    602 Posts 67 Posters 2.4m Views 68 Watching
    • H
      Hram2008 @evroom
      @evroom
      Please see below.
      Any thoughts would be appreciated.
      evroomE BKeyportB 2 Replies Last reply
      • evroomE
        evroom @Hram2008
        @Hram2008 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        I am not able to respond to your settings right now, please remind me when I do not answer in a few days.
        MagicMirror version: 2.37.0
        • BKeyportB
          BKeyport Module Developer @Hram2008
          @Hram2008 Honestly, if it’s gonna work, you’ve got a good config. I don’t think “port” is valid (you’d put it on the URI)
          Other than that…
          Did you check the URI through https://www.ispyconnect.com/sources.aspx ?
          iSpy is a great resource to get accurate URIs.
          H 1 Reply Last reply
            I’ve got a good one, just playing with RTPStream module… my MM is on a second monitor, and the box is shown on the MM screen, but the ffmpeg video is displayed in the same position on the 1st screen… oops…
            BKeyportB 1 Reply Last reply
            • BKeyportB
              @sdetweil whoops!
                raf
                on my other two rpi I use the rpisurv program which has been doing great for a number of years
                you can find it in ipcamtalk forum
                • H
                  Hram2008 @BKeyport
                  @BKeyport
                  I used Ispy to generate the URL… when tested in the VLC player it works. Just wont show on the MM screen. I only get Loading RTSP Stream displayed or a black box.
                  R 1 Reply Last reply
                  • evroomE
                    evroom
                    Please see below.
                    I would first disable the module (disabled: true,) and restart MM.
                    Check if there are no omx_streams running (pm2 status).
                    Stop them when present (pm2 stop omx_stream1 / pm2 delete omx_stream1).
                    Then verify if omxplayer works standalone (use your own user & password & IP address).
                    If it does not work standalone, then there is no need to continue trying the module.
                    $ omxplayer --avdict rtsp_transport:tcp --win 85,65,725,425 --live --video_queue 4 --fps 30 --no-osd rtsp://user:password@192.168.178.55/axis-media/media.amp?resolution=640x360
                    If that works you can try this verified config (use your own user & password & IP address):
                    $ vi ~/MagicMirror/config/config.js
                        module: "MMM-RTSPStream",
                        //disabled: false,
                        disabled: true,
                        position: "middle_center",
                        header: "Axis Security Monitor",
                          autoStart: true,
                          rotateStreams: false,
                          moduleWidth: 640,
                          moduleHeight: 360,
                          localPlayer: 'omxplayer',
                          remotePlayer: 'none',
                          showSnapWhenPaused: false,
                          remoteSnaps: false,
                          stream1: {
                            url: 'rtsp://user:password@192.168.178.55/axis-media/media.amp?resolution=640x360',
                            frameRate: "30",
                            protocol: "tcp",
                            width: 640,
                            height: 360,
                            omxRestart: 1,
                            hwAccel: true,
                    This works for Axis P1448-LE, M2026-LE Mk II and M1125-E.
                    Good luck.
                    H W 2 Replies Last reply
                    • H
                      Hram2008 @evroom
                      @evroom
                      Thank you for the details, I am happy to report that the shared config also works for the Axis
                      Q3615. Thank you assist.
                      • W
                        warrendt @evroom
                        @evroom thanks for this, I am trying to get my vivotek cameras working,
                        omxplayer --avdict rtsp_transport:tcp --win 85,65,725,425 --live --video_queue 4 --fps 30 --no-osd rtsp://user:password@192.168.1.###/live1s3.sdp
                        This works great, and I see the feed perfect in the OMX player,
                        However, my config in the plugin doesn’t. I just get a black box. Any ideas would be appreciated.
                        			//disabled: false,
                        			//disabled: true,
                        			header: "Cameras",
                        				autoStart: true,
                        				moduleWidth: 640,
                        				moduleHeight: 480,
                        				remoteSnaps: false,
                        				stream1: {
                        					url: 'rtsp://user:password@192.168.1.###/live1s3.sdp',
                        					frameRate: "30",
                        					protocol: "tcp",
                        					width: 640,
                        					height: 480,
                        					omxRestart: 1,
                        					hwAccel: true,
                        evroomE 1 Reply Last reply
                        • evroomE
                          evroom @warrendt
                          @warrendt
                          Can you check following ?
                          Process omx_stream1 present:
                          $ pm2 status
                          $ ps -eaf | grep -v grep | grep omxplayer
                          Entries in pm2 log:
                          $ pm2 logs --lines 100
                          Might need to flush the logs and restart MM in order to show new RTSPStream log entries:
                          $ pm2 flush
                          $ pm2 restart MagicMirror
                          omxplayer version:
                          $ omxplayer -version
                          MMM-RTSPStream git status
                          $ cd ~/MagicMirror/modules/MMM-RTSPStream
                          $ git status
                          I am on the develop branch, you might need o switch to that too.
                          $ git checkout develop
                          $ npm install
                            rhopkins7428 @Hram2008
                            @Hram2008
                            TLDR, I switched from VLC to omxplayer and my previously working config started working again
                            I’m using hikvision cameras,
                            I was having a similar issue, migrating from an working configuration on an old PI3 to a new fresh image on PI4,
                            fresh Magic Mirror/ and MMM-RTSPStream install, copied original config over but both VLC windows black.
                            You can click pause on each window, (then shows correct window name) but when you resume it’s just black windows. I confirmed running VLC standalone, using the open network URL, pasted same URL in config and it worked fine. (Like I mentioned running on an older PI no problems)
                            Anyway, I changed player to omxplayer in the config and it worked immediately, not sure why VLC in MM not working…
                            my config:
                            module: “MMM-RTSPStream”,
                            position: “top_left”,
                            autoStart: true,
                            rotateStreamTimeout: 10,
                            moduleWidth: 354,
                            moduleHeight: 240,
                            localPlayer: ‘omxplayer’,
                            remotePlayer: ‘none’,
                            showSnapWhenPaused: true,
                            remoteSnaps: false,
                            shutdownDelay: 12,
                            stream1: {
                            url: ‘rtsp://admin:secret@10.99.98.101:554//Streaming/Channels/2’,
                            frameRate: ‘undefined’,
                            snapshotType: ‘url’,
                            snapshotRefresh: 10,
                            width: undefined,
                            height: undefined,
                            stream2: {
                            url: ‘rtsp://admin:secret@10.99.98.37:554//Streaming/Channels/2’,
                            width: undefined,
                            height: undefined,
                            • BKeyportB
                              Sometimes with this app you gotta jiggle the handle.
                              • bheplerB
                                bhepler Module Developer
                                This may be a bit weird, but I’m trying to install this on a non-RaspberryPi piece of hardware running Ubuntu 20. Is there a manual installation process that doesn’t require OMXPlayer?I realize that it will limit my options to VLC, but I’m willing to try. I’m getting caught up on it trying to install a player that isn’t available on Ubuntu.
                                I tried installing OMXPlayer through the Snap store, but because the hardware is AMD64, it’s not available.
                                • E
                                  Egnos
                                  Hi everyone,
                                  I believe that the MMM - RTSPStream module is incompatible with the MMM-Pages multi page module!
                                  By removing MMM-Pages, the RTSPStream module works again.
                                  The link for the video stream works correctly both with VLC and with the “omxplayer” command.
                                  The version of MM I am using is the latest available 2.14.0.
                                  The error I find in the console is the following:
                                  MMM-RTSPStream.js:164 MMM-RTSPStream has resumed... rotateStreams: true, autoStart: true
                                  MMM-RTSPStream.js:368 Uncaught TypeError: Cannot read property 'getBoundingClientRect' of null
                                      at Class.playStream (MMM-RTSPStream.js:368)
                                      at Class.rotateStream (MMM-RTSPStream.js:123)
                                      at Class.setupStreamRotation (MMM-RTSPStream.js:94)
                                      at Class.resumed (MMM-RTSPStream.js:168)
                                      at newCallback (MMM-RTSPStream.js:186)
                                      at main.js:324
                                  Here is my configuration:
                                  		   position: "bottom_right",
                                  		   header: "Test",
                                  			    //initialSetup: true,
                                  				autoStart: true,
                                  				moduleWidth: 354,
                                  				moduleHeight: 240,
                                  				remoteSnaps: false,
                                  				stream1: {
                                  					url: 'rtsp://xxxxxxxxxxx:xxxxxxxxx@xxx.xxx.x.xxx:554/stream1',
                                  					frameRate: 'undefined',
                                  					//width: undefined,
                                  					//height: undefined,
                                  In the “bottom_right” region what I see:
                                  alt text
                                  Have any of you noticed this incompatibility?
                                  Any advice / help is welcome.
                                  Thanks.
                                  BKeyportB JerryPJ 2 Replies Last reply
                                  • BKeyportB
                                    BKeyport Module Developer @Egnos
                                    @Egnos Don’t have a clue myself, and this module is no longer supported. :(
                                    • E
                                      Egnos @BKeyport
                                      @BKeyport thanks.
                                      Do you know any other module that can show the stream of surveillance cameras?
                                      Cr4z33C 1 Reply Last reply
                                      • Cr4z33C
                                        Cr4z33 @Egnos
                                        @Egnos as I wrote already some pages ago there’s MMM-FreeboxTV.
                                        Similar this module, but most of all it works.
                                        • E
                                          Egnos @Cr4z33
                                          @Cr4z33 many thanks.
                                          If I understand correctly the stream is started only if I ask the Google assistant to launch it, correct?
                                          • E
                                            Egnos
                                            …maybe I can use this “onStart” parameter to launch the stream that interests me at startup without asking the assistant.
                                            With this parameter it would also be possible to launch multiple streams at startup?
                                            Many thanks.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 29 / 31
