    602 Posts 67 Posters 2.3m Views 68 Watching
    • Cr4z33C
      Cr4z33 @sdetweil
      @sdetweil yep.
        sdetweil @Cr4z33
        @Cr4z33 can u try this
        cd ~/MagicMirror/modules/shbatm/MMM-RTSPStream
        ls node_modules/node-rtsp-stream-es6
        rm -rf node_modules/node-rtsp-stream-es6
        rm package-lock.json
        npm install
        then try restarting MM
        • Cr4z33C
          Cr4z33 @sdetweil
          @sdetweil thanks for helping! :)
          Last command showed an error that looks like (translated from Italian):
          cr4z33@Cr4z33-UbuntuDesktop-VM-Synology:~/MagicMirror/modules/MMM-RTSPStream$
          ls: Cannot access 'node_modules/node-rtsp-stream-es6': File or directory does not exist
          In fact looking in the node_modules folder there’s no node-rtsp-stream-es6 directory. :thinking_face:
          I then thought it was a good idea running npm install node-rtsp-stream-es6 in the MMM-RTSPStream directory.
          The folder was created at last, but then I kept getting errors at MM launch:
          cr4z33@Cr4z33-UbuntuDesktop-VM-Synology:~/MagicMirror$ npm start
          > magicmirror@2.12.0 start /home/cr4z33/MagicMirror
          [2020-07-15 08:58:08.182] [LOG]    Starting MagicMirror: v2.12.0
          [2020-07-15 08:58:08.184] [LOG]    Loading config ...
          [2020-07-15 08:58:08.186] [LOG]    Loading module helpers ...
          [2020-07-15 08:58:08.188] [LOG]    Initializing new module helper ...
          [2020-07-15 08:58:08.188] [LOG]    Module helper loaded: MMM-WatchDog
          [2020-07-15 08:58:08.231] [LOG]    Initializing new module helper ...
          [2020-07-15 08:58:08.232] [LOG]    Module helper loaded: MMM-Remote-Control
          [2020-07-15 08:58:08.354] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'datauri'
          Require stack:
          - /home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js
          - /home/cr4z33/MagicMirror/js/app.js
          - /home/cr4z33/MagicMirror/js/electron.js
          - /home/cr4z33/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
          [2020-07-15 08:58:08.354] [LOG]    Loading module helpers ...
          [2020-07-15 08:58:08.355] [LOG]    Initializing new module helper ...
          [2020-07-15 08:58:08.355] [LOG]    Module helper loaded: MMM-WatchDog
          [2020-07-15 08:58:08.355] [LOG]    Module helper loaded: MMM-Remote-Control
          [2020-07-15 08:58:08.356] [ERROR]  App threw an error during load
          [2020-07-15 08:58:08.356] [ERROR]  Error: Cannot find module 'datauri'
          Require stack:
              at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
              at Function.Module._resolveFilename (/home/cr4z33/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
              at Function.Module._resolveFilename (/home/cr4z33/MagicMirror/node_modules/module-alias/index.js:49:29)
              at Function.Module._load (internal/modules/cjs/loader.js:531:27)
              at Module.require (internal/modules/cjs/loader.js:685:19)
              at require (internal/modules/cjs/helpers.js:16:16)
              at Object.<anonymous> (/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js:14:17)
              at Module._compile (internal/modules/cjs/loader.js:786:30)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
              at Module.load (internal/modules/cjs/loader.js:645:32)
          [2020-07-15 08:58:08.357] [ERROR]  Whoops! There was an uncaught exception...
          [2020-07-15 08:58:08.357] [ERROR]  Error: Cannot find module 'datauri'
          Require stack:
              at Module.load (internal/modules/cjs/loader.js:645:32) {
            code: 'MODULE_NOT_FOUND',
            requireStack: [
              '/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js',
              '/home/cr4z33/MagicMirror/js/app.js',
              '/home/cr4z33/MagicMirror/js/electron.js',
              '/home/cr4z33/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
              undefined
          [2020-07-15 08:58:08.359] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2020-07-15 08:58:08.359] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [2020-07-15 08:58:08.412] [LOG]    Launching application.
          • Cr4z33C
            Cr4z33
            Problem sorted by manually untarring the module from a previous (RPI4) backup.
            Basically the module installation in Ubuntu could not be completed properly and therefore a lot of stuff was missing. :)
            • Cr4z33C
              Cr4z33
              Hmmm one more issue came out…
              While opting to go for Debian 10.x instead of Ubuntu I notice now that the stream window doesn’t go where it should.
              Basically I choosed to place it on bottom right, but it pops in a vlc titled window (and in the wrong position) instead. :confused_face:
              Here’s the screenshot:
              https://imgur.com/QUiumaA
              • BKeyportB
                BKeyport Module Developer @Cr4z33
                @Cr4z33 RTSPStream uses an external utility to move VNC around the screen, it’s entirely possible that utility doesn’t work in Debian or isn’t installed in your version.
                • Cr4z33C
                  Cr4z33 @BKeyport
                  • Cr4z33C
                    Cr4z33
                    This module needs to be fixed asap.
                    The developer @shbatm seems to have abandoned the project since many weeks/months and the module was a real good add to MagicMirror.
                    After latest MM upgrades it has broken and now streams come up in weird huge size and in a wrong position (stream position config settings get COMPLETELY ignored).
                    If someone skilled enough would be willing to post please a fix?
                    I assume it’s just a matter of some node_helper.js edit, but I have zero knowledge of JavaScript language…
                    @BKeyport are you able to do that please? :smiling_face_with_open_mouth_cold_sweat:
                    • Cr4z33C
                      Cr4z33
                      OK I solved the problem by replacing this module with MMM-FreeboxTV. 👋
                        jasim @Cr4z33
                        @Cr4z33
                        Do you have a link to the module: MMM-FreeboxTV
                        S Cr4z33C 2 Replies Last reply Reply Quote 0
                          sdetweil @jasim
                          @jasim Google is your friend
                          search with
                          modulename GitHub
                          will find it every time
                          • Cr4z33C
                            Cr4z33 @jasim
                            @jasim https://github.com/bugsounet/MMM-FreeboxTV
                              jasim @Cr4z33
                              @Cr4z33
                              Can I display RTSPStream from an IP camera in the module?
                                costascontis
                                module still works for me using vlc at my rpi3b.I just need to find a way to restart the stream cause sometimes stream stops and need to manually press “pause” wait some seconds ,and press play again to start stream.Any ideas?Can i use pm2 somehow when this is happening?
                                • K
                                  KumarTRD @costascontis
                                  @costascontis would you be willing to help get my RTSPStream up and running? Been trying for some time now but keep hitting walls.
                                  BKeyportB Cr4z33C 2 Replies Last reply Reply Quote 0
                                  • BKeyportB
                                    BKeyport Module Developer @KumarTRD
                                    @KumarTRD I’d highly recommend using a different module if possible.
                                    • Cr4z33C
                                      Cr4z33 @KumarTRD
                                      @KumarTRD go for MMM-FreeboxTV.
                                      It does everything you need.
                                      • G
                                        goprojojo @Cr4z33
                                        @Cr4z33 how would it solve the rtsp stream. Do you have an example?
                                        • Cr4z33C
                                          Cr4z33 @goprojojo
                                          @goprojojo well let’s say that MMM-FreeboxTV is currently developed and therefore supported by its developer (@Bugsounet).
                                          So once you are sure you are using a 100% bugs free up to date module you can start testing your RTSP stream and eventually ask for help. ;)
                                          • BKeyportB
                                            @Cr4z33 Good answer. 🤣🤣
                                            Then, again, I’m not sure how MMM-FreeboxTV is supposed to help with RTSP streaming - wanna comment, @Bugsounet ?
                                            Cr4z33C 1 Reply Last reply Reply Quote 1
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 28 / 31
