    602 Posts 67 Posters 2.3m Views 68 Watching
    • Cr4z33C
      Cr4z33 @BKeyport
      • Cr4z33C
        Cr4z33
        This module needs to be fixed asap.
        The developer @shbatm seems to have abandoned the project since many weeks/months and the module was a real good add to MagicMirror.
        After latest MM upgrades it has broken and now streams come up in weird huge size and in a wrong position (stream position config settings get COMPLETELY ignored).
        If someone skilled enough would be willing to post please a fix?
        I assume it’s just a matter of some node_helper.js edit, but I have zero knowledge of JavaScript language…
        @BKeyport are you able to do that please? :smiling_face_with_open_mouth_cold_sweat:
        • Cr4z33C
          Cr4z33
          OK I solved the problem by replacing this module with MMM-FreeboxTV. 👋
            jasim @Cr4z33
            @Cr4z33
            Do you have a link to the module: MMM-FreeboxTV
            S Cr4z33C 2 Replies Last reply Reply Quote 0
              sdetweil @jasim
              @jasim Google is your friend
              search with
              modulename GitHub
              will find it every time
              • Cr4z33C
                Cr4z33 @jasim
                @jasim https://github.com/bugsounet/MMM-FreeboxTV
                  jasim @Cr4z33
                  @Cr4z33
                  Can I display RTSPStream from an IP camera in the module?
                    costascontis
                    module still works for me using vlc at my rpi3b.I just need to find a way to restart the stream cause sometimes stream stops and need to manually press “pause” wait some seconds ,and press play again to start stream.Any ideas?Can i use pm2 somehow when this is happening?
                    • K
                      KumarTRD @costascontis
                      @costascontis would you be willing to help get my RTSPStream up and running? Been trying for some time now but keep hitting walls.
                      BKeyportB Cr4z33C 2 Replies Last reply Reply Quote 0
                      • BKeyportB
                        BKeyport Module Developer @KumarTRD
                        @KumarTRD I’d highly recommend using a different module if possible.
                        • Cr4z33C
                          Cr4z33 @KumarTRD
                          @KumarTRD go for MMM-FreeboxTV.
                          It does everything you need.
                          • G
                            goprojojo @Cr4z33
                            @Cr4z33 how would it solve the rtsp stream. Do you have an example?
                            • Cr4z33C
                              Cr4z33 @goprojojo
                              @goprojojo well let’s say that MMM-FreeboxTV is currently developed and therefore supported by its developer (@Bugsounet).
                              So once you are sure you are using a 100% bugs free up to date module you can start testing your RTSP stream and eventually ask for help. ;)
                              • BKeyportB
                                BKeyport Module Developer @Cr4z33
                                @Cr4z33 Good answer. 🤣🤣
                                Then, again, I’m not sure how MMM-FreeboxTV is supposed to help with RTSP streaming - wanna comment, @Bugsounet ?
                                Cr4z33C 1 Reply Last reply Reply Quote 1
                                  shbatm Module Developer
                                  All, I just wanted to check in and apologize for not only lack of support for this module but lack of response on here and on GitHub.
                                  Thank you for those who have been continuously trying to get others’ setups working. You are showing the true value of this community.
                                  I feel I at least owe a bit of an update, since I’ve been utterly frustrated before by developers who disappear without a trace, but officially: I am not planning on actively supporting this module any further.
                                  The underlying software for the OMXPlayer and VLC overlays are not under my control, and in several years of searching I have not found a “smooth” or “robust” way of maintaining a low-resource-demand RTSP Stream without significant lag, and I was a bit overwhelmed trying to make a one-size-fits-all module that worked for everything. I actually have only used the stills/snapshot feature of this module on my own mirror for the last year and a half, and found myself never using the live stream, that functionality has been delegated to my Home Assistant setups, which have people much better than me working on the Stream components.
                                  Both of my mirrors are also presently in pieces as part of a home move that is going terribly and coupled with a COVID-19-impacted work schedule (now working 2/3s of my days away from home), I will not have time to make any improvements to this module in the foreseeable future.
                                  I’m sorry to have to make this decision and will try and accept any Pull Requests outstanding and clean up the dev/master branches to be consistent. If there is someone willing to take over developing, I can transfer the repo to your fork.
                                  For those who have been continually helping to get streaming working for everyone on here, again, thank you, you are helping drive what this community is about (and helping me by knowing the countless hours put into this module have at least helped a few others).
                                  BKeyportB 1 Reply Last reply Reply Quote 2
                                  • BKeyportB
                                    BKeyport Module Developer @shbatm
                                    @shbatm Thanks for updating us on what’s going on.
                                    • K
                                      KumarTRD @BKeyport
                                      @BKeyport what module would you suggest using? I have a Lorex NVR system and this is the last module that i NEED/WANT to complete my build.
                                      • K
                                        KumarTRD @sdetweil
                                        @sdetweil Have you had any success with this module?
                                          sdetweil @KumarTRD
                                          @KumarTRD I don’t have a need, so haven’t really tried. a year or so ago
                                          • BKeyportB
                                            @KumarTRD Honestly, I run OMXPlayer direct, and have a custom built module to cut out the space for it.
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 28 / 31
