    602 Posts 67 Posters 2.2m Views 68 Watching
    • E Offline
      Egnos @BKeyport
      @BKeyport thanks.
      Do you know any other module that can show the stream of surveillance cameras?
      • Cr4z33C Offline
        Cr4z33 @Egnos
        @Egnos as I wrote already some pages ago there’s MMM-FreeboxTV.
        Similar this module, but most of all it works.
        • E Offline
          Egnos @Cr4z33
          @Cr4z33 many thanks.
          If I understand correctly the stream is started only if I ask the Google assistant to launch it, correct?
          • E Offline
            Egnos
            …maybe I can use this “onStart” parameter to launch the stream that interests me at startup without asking the assistant.
            With this parameter it would also be possible to launch multiple streams at startup?
            Many thanks.
            • Cr4z33C Offline
              Cr4z33 @Egnos
              @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              It’s up to you.
              Either have it streaming 24/7 or upon command. :)
                drx1984 @Cr4z33
                @Cr4z33 how does a config look like with MMM-FreeboxTV?
                can I insert a link under stream: rtsp-stream?
                • Cr4z33C Offline
                  Cr4z33 @drx1984
                  @drx1984 find out by yourself and… happy studying. ;)
                  https://github.com/bugsounet/MMM-FreeboxTV/
                    drx1984 @Cr4z33
                    @Cr4z33 Unfortunately it does not work. can you help me?
                    is the MMM-RTSPstream module no longer functional?
                    • BKeyportB Offline
                      BKeyport Module Developer @drx1984
                      @drx1984 Consider it abandonware… It’s dead.
                        Sh4wn9
                        Im using the module with ffmpeg, everything is working fine until i try and use MMM-ModuleSchedule. The module will hide no problem but when its time to show the module i get just a grey screen where the stream should be. If anyone could help i can provide whatever logs needed. I have just done a fresh install as of yesterday…
                        • BKeyportB Offline
                          BKeyport Module Developer @Sh4wn9
                          @Sh4wn9 I believe that using any sort of hiding breaks the module, long standing bug.
                          • JerryPJ Offline
                            JerryP @Egnos
                            Hi everyone,
                            I believe that the MMM - RTSPStream module is incompatible with the MMM-Pages multi page module!
                            By removing MMM-Pages, the RTSPStream module works again.
                            The link for the video stream works correctly both with VLC and with the “omxplayer” command.
                            The version of MM I am using is the latest available 2.14.0.
                            The error I find in the console is the following:
                            MMM-RTSPStream.js:164 MMM-RTSPStream has resumed... rotateStreams: true, autoStart: true
                            MMM-RTSPStream.js:368 Uncaught TypeError: Cannot read property 'getBoundingClientRect' of null
                                at Class.playStream (MMM-RTSPStream.js:368)
                                at Class.rotateStream (MMM-RTSPStream.js:123)
                                at Class.setupStreamRotation (MMM-RTSPStream.js:94)
                                at Class.resumed (MMM-RTSPStream.js:168)
                                at newCallback (MMM-RTSPStream.js:186)
                                at main.js:324
                            Here is my configuration:
                            		   module: "MMM-RTSPStream",
                            		   position: "bottom_right",
                            		   header: "Test",
                            			    //initialSetup: true,
                            				autoStart: true,
                            				rotateStreamTimeout: 10,
                            				moduleWidth: 354,
                            				moduleHeight: 240,
                            				localPlayer: 'omxplayer',
                            				remotePlayer: 'none',
                            				showSnapWhenPaused: false,
                            				remoteSnaps: false,
                            				stream1: {
                            					url: 'rtsp://xxxxxxxxxxx:xxxxxxxxx@xxx.xxx.x.xxx:554/stream1',
                            					frameRate: 'undefined',
                            					//width: undefined,
                            					//height: undefined,
                            In the “bottom_right” region what I see:
                            alt text
                            Have any of you noticed this incompatibility?
                            Any advice / help is welcome.
                            Thanks.
                            Goodmorning, I belive.
                            rtsp://gebruikersnaam:wachtwoord@IPCAM:554/cam/realmonitor?channel=1&subtype=2
                            Pleas run this line in a VLC player. if you can see the camera screen than you know that the connection is oke.
                            After that we kan see what’s wrong whit the config.js
                            bur first check if you see the camera feet…
                            pleas
                            Whits type camera you use???
                            Jerry frome Holland
                            • E Offline
                              Egnos @JerryP
                              @JerryP thank you for answering me!
                              The stream is ok, I think the problem is the coexistence between MMM-Pages and this module. For now I have managed using the omxplayer command which he launched from the terminal outside of MM.
                              • BKeyportB Offline
                                BKeyport Module Developer @Egnos
                                @Egnos that’s the best method, it seems. Only way i can keep my streams from crashing.
                                  sophia787
                                  Sorry at this time I don’t have any solution.
                                  https://racketsblog.com/best-tennis-rackets/
                                    Plainbroke 0
                                    I understand that the developer of this module is not supporting it, but
                                    I see a lot of people are using it or at least trying to…
                                    I have it working with 3 Wyze v2 cams, using omxplayer.
                                    I would like to see if using vlc would possibly fix the lag time loading the cam output… I have a approximately 10 second lag between module start up and the picture actually showing up…
                                    Problem is when I change the localPlayer: to vlc from omxplayer I get a blank screen screen. I reinstalled vlc player to my rpi but can not figure out how to get it to load vlc. I use carousel and have approx 35 different modules working through it… I tried pm2 start vlc and it did but still did not show a feed.
                                    I posted my config.js minus keys and passwords of course. Any help is appreciated…
                                    /* Magic Mirror Config Sample
                                     * MIT Licensed.
                                    var config = {
                                    	address: "0.0.0.0", // Address to listen on, can be:
                                    	port: 8080,
                                    	ipWhitelist: [], // Set [] to allow all IP addresses
                                    	useHttps: false, // Support HTTPS or not, default "false"
                                    	language: "en",
                                    	timeFormat: 12,
                                    	units: "imperial",
                                    			module: "MMM-Carousel",
                                    				transitionInterval: 53000,
                                    				ignoreModules: ["MMM-Snow"],
                                    				mode: "slides",
                                    				slides: [
                                    					["MMM-CalendarExt"],
                                    					["calendar", "clock", "compliments"],
                                    					["calendarH", "clock", "compliments"],
                                    //					["calendarN", "clock", "compliments"],
                                    					["iFrame"],
                                    					["MMM-ATM", "clock", "compliments"],
                                    					["MMM-BMI", "clock", "compliments"],
        ["MMM-RTSPStream"],
                                    					["MMM-Bored", "clock", "compliments"],
                                    					["MMM-CalvinAndHobbes", "clock", "compliments"],
                                    					["MMM-CloneWarsQuotes", "clock", "compliments"],
                                    					["MMM-Cocktails"],
                                    					["MMM-COVID19", "clock", "compliments"],
                                    					["MMM-DailyQuote", "clock", "compliments"],
                                    					["MMM-DarkSkyForecast", "clock", "compliments"],
                                    					["MMM-Dogs", "clock", "compliments"],
                                    					["MMM-Evil", "clock", "compliments"],
                                    					["MMM-Gas", "clock", "compliments"],
                                    					["MMM-GmailFeed", "clock", "compliments"],
                                    					["MMM-History", "clock", "compliments"],
        ["MMM-RTSPStream2"],
                                    					["MMM-icanhazdadjoke", "clock", "compliments"],
                                    					["MMM-ImagesPhotos", "clock", "compliments"],
                                    					["MMM-learnlanguage", "clock", "compliments"],
                                    					["MMM-MotionEye"],
                                    					["MMM-MyWordOfTheDay", "clock", "compliments"],
                                    					["MMM-NetworkScanner"],
                                    					["MMM-Parcel", "clock", "compliments"],
                                    					["MMM-PoemOfTheDay"],
                                    					["MMM-quote-of-the-day", "clock", "compliments"],
                                    					["MMM-RAIN-MAP"],
                                    					["MMM-rfacts", "clock", "compliments"],
                                    					["MMM-RTSPStream3"],
                                    					["MMM-SimpleLogo", "clock", "compliments"],
                                    					["MMM-SugarValue", "clock", "compliments"],
                                    					["on-this-day", "clock", "compliments"],
                                    					["random_quotes", "clock", "compliments"]
                                    			module: "clock",
                                    			classes: "clock-time-only",
                                    				timeFormat: 12,
                                    				displaySeconds: false,
                                    				showPeriodUpper: false,
                                    				showPeriod: false
                                    			module: "clock",
                                    			position: "top_center",
                                    			classes: "clock-date-only",
                                    				timeFormat: 12,
                                    				showPeriod: false,
                                    				dateFormat: "ddd, ll",
                                    			module: "clock",
                                    				timeFormat: 12,
                                    				showPeriod: false
                                                            position: "middle_center",
                                                            header: "Birthdays",
        fade: false,
        maximumEntries: 9,
        timeFormat: "absolute",
        urgency: 3,
        getRelative: 24,
        symbol: "birthday-cake",
        url: ""
                                                            module: "calendarH",
                                                            header: "US Holidays",
        maximumEntries: 9,
        urgency: 3,
        getRelative: 24,
        symbol: "h-square",
        url:""
                                                            module: "calendarN",
                                                            header: "Nascar",
        maximumEntries: 9,
        urgency: 3,
        getRelative: 24,
        symbol: "automobile",
        url: ""
                                                            module: "compliments",
                                                            position: "bottom_bar",
        remoteFile: "compliments.json"
                                    	                module: "iFrame",
        url: "",
        width: "1000px",
        height: "950px"
                                    			module: "MMM-ATM",
                                    				multipleChoice: "Yes",
                                    				useHeader: false,
                                    				header: "Another Trivia Module!",
                                    				maxWidth: "1240px"
                                    			module: "MMM-BMI",
                                    				imperialUnits: true,
                                    				weight: "250",
                                    				height: "73",
                                    				herName: "Stacey",
                                    				herWeight: "140",
                                    				herHeight: "67",
                                    				useHeader: false,
                                    				header: "Our Body Mass Index",
                                    				maxWidth: "1000px"
                                    			module: "MMM-Bored",
                                    				maxWidth: "1310px"
                                    			module: "MMM-CalendarExt",
                                                        maxHeight: "100%",
                                                        maxWidth: "100%",
                                    				system: {
                                    					show: ["month"],
                                    					locale: "en",
                                    					showEmptyView: 1,
                                    					fullDayEventLocalize: 0,
                                    					redrawInterval: 1 * 60 * 1000,
                                    					useProfileConfig: 0,
                                    					startProfile: "Birthdays",
                                    				defaultView: {
                                    					positionOrder: 1,
                                    					overflowRolling: 0,
                                    					overflowHeight: 300,
                                    					overflowDuration: 3,
                                    					onlyStartingTime: 0,
                                    					timeFormat: "h:mm a",
                                    					dateFormat: "ddd, M/D",
                                    					fullDayEventDateFormat: "ddd, M/D",
                                    					ellipsis: 0,
                                    					limit: 0,
                                    				views: {
                                    					month: {
                                    						showWeeks: 0,
                                    				defaultCalendar: {
                                    					profiles: [],
                                    					views: ["month", "upcoming"],
                                    					symbol: "cake-variant@md",
                                    					styleName: "style5",
                                    					replaceTitle: [],
                                    					classPattern: [],
                                    					classPatternWhere: ["title"],
                                    					symbolPattern: [],
                                    					symbolPatternWhere: ["title"],
                                    					maxEntries: 90,
                                    					maxDays: 365,
                                    					interval: 300000,
                                    						url: "webcal://ical.mac.com/ical/US32Holidays.ics",
                                    						profile: [""],
                                    						symbol: "pine-tree@md",
                                    						url: "",
                                    						profile: [""],
                                    			module: "MMM-CalvinAndHobbes",
                                    			        invertColors: false,
                                    			        grayScale: false,
                                    			        updateInterval: 1000 * 60 * 60 * 2, // 2 Hr
        maxWidth: "100%",
        maxHieght: "100%"
                                    			module: "MMM-CloneWarsQuotes",
                                    			module: "MMM-Cocktails",
                                    				maxHeight: "100%",
                                    				maxWidth: "100%"
                                    			module: "MMM-COVID19",
                                    				header: "",
                                    				updateInterval: 300000,
                                    				worldStats: true,
                                    				delta: true,
                                    				lastUpdateInfo: true,
                                    				countries: [  "Mexico", "United Kingdom", "Italy", "Asia", "Africa", "Spain", "USA" ],
                                    				headerRowClass: "small",
                                    				rapidapiKey : ""
                                    			module: "MMM-DailyQuote",
                                    				updateInterval: 1*60*60*1000,
                                    			module: "MMM-DarkSkyForecast",
                                    			classes: "default everyone",
                                    			disabled: false,
                                    				header: "",
                                    				apikey: "",
                                    				latitude: "",
                                    				longitude: "",
                                    				iconset: "3c",
                                    				maxHourliesToShow: 1,
                                    				concise: false,
                                    				forecastLayout: "table"
                                    			disabled: false,
                                    			module: "MMM-Dogs",
                                    				updateInterval: 35 * 60 * 1000,
        maxHeight: "475px",
        maxWidth: "700px"
                                                            disabled: false,
                                                            module: "MMM-Evil",
        maxHeight: "300px",
        maxWidth: "1320px"
                                    			module: "MMM-Gas",
                                    				zip : "",
                                    				typeGas: "",
                                    				sortBy: "price",
                                    				items: 12,
                                    				distance: true
                                    			module: "MMM-GmailFeed",
                                    				username: "",
                                    				password: "",
                                    				header: false,
                                    				updateInterval: 60000,
                                    				maxEmails: 8,
                                    				maxSubjectLength: 30,
                                    				maxFromLength: 12,
                                    				playSound: false
                                    			module: "MMM-History",
                                    				maxWidth: "1320px"
                                    			module: "MMM-icanhazdadjoke",
                                    				maxWidth: "100%"
                                    			module: "MMM-ImagesPhotos",
                                    				opacity: 0.9,
                                    				animationSpeed: 500,
                                    				updateInterval: 2000,
                                    				backgroundColor: "black",
                                    				width: "500px",
                                    				height: "500px",
                                    				fill: false
                                    			module: "MMM-learnlanguage",
                                    				language: "spanish",
                                    				nextWordInterval: 2160000,
                                    		                    showpair: "showboth",
                                    			module: "MMM-MotionEye",
                                    				url: "",
                                    				forcedRefreshInterval: 60000,
                                    				width: "1000px",
                                    				debug: false
                                    			module: "MMM-MyWordOfTheDay",
                                    				header: "Word Of The Day",
                                    				apiKey: "",
        width: "1320px",
        height: "505px"
                                    			module: "MMM-NetworkScanner",
                                    			header: "Who's home",
                                    				devices: [
                                    					{ macAddress: "", name: "00 Stacey", icon: "female" },
                                    					{ macAddress: "", name: "00 Jeff", icon: "male" },
                                    					{ macAddress: "", name: "01 Netgear M1", icon: "server" },
                                    					{ macAddress: "", name: "03 Ubiquiti", icon: "wifi" },
                                    					{ macAddress: "", name: "04 Omada EAP225", icon: "wifi" },
                                    					{ macAddress: "", name: "224 PiHole", icon: "server" },
                                    					{ macAddress: "", name: "30 WyzeBridge", icon: "wifi" },
                                    					{ macAddress: "", name: "31 WyzeCam1 Garage", icon: "camera" },
                                    					{ macAddress: "", name: "32 WyzeCam2", icon: "camera" },
                                    					{ macAddress: "", name: "33 WyzeCam3South", icon: "camera" },
                                                        { macAddress: "", name: "34 WyzeCam4", icon: "camera" },
                                    				network: "192.168.1.0/24",
                                    				showUnknown: false,
                                    				showOffline: false, // shows devices specified in the 'devices' option even when offline
                                    				showLastSeen: false, // shows when the device was last seen e.g. "Device Name - last seen 5 minutes ago"
                                                    		keepAlive: 400, // how long (in seconds) a device should be considered 'alive' since it was last found on the network
                                    	             		updateInterval: 1500, // how often (in seconds) the module should scan the network
                                                    		sort: true, // sort the devices in the mirror
                                                    		colored: false, // show devices colorcoded with color defined in devices [] //
                                                    		coloredSymbolOnly: false, // show symbol only in color //
                                    				maxWidth: "100%",
                                    				maxHieght: "100%"
                                    			module: "MMM-Parcel",
                                    				header: "",
                                    				maxWidth: "1320px",
                                    				apiKey: "",
                                    				autoTranslate : "en",
                                    				compactness: 2,
                                    				hideExpired: true, // don't show expired parcels
                                    				hideDelivered: true
                                    			module: "MMM-PoemOfTheDay",
                                    				textLimit: 1000,
                                    				lineLimit: 10,
                                    				detectLanguageApiKey: "",
                                    				languageSet: ["en"],
                                    			module: "MMM-quote-of-the-day",
                                    				language: "en",
                                    				updateInterval: "10m"
                                    			module: "MMM-RAIN-MAP",
                                    				animationSpeed: 600,
                                    				displayClockSymbol: true,
                                    				displayTime: true,
                                    				extraDelayLastFrame: 2000,
                                    				height: "750px",
                                    				lat: ,
                                    				lng: ,
                                    				map: "OSM",
                                    				markers: [
                                    					{ lat: , lng: -, color: "red" },
                                    					{ lat: , lng: -, color: "blue" }
                                    					onlyOnRain: false,
                                    					opacity: 1, //0 to 1 .65 default
                                    					timeFormat: 12,
                                    					updateIntervalInSeconds: 300,
                                    					width: "1240px",
                                    					zoom: 8,
                                    					zoomOutEach: 1,
                                    					zoomOutLevel: 3,
                                    			module: "MMM-rfacts",
                                    				updateInterval: 30 * 60 * 1000,
                                    				maxHeight: "505px",
                                    				maxWidth: "1310px"
                                    				autoStart: true,
                                    				rotateStreamTimeout: 0,
                                    				moduleWidth: 1240,
                                    				moduleHeight: 700,
                                    				localPlayer: "vlc",
                                    				remotePlayer: "none",
                                    				remoteSnaps: false,
        stream1: {
        url: "rtsp://xxxxx:xxxxx@192.168.1.31:554/live",
        frameRate: "15",
        width: 1240,
        height: 700,
                                                            module: "MMM-RTSPStream2",
        autoStart: true,
        moduleWidth: 1240,
        moduleHeight: 700,
        localPlayer: "vlc",
        remoteSnaps: false,
        stream1: {
        url: "rtsp://xxxxx:xxxxx@192.168.1.32:554/live",
        frameRate: "15",
        width: 1240,
        height: 700,
                                                            module: "MMM-RTSPStream3",
        autoStart: true,
        moduleWidth: 1240,
        moduleHeight: 700,
        localPlayer: "vlc",
        remoteSnaps: false,
        stream1: {
        url: "rtsp://xxxxx:xxxxx@192.168.1.33:554/live",
        frameRate: "15",
        width: 1240,
        height: 700,
                                    			module: "MMM-SimpleLogo",
                                    			position: "middle_center", // This can be any of the regions.
                                    				maxHeight: "490px",
                                    				maxWidth: "1240px",
                                    				refreshInterval: 10000,
                                    				text: ""
                                    			module: "MMM-Snow",
                                    			position: "fullscreen_above",
                                    				flakeCount: 200,
                                    				theme: "winter" //"water" //"winter" //"love"
                                    			module: "MMM-SugarValue",
                                    				username: "",
                                    				password: "",
                                    				units: "mg",
                                    		                height: "505px",
                                                    		width: "1320px"
                                    			module: "on-this-day",
                                    				updateInterval: 10 * 1000 * 60
                                    			module: "random_quotes",
                                      Biebermann
                                      Hello, is the module still maintained or not?
                                        codac
                                        I keep getting this error:
                                        0|mm       | [15.04.2021 15:10.29.116] [ERROR] TypeError: Cannot set property 'omx_stream1' of undefined
                                        0|mm       |     at Timeout.worker [as _onTimeout] (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:367:87)
                                        0|mm       |     at listOnTimeout (internal/timers.js:549:17)
                                        0|mm       |     at processTimers (internal/timers.js:492:7)
                                          mnyqvist
                                          Hi
                                          I just get a white border when my MM starts. I´m using VLC and in the player I can see the stream. Here are the error codes.
                                          [17.06.2021 08:31.58.706] [LOG] Starting stream stream1 using VLC with args --width 352 --height 242 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream1 http://admin:password@192.168.1.79/video.cgi…
                                          [17.06.2021 08:31.58.728] [ERROR] Failed to start subprocess: [object Object].
                                          [17.06.2021 08:31.58.751] [LOG] DP2: Config File Saved!
                                          [17.06.2021 08:31.58.752] [INFO] DP2: Running window resizers…
                                          [17.06.2021 08:31.58.768] [ERROR] DP2: Failed to start.
                                          [17.06.2021 08:32.05.769] [INFO] DP2: Running window resizers…
                                          [17.06.2021 08:32.05.779] [ERROR] DP2: Failed to start.
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! magicmirror@2.15.0 start: electron js/electron.js
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the magicmirror@2.15.0 start script.
                                          • 27
                                          • 28
                                          • 29
                                          • 30
                                          • 31
                                          • 30 / 31
