Developer @KumarTRD
                                  @KumarTRD I’d highly recommend using a different module if possible.
                                  • Cr4z33C Offline
                                    Cr4z33 @KumarTRD
                                    @KumarTRD go for MMM-FreeboxTV.
                                    It does everything you need.
                                    • G Offline
                                      goprojojo @Cr4z33
                                      @Cr4z33 how would it solve the rtsp stream. Do you have an example?
                                      • Cr4z33C Offline
                                        Cr4z33 @goprojojo
                                        @goprojojo well let’s say that MMM-FreeboxTV is currently developed and therefore supported by its developer (@Bugsounet).
                                        So once you are sure you are using a 100% bugs free up to date module you can start testing your RTSP stream and eventually ask for help. ;)
                                        • BKeyportB Offline
                                          @Cr4z33 Good answer. 🤣🤣
                                          Then, again, I’m not sure how MMM-FreeboxTV is supposed to help with RTSP streaming - wanna comment, @Bugsounet ?
                                          Cr4z33C 1 Reply Last reply Reply Quote 1
                                            shbatm Module Developer
                                            All, I just wanted to check in and apologize for not only lack of support for this module but lack of response on here and on GitHub.
                                            Thank you for those who have been continuously trying to get others’ setups working. You are showing the true value of this community.
                                            I feel I at least owe a bit of an update, since I’ve been utterly frustrated before by developers who disappear without a trace, but officially: I am not planning on actively supporting this module any further.
                                            The underlying software for the OMXPlayer and VLC overlays are not under my control, and in several years of searching I have not found a “smooth” or “robust” way of maintaining a low-resource-demand RTSP Stream without significant lag, and I was a bit overwhelmed trying to make a one-size-fits-all module that worked for everything. I actually have only used the stills/snapshot feature of this module on my own mirror for the last year and a half, and found myself never using the live stream, that functionality has been delegated to my Home Assistant setups, which have people much better than me working on the Stream components.
                                            Both of my mirrors are also presently in pieces as part of a home move that is going terribly and coupled with a COVID-19-impacted work schedule (now working 2/3s of my days away from home), I will not have time to make any improvements to this module in the foreseeable future.
                                            I’m sorry to have to make this decision and will try and accept any Pull Requests outstanding and clean up the dev/master branches to be consistent. If there is someone willing to take over developing, I can transfer the repo to your fork.
                                            For those who have been continually helping to get streaming working for everyone on here, again, thank you, you are helping drive what this community is about (and helping me by knowing the countless hours put into this module have at least helped a few others).
                                            BKeyportB 1 Reply Last reply Reply Quote 2
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 28 / 31
