    602 Posts 67 Posters 2.4m Views 68 Watching
    • twosquirrelsT
      twosquirrels @dwburger
      • Cr4z33C
        Cr4z33
        I am trying to have this module running succesfully in Ubuntu Desktop, but it doesn’t work right now.
        I ran the bash setup command and choosed the master build (dev build gave the same errors).
        [2020-07-14 16:46:29.279] [LOG]    Starting MagicMirror: v2.12.0
        [2020-07-14 16:46:29.282] [LOG]    Loading config ...
        [2020-07-14 16:46:29.284] [LOG]    Loading module helpers ...
        [2020-07-14 16:46:29.286] [LOG]    Initializing new module helper ...
        [2020-07-14 16:46:29.286] [LOG]    Module helper loaded: MMM-WatchDog
        [2020-07-14 16:46:29.335] [LOG]    Initializing new module helper ...
        [2020-07-14 16:46:29.335] [LOG]    Module helper loaded: MMM-Remote-Control
        [2020-07-14 16:46:29.339] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-rtsp-stream-es6'
        Require stack:
        - /home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js
        - /home/cr4z33/MagicMirror/js/app.js
        - /home/cr4z33/MagicMirror/js/electron.js
        - /home/cr4z33/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
        [2020-07-14 16:46:29.340] [LOG]    Loading module helpers ...
        [2020-07-14 16:46:29.340] [LOG]    Initializing new module helper ...
        [2020-07-14 16:46:29.340] [LOG]    Module helper loaded: MMM-WatchDog
        [2020-07-14 16:46:29.341] [LOG]    Module helper loaded: MMM-Remote-Control
        [2020-07-14 16:46:29.342] [ERROR]  App threw an error during load
        [2020-07-14 16:46:29.342] [ERROR]  Error: Cannot find module 'node-rtsp-stream-es6'
        Require stack:
            at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
            at Function.Module._resolveFilename (/home/cr4z33/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
            at Function.Module._resolveFilename (/home/cr4z33/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Function.Module._load (internal/modules/cjs/loader.js:531:27)
            at Module.require (internal/modules/cjs/loader.js:685:19)
            at require (internal/modules/cjs/helpers.js:16:16)
            at Object.<anonymous> (/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js:10:14)
            at Module._compile (internal/modules/cjs/loader.js:786:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
            at Module.load (internal/modules/cjs/loader.js:645:32)
        [2020-07-14 16:46:29.343] [ERROR]  Whoops! There was an uncaught exception...
        [2020-07-14 16:46:29.343] [ERROR]  Error: Cannot find module 'node-rtsp-stream-es6'
        Require stack:
            at Module.load (internal/modules/cjs/loader.js:645:32) {
          code: 'MODULE_NOT_FOUND',
          requireStack: [
            '/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js',
            '/home/cr4z33/MagicMirror/js/app.js',
            '/home/cr4z33/MagicMirror/js/electron.js',
            '/home/cr4z33/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
            undefined
        [2020-07-14 16:46:29.345] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-07-14 16:46:29.346] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-07-14 16:46:29.414] [LOG]    Launching application.
          sdetweil @Cr4z33
          @Cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
          Error: Cannot find module ‘node-rtsp-stream-es6’
          did u do npm install in the “/home/cr4z33/MagicMirror/modules/MMM-RTSPStream” folder?
          Cr4z33C 1 Reply Last reply
          • Cr4z33C
            Cr4z33 @sdetweil
            @sdetweil yep.
              sdetweil @Cr4z33
              @Cr4z33 can u try this
              cd ~/MagicMirror/modules/shbatm/MMM-RTSPStream
              ls node_modules/node-rtsp-stream-es6
              rm -rf node_modules/node-rtsp-stream-es6
              rm package-lock.json
              npm install
              then try restarting MM
              • Cr4z33C
                Cr4z33 @sdetweil
                @sdetweil thanks for helping! :)
                Last command showed an error that looks like (translated from Italian):
                cr4z33@Cr4z33-UbuntuDesktop-VM-Synology:~/MagicMirror/modules/MMM-RTSPStream$
                ls: Cannot access 'node_modules/node-rtsp-stream-es6': File or directory does not exist
                In fact looking in the node_modules folder there’s no node-rtsp-stream-es6 directory. :thinking_face:
                I then thought it was a good idea running npm install node-rtsp-stream-es6 in the MMM-RTSPStream directory.
                The folder was created at last, but then I kept getting errors at MM launch:
                cr4z33@Cr4z33-UbuntuDesktop-VM-Synology:~/MagicMirror$ npm start
                > magicmirror@2.12.0 start /home/cr4z33/MagicMirror
                [2020-07-15 08:58:08.182] [LOG]    Starting MagicMirror: v2.12.0
                [2020-07-15 08:58:08.184] [LOG]    Loading config ...
                [2020-07-15 08:58:08.186] [LOG]    Loading module helpers ...
                [2020-07-15 08:58:08.188] [LOG]    Initializing new module helper ...
                [2020-07-15 08:58:08.188] [LOG]    Module helper loaded: MMM-WatchDog
                [2020-07-15 08:58:08.231] [LOG]    Initializing new module helper ...
                [2020-07-15 08:58:08.232] [LOG]    Module helper loaded: MMM-Remote-Control
                [2020-07-15 08:58:08.354] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'datauri'
                Require stack:
                [2020-07-15 08:58:08.354] [LOG]    Loading module helpers ...
                [2020-07-15 08:58:08.355] [LOG]    Initializing new module helper ...
                [2020-07-15 08:58:08.355] [LOG]    Module helper loaded: MMM-WatchDog
                [2020-07-15 08:58:08.355] [LOG]    Module helper loaded: MMM-Remote-Control
                [2020-07-15 08:58:08.356] [ERROR]  App threw an error during load
                [2020-07-15 08:58:08.356] [ERROR]  Error: Cannot find module 'datauri'
                Require stack:
                    at Object.<anonymous> (/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js:14:17)
                [2020-07-15 08:58:08.357] [ERROR]  Whoops! There was an uncaught exception...
                [2020-07-15 08:58:08.357] [ERROR]  Error: Cannot find module 'datauri'
                Require stack:
                  requireStack: [
                    undefined
                [2020-07-15 08:58:08.359] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2020-07-15 08:58:08.359] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                [2020-07-15 08:58:08.412] [LOG]    Launching application.
                • Cr4z33C
                  Cr4z33
                  Problem sorted by manually untarring the module from a previous (RPI4) backup.
                  Basically the module installation in Ubuntu could not be completed properly and therefore a lot of stuff was missing. :)
                  • Cr4z33C
                    Cr4z33
                    Hmmm one more issue came out…
                    While opting to go for Debian 10.x instead of Ubuntu I notice now that the stream window doesn’t go where it should.
                    Basically I choosed to place it on bottom right, but it pops in a vlc titled window (and in the wrong position) instead. :confused_face:
                    Here’s the screenshot:
                    https://imgur.com/QUiumaA
                    BKeyportB 1 Reply Last reply
                    • BKeyportB
                      BKeyport Module Developer @Cr4z33
                      @Cr4z33 RTSPStream uses an external utility to move VNC around the screen, it’s entirely possible that utility doesn’t work in Debian or isn’t installed in your version.
                      • Cr4z33C
                        Cr4z33 @BKeyport
                        • Cr4z33C
                          Cr4z33
                          This module needs to be fixed asap.
                          The developer @shbatm seems to have abandoned the project since many weeks/months and the module was a real good add to MagicMirror.
                          After latest MM upgrades it has broken and now streams come up in weird huge size and in a wrong position (stream position config settings get COMPLETELY ignored).
                          If someone skilled enough would be willing to post please a fix?
                          I assume it’s just a matter of some node_helper.js edit, but I have zero knowledge of JavaScript language…
                          @BKeyport are you able to do that please? :smiling_face_with_open_mouth_cold_sweat:
                          • Cr4z33C
                            Cr4z33
                            OK I solved the problem by replacing this module with MMM-FreeboxTV. 👋
                            J 1 Reply Last reply
                              jasim @Cr4z33
                              @Cr4z33
                              Do you have a link to the module: MMM-FreeboxTV
                              S Cr4z33C 2 Replies Last reply
                                sdetweil @jasim
                                @jasim Google is your friend
                                search with
                                modulename GitHub
                                will find it every time
                                K 1 Reply Last reply
                                • Cr4z33C
                                  Cr4z33 @jasim
                                  @jasim https://github.com/bugsounet/MMM-FreeboxTV
                                    jasim @Cr4z33
                                    @Cr4z33
                                    Can I display RTSPStream from an IP camera in the module?
                                      costascontis
                                      module still works for me using vlc at my rpi3b.I just need to find a way to restart the stream cause sometimes stream stops and need to manually press “pause” wait some seconds ,and press play again to start stream.Any ideas?Can i use pm2 somehow when this is happening?
                                      • K
                                        KumarTRD @costascontis
                                        @costascontis would you be willing to help get my RTSPStream up and running? Been trying for some time now but keep hitting walls.
                                        BKeyportB Cr4z33C 2 Replies Last reply
                                        • BKeyportB
                                          BKeyport Module Developer @KumarTRD
                                          @KumarTRD I’d highly recommend using a different module if possible.
                                          • Cr4z33C
                                            Cr4z33 @KumarTRD
                                            @KumarTRD go for MMM-FreeboxTV.
                                            It does everything you need.
                                            G 1 Reply Last reply
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 28 / 31
