    602 Posts 67 Posters 2.4m Views 68 Watching
    • bheplerB
      bhepler Module Developer
      This may be a bit weird, but I’m trying to install this on a non-RaspberryPi piece of hardware running Ubuntu 20. Is there a manual installation process that doesn’t require OMXPlayer?I realize that it will limit my options to VLC, but I’m willing to try. I’m getting caught up on it trying to install a player that isn’t available on Ubuntu.
      I tried installing OMXPlayer through the Snap store, but because the hardware is AMD64, it’s not available.
      • E
        Egnos
        Hi everyone,
        I believe that the MMM - RTSPStream module is incompatible with the MMM-Pages multi page module!
        By removing MMM-Pages, the RTSPStream module works again.
        The link for the video stream works correctly both with VLC and with the “omxplayer” command.
        The version of MM I am using is the latest available 2.14.0.
        The error I find in the console is the following:
        MMM-RTSPStream.js:164 MMM-RTSPStream has resumed... rotateStreams: true, autoStart: true
        MMM-RTSPStream.js:368 Uncaught TypeError: Cannot read property 'getBoundingClientRect' of null
            at Class.playStream (MMM-RTSPStream.js:368)
            at Class.rotateStream (MMM-RTSPStream.js:123)
            at Class.setupStreamRotation (MMM-RTSPStream.js:94)
            at Class.resumed (MMM-RTSPStream.js:168)
            at newCallback (MMM-RTSPStream.js:186)
            at main.js:324
        Here is my configuration:
        		   module: "MMM-RTSPStream",
        		   position: "bottom_right",
        		   header: "Test",
        			    //initialSetup: true,
        				autoStart: true,
        				rotateStreamTimeout: 10,
        				moduleWidth: 354,
        				moduleHeight: 240,
        				localPlayer: 'omxplayer',
        				remotePlayer: 'none',
        				showSnapWhenPaused: false,
        				remoteSnaps: false,
        				stream1: {
        					url: 'rtsp://xxxxxxxxxxx:xxxxxxxxx@xxx.xxx.x.xxx:554/stream1',
        					frameRate: 'undefined',
        					//width: undefined,
        					//height: undefined,
        In the “bottom_right” region what I see:
        alt text
        Have any of you noticed this incompatibility?
        Any advice / help is welcome.
        Thanks.
        BKeyportB JerryPJ 2 Replies Last reply
        • BKeyportB
          BKeyport Module Developer @Egnos
          @Egnos Don’t have a clue myself, and this module is no longer supported. :(
          E 1 Reply Last reply
          • E
            Egnos @BKeyport
            @BKeyport thanks.
            Do you know any other module that can show the stream of surveillance cameras?
            Cr4z33C 1 Reply Last reply
            • Cr4z33C
              Cr4z33 @Egnos
              @Egnos as I wrote already some pages ago there’s MMM-FreeboxTV.
              Similar this module, but most of all it works.
              • E
                Egnos @Cr4z33
                @Cr4z33 many thanks.
                If I understand correctly the stream is started only if I ask the Google assistant to launch it, correct?
                • E
                  Egnos
                  …maybe I can use this “onStart” parameter to launch the stream that interests me at startup without asking the assistant.
                  With this parameter it would also be possible to launch multiple streams at startup?
                  Many thanks.
                  • Cr4z33C
                    Cr4z33 @Egnos
                    @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                    It’s up to you.
                    Either have it streaming 24/7 or upon command. :)
                    D 1 Reply Last reply
                      drx1984 @Cr4z33
                      @Cr4z33 how does a config look like with MMM-FreeboxTV?
                      can I insert a link under stream: rtsp-stream?
                      • Cr4z33C
                        Cr4z33 @drx1984
                        @drx1984 find out by yourself and… happy studying. ;)
                        https://github.com/bugsounet/MMM-FreeboxTV/
                          drx1984 @Cr4z33
                          @Cr4z33 Unfortunately it does not work. can you help me?
                          is the MMM-RTSPstream module no longer functional?
                          BKeyportB 1 Reply Last reply
                          • BKeyportB
                            BKeyport Module Developer @drx1984
                            @drx1984 Consider it abandonware… It’s dead.
                              Sh4wn9
                              Im using the module with ffmpeg, everything is working fine until i try and use MMM-ModuleSchedule. The module will hide no problem but when its time to show the module i get just a grey screen where the stream should be. If anyone could help i can provide whatever logs needed. I have just done a fresh install as of yesterday…
                              • BKeyportB
                                BKeyport Module Developer @Sh4wn9
                                @Sh4wn9 I believe that using any sort of hiding breaks the module, long standing bug.
                                • JerryPJ
                                  JerryP @Egnos
                                  Hi everyone,
                                      at main.js:324
                                  		   header: "Test",
                                  				autoStart: true,
                                  				moduleWidth: 354,
                                  				moduleHeight: 240,
                                  				remoteSnaps: false,
                                  				stream1: {
                                  					//width: undefined,
                                  alt text
                                  Thanks.
                                  Goodmorning, I belive.
                                  rtsp://gebruikersnaam:wachtwoord@IPCAM:554/cam/realmonitor?channel=1&subtype=2
                                  Pleas run this line in a VLC player. if you can see the camera screen than you know that the connection is oke.
                                  After that we kan see what’s wrong whit the config.js
                                  bur first check if you see the camera feet…
                                  pleas
                                  Whits type camera you use???
                                  Jerry frome Holland
                                  • E
                                    Egnos @JerryP
                                    @JerryP thank you for answering me!
                                    The stream is ok, I think the problem is the coexistence between MMM-Pages and this module. For now I have managed using the omxplayer command which he launched from the terminal outside of MM.
                                    • BKeyportB
                                      @Egnos that’s the best method, it seems. Only way i can keep my streams from crashing.
                                        sophia787
                                        Sorry at this time I don’t have any solution.
                                        https://racketsblog.com/best-tennis-rackets/
                                          Plainbroke 0
                                          I understand that the developer of this module is not supporting it, but
                                          I see a lot of people are using it or at least trying to…
                                          I have it working with 3 Wyze v2 cams, using omxplayer.
                                          I would like to see if using vlc would possibly fix the lag time loading the cam output… I have a approximately 10 second lag between module start up and the picture actually showing up…
                                          Problem is when I change the localPlayer: to vlc from omxplayer I get a blank screen screen. I reinstalled vlc player to my rpi but can not figure out how to get it to load vlc. I use carousel and have approx 35 different modules working through it… I tried pm2 start vlc and it did but still did not show a feed.
                                          I posted my config.js minus keys and passwords of course. Any help is appreciated…
                                          /* Magic Mirror Config Sample
                                           * MIT Licensed.
                                          var config = {
                                          	address: "0.0.0.0", // Address to listen on, can be:
                                          	port: 8080,
                                          	ipWhitelist: [], // Set [] to allow all IP addresses
                                          	useHttps: false, // Support HTTPS or not, default "false"
                                          	language: "en",
                                          	timeFormat: 12,
                                          	units: "imperial",
                                          			module: "MMM-Carousel",
                                          				transitionInterval: 53000,
                                          				ignoreModules: ["MMM-Snow"],
                                          				mode: "slides",
                                          				slides: [
                                          					["MMM-CalendarExt"],
                                          					["calendar", "clock", "compliments"],
                                          					["calendarH", "clock", "compliments"],
                                          //					["calendarN", "clock", "compliments"],
                                          					["iFrame"],
                                          					["MMM-ATM", "clock", "compliments"],
                                          					["MMM-BMI", "clock", "compliments"],
        ["MMM-RTSPStream"],
                                          					["MMM-Bored", "clock", "compliments"],
                                          					["MMM-CalvinAndHobbes", "clock", "compliments"],
                                          					["MMM-CloneWarsQuotes", "clock", "compliments"],
                                          					["MMM-Cocktails"],
                                          					["MMM-COVID19", "clock", "compliments"],
                                          					["MMM-DailyQuote", "clock", "compliments"],
                                          					["MMM-DarkSkyForecast", "clock", "compliments"],
                                          					["MMM-Dogs", "clock", "compliments"],
                                          					["MMM-Evil", "clock", "compliments"],
                                          					["MMM-Gas", "clock", "compliments"],
                                          					["MMM-GmailFeed", "clock", "compliments"],
                                          					["MMM-History", "clock", "compliments"],
        ["MMM-RTSPStream2"],
                                          					["MMM-icanhazdadjoke", "clock", "compliments"],
                                          					["MMM-ImagesPhotos", "clock", "compliments"],
                                          					["MMM-learnlanguage", "clock", "compliments"],
                                          					["MMM-MotionEye"],
                                          					["MMM-MyWordOfTheDay", "clock", "compliments"],
                                          					["MMM-NetworkScanner"],
                                          					["MMM-Parcel", "clock", "compliments"],
                                          					["MMM-PoemOfTheDay"],
                                          					["MMM-quote-of-the-day", "clock", "compliments"],
                                          					["MMM-RAIN-MAP"],
                                          					["MMM-rfacts", "clock", "compliments"],
                                          					["MMM-RTSPStream3"],
                                          					["MMM-SimpleLogo", "clock", "compliments"],
                                          					["MMM-SugarValue", "clock", "compliments"],
                                          					["on-this-day", "clock", "compliments"],
                                          					["random_quotes", "clock", "compliments"]
                                          			module: "clock",
                                          			classes: "clock-time-only",
                                          				timeFormat: 12,
                                          				displaySeconds: false,
                                          				showPeriodUpper: false,
                                          				showPeriod: false
                                          			module: "clock",
                                          			position: "top_center",
                                          			classes: "clock-date-only",
                                          				timeFormat: 12,
                                          				showPeriod: false,
                                          				dateFormat: "ddd, ll",
                                          			module: "clock",
                                          				timeFormat: 12,
                                          				showPeriod: false
        position: "middle_center",
        header: "Birthdays",
        fade: false,
        maximumEntries: 9,
        timeFormat: "absolute",
        urgency: 3,
        getRelative: 24,
        symbol: "birthday-cake",
        url: ""
        module: "calendarH",
        header: "US Holidays",
        maximumEntries: 9,
        urgency: 3,
        getRelative: 24,
        symbol: "h-square",
        url:""
        module: "calendarN",
        header: "Nascar",
        maximumEntries: 9,
        urgency: 3,
        getRelative: 24,
        symbol: "automobile",
        url: ""
        module: "compliments",
        position: "bottom_bar",
        remoteFile: "compliments.json"
                                          	                module: "iFrame",
        url: "",
        width: "1000px",
        height: "950px"
                                          			module: "MMM-ATM",
                                          				multipleChoice: "Yes",
                                          				useHeader: false,
                                          				header: "Another Trivia Module!",
                                          				maxWidth: "1240px"
                                          			module: "MMM-BMI",
                                          				imperialUnits: true,
                                          				weight: "250",
                                          				height: "73",
                                          				herName: "Stacey",
                                          				herWeight: "140",
                                          				herHeight: "67",
                                          				useHeader: false,
                                          				header: "Our Body Mass Index",
                                          				maxWidth: "1000px"
                                          			module: "MMM-Bored",
                                          				maxWidth: "1310px"
                                          			module: "MMM-CalendarExt",
                                                              maxHeight: "100%",
                                                              maxWidth: "100%",
                                          				system: {
                                          					show: ["month"],
                                          					locale: "en",
                                          					showEmptyView: 1,
                                          					fullDayEventLocalize: 0,
                                          					redrawInterval: 1 * 60 * 1000,
                                          					useProfileConfig: 0,
                                          					startProfile: "Birthdays",
                                          				defaultView: {
                                          					positionOrder: 1,
                                          					overflowRolling: 0,
                                          					overflowHeight: 300,
                                          					overflowDuration: 3,
                                          					onlyStartingTime: 0,
                                          					timeFormat: "h:mm a",
                                          					dateFormat: "ddd, M/D",
                                          					fullDayEventDateFormat: "ddd, M/D",
                                          					ellipsis: 0,
                                          					limit: 0,
                                          				views: {
                                          					month: {
                                          						showWeeks: 0,
                                          				defaultCalendar: {
                                          					profiles: [],
                                          					views: ["month", "upcoming"],
                                          					symbol: "cake-variant@md",
                                          					styleName: "style5",
                                          					replaceTitle: [],
                                          					classPattern: [],
                                          					classPatternWhere: ["title"],
                                          					symbolPattern: [],
                                          					symbolPatternWhere: ["title"],
                                          					maxEntries: 90,
                                          					maxDays: 365,
                                          					interval: 300000,
                                          						url: "webcal://ical.mac.com/ical/US32Holidays.ics",
                                          						profile: [""],
                                          						symbol: "pine-tree@md",
                                          						url: "",
                                          						profile: [""],
                                          			module: "MMM-CalvinAndHobbes",
                                          			        invertColors: false,
                                          			        grayScale: false,
                                          			        updateInterval: 1000 * 60 * 60 * 2, // 2 Hr
        maxWidth: "100%",
        maxHieght: "100%"
                                          			module: "MMM-CloneWarsQuotes",
                                          			module: "MMM-Cocktails",
                                          				maxHeight: "100%",
                                          				maxWidth: "100%"
                                          			module: "MMM-COVID19",
                                          				header: "",
                                          				updateInterval: 300000,
                                          				worldStats: true,
                                          				delta: true,
                                          				lastUpdateInfo: true,
                                          				countries: [  "Mexico", "United Kingdom", "Italy", "Asia", "Africa", "Spain", "USA" ],
                                          				headerRowClass: "small",
                                          				rapidapiKey : ""
                                          			module: "MMM-DailyQuote",
                                          				updateInterval: 1*60*60*1000,
                                          			module: "MMM-DarkSkyForecast",
                                          			classes: "default everyone",
                                          			disabled: false,
                                          				header: "",
                                          				apikey: "",
                                          				latitude: "",
                                          				longitude: "",
                                          				iconset: "3c",
                                          				maxHourliesToShow: 1,
                                          				concise: false,
                                          				forecastLayout: "table"
                                          			disabled: false,
                                          			module: "MMM-Dogs",
                                          				updateInterval: 35 * 60 * 1000,
        maxHeight: "475px",
        maxWidth: "700px"
        disabled: false,
        module: "MMM-Evil",
        maxHeight: "300px",
        maxWidth: "1320px"
                                          			module: "MMM-Gas",
                                          				zip : "",
                                          				typeGas: "",
                                          				sortBy: "price",
                                          				items: 12,
                                          				distance: true
                                          			module: "MMM-GmailFeed",
                                          				username: "",
                                          				password: "",
                                          				header: false,
                                          				updateInterval: 60000,
                                          				maxEmails: 8,
                                          				maxSubjectLength: 30,
                                          				maxFromLength: 12,
                                          				playSound: false
                                          			module: "MMM-History",
                                          				maxWidth: "1320px"
                                          			module: "MMM-icanhazdadjoke",
                                          				maxWidth: "100%"
                                          			module: "MMM-ImagesPhotos",
                                          				opacity: 0.9,
                                          				animationSpeed: 500,
                                          				updateInterval: 2000,
                                          				backgroundColor: "black",
                                          				width: "500px",
                                          				height: "500px",
                                          				fill: false
                                          			module: "MMM-learnlanguage",
                                          				language: "spanish",
                                          				nextWordInterval: 2160000,
        showpair: "showboth",
                                          			module: "MMM-MotionEye",
                                          				url: "",
                                          				forcedRefreshInterval: 60000,
                                          				width: "1000px",
                                          				debug: false
                                          			module: "MMM-MyWordOfTheDay",
                                          				header: "Word Of The Day",
                                          				apiKey: "",
        width: "1320px",
        height: "505px"
                                          			module: "MMM-NetworkScanner",
                                          			header: "Who's home",
                                          				devices: [
                                          					{ macAddress: "", name: "00 Stacey", icon: "female" },
                                          					{ macAddress: "", name: "00 Jeff", icon: "male" },
                                          					{ macAddress: "", name: "01 Netgear M1", icon: "server" },
                                          					{ macAddress: "", name: "03 Ubiquiti", icon: "wifi" },
                                          					{ macAddress: "", name: "04 Omada EAP225", icon: "wifi" },
                                          					{ macAddress: "", name: "224 PiHole", icon: "server" },
                                          					{ macAddress: "", name: "30 WyzeBridge", icon: "wifi" },
                                          					{ macAddress: "", name: "31 WyzeCam1 Garage", icon: "camera" },
                                          					{ macAddress: "", name: "32 WyzeCam2", icon: "camera" },
                                          					{ macAddress: "", name: "33 WyzeCam3South", icon: "camera" },
                                                              { macAddress: "", name: "34 WyzeCam4", icon: "camera" },
                                          				network: "192.168.1.0/24",
                                          				showUnknown: false,
                                          				showOffline: false, // shows devices specified in the 'devices' option even when offline
                                          				showLastSeen: false, // shows when the device was last seen e.g. "Device Name - last seen 5 minutes ago"
                                                          		keepAlive: 400, // how long (in seconds) a device should be considered 'alive' since it was last found on the network
                                          	             		updateInterval: 1500, // how often (in seconds) the module should scan the network
                                                          		sort: true, // sort the devices in the mirror
                                                          		colored: false, // show devices colorcoded with color defined in devices [] //
                                                          		coloredSymbolOnly: false, // show symbol only in color //
                                          				maxWidth: "100%",
                                          				maxHieght: "100%"
                                          			module: "MMM-Parcel",
                                          				header: "",
                                          				maxWidth: "1320px",
                                          				apiKey: "",
                                          				autoTranslate : "en",
                                          				compactness: 2,
                                          				hideExpired: true, // don't show expired parcels
                                          				hideDelivered: true
                                          			module: "MMM-PoemOfTheDay",
                                          				textLimit: 1000,
                                          				lineLimit: 10,
                                          				detectLanguageApiKey: "",
                                          				languageSet: ["en"],
                                          			module: "MMM-quote-of-the-day",
                                          				language: "en",
                                          				updateInterval: "10m"
                                          			module: "MMM-RAIN-MAP",
                                          				animationSpeed: 600,
                                          				displayClockSymbol: true,
                                          				displayTime: true,
                                          				extraDelayLastFrame: 2000,
                                          				height: "750px",
                                          				lat: ,
                                          				lng: ,
                                          				map: "OSM",
                                          				markers: [
                                          					{ lat: , lng: -, color: "red" },
                                          					{ lat: , lng: -, color: "blue" }
                                          					onlyOnRain: false,
                                          					opacity: 1, //0 to 1 .65 default
                                          					timeFormat: 12,
                                          					updateIntervalInSeconds: 300,
                                          					width: "1240px",
                                          					zoom: 8,
                                          					zoomOutEach: 1,
                                          					zoomOutLevel: 3,
                                          			module: "MMM-rfacts",
                                          				updateInterval: 30 * 60 * 1000,
                                          				maxHeight: "505px",
                                          				maxWidth: "1310px"
                                          				autoStart: true,
                                          				rotateStreamTimeout: 0,
                                          				moduleWidth: 1240,
                                          				moduleHeight: 700,
                                          				localPlayer: "vlc",
                                          				remotePlayer: "none",
                                          				remoteSnaps: false,
        stream1: {
        url: "rtsp://xxxxx:xxxxx@192.168.1.31:554/live",
        frameRate: "15",
        width: 1240,
        height: 700,
        module: "MMM-RTSPStream2",
        autoStart: true,
        moduleWidth: 1240,
        moduleHeight: 700,
        localPlayer: "vlc",
        remoteSnaps: false,
        stream1: {
        url: "rtsp://xxxxx:xxxxx@192.168.1.32:554/live",
        frameRate: "15",
        width: 1240,
        height: 700,
        module: "MMM-RTSPStream3",
        autoStart: true,
        moduleWidth: 1240,
        moduleHeight: 700,
        localPlayer: "vlc",
        remoteSnaps: false,
        stream1: {
        url: "rtsp://xxxxx:xxxxx@192.168.1.33:554/live",
        frameRate: "15",
        width: 1240,
        height: 700,
                                          			module: "MMM-SimpleLogo",
                                          			position: "middle_center", // This can be any of the regions.
                                          				maxHeight: "490px",
                                          				maxWidth: "1240px",
                                          				refreshInterval: 10000,
                                          				text: ""
                                          			module: "MMM-Snow",
                                          			position: "fullscreen_above",
                                          				flakeCount: 200,
                                          				theme: "winter" //"water" //"winter" //"love"
                                          			module: "MMM-SugarValue",
                                          				username: "",
                                          				password: "",
                                          				units: "mg",
                                          		                height: "505px",
                                                          		width: "1320px"
                                          			module: "on-this-day",
                                          				updateInterval: 10 * 1000 * 60
                                          			module: "random_quotes",
                                            Biebermann
                                            Hello, is the module still maintained or not?
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 30 / 31
