    602 Posts 67 Posters 2.3m Views 68 Watching
    • Cr4z33C
      Cr4z33 @BKeyport
      @BKeyport said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      @Cr4z33 Good answer. 🤣🤣
      Then, again, I’m not sure how MMM-FreeboxTV is supposed to help with RTSP streaming - wanna comment, @Bugsounet ?
      It is VERY similar to MMM-RTSPStream therefore you add the IP and options in a similar way. :)
      I’ve got some hacked Xiaomi IP cams around the house and so far so good with MMM-FreeboxTV.
      • G
        goprojojo @Cr4z33
        @Cr4z33 That sounds great. Could you share a screenshot how these camera’s looks like on the monitor/mirror?
        • Cr4z33C
          Cr4z33 @goprojojo
          @goprojojo I am away from home, but it is nothing different from how it looks in MMM-RTSPStream. ;)
          • H
            Hram2008 @evroom
            @evroom
            Please see below.
            Any thoughts would be appreciated.
            evroomE BKeyportB 2 Replies Last reply Reply Quote 0
            • evroomE
              evroom @Hram2008
              @Hram2008 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              I am not able to respond to your settings right now, please remind me when I do not answer in a few days.
              MagicMirror version: 2.37.0
              • BKeyportB
                BKeyport Module Developer @Hram2008
                @Hram2008 Honestly, if it’s gonna work, you’ve got a good config. I don’t think “port” is valid (you’d put it on the URI)
                Other than that…
                Did you check the URI through https://www.ispyconnect.com/sources.aspx ?
                iSpy is a great resource to get accurate URIs.
                  I’ve got a good one, just playing with RTPStream module… my MM is on a second monitor, and the box is shown on the MM screen, but the ffmpeg video is displayed in the same position on the 1st screen… oops…
                  • BKeyportB
                    @sdetweil whoops!
                      raf
                      on my other two rpi I use the rpisurv program which has been doing great for a number of years
                      you can find it in ipcamtalk forum
                      • H
                        Hram2008 @BKeyport
                        @BKeyport
                        I used Ispy to generate the URL… when tested in the VLC player it works. Just wont show on the MM screen. I only get Loading RTSP Stream displayed or a black box.
                        • evroomE
                          evroom
                          Please see below.
                          I would first disable the module (disabled: true,) and restart MM.
                          Check if there are no omx_streams running (pm2 status).
                          Stop them when present (pm2 stop omx_stream1 / pm2 delete omx_stream1).
                          Then verify if omxplayer works standalone (use your own user & password & IP address).
                          If it does not work standalone, then there is no need to continue trying the module.
                          $ omxplayer --avdict rtsp_transport:tcp --win 85,65,725,425 --live --video_queue 4 --fps 30 --no-osd rtsp://user:password@192.168.178.55/axis-media/media.amp?resolution=640x360
                          If that works you can try this verified config (use your own user & password & IP address):
                          $ vi ~/MagicMirror/config/config.js
                              module: "MMM-RTSPStream",
                              //disabled: false,
                              disabled: true,
                              position: "middle_center",
                              header: "Axis Security Monitor",
                                autoStart: true,
                                rotateStreams: false,
                                moduleWidth: 640,
                                moduleHeight: 360,
                                localPlayer: 'omxplayer',
                                remotePlayer: 'none',
                                showSnapWhenPaused: false,
                                remoteSnaps: false,
                                stream1: {
                                  url: 'rtsp://user:password@192.168.178.55/axis-media/media.amp?resolution=640x360',
                                  frameRate: "30",
                                  protocol: "tcp",
                                  width: 640,
                                  height: 360,
                                  omxRestart: 1,
                                  hwAccel: true,
                          This works for Axis P1448-LE, M2026-LE Mk II and M1125-E.
                          Good luck.
                          H W 2 Replies Last reply Reply Quote 0
                          • H
                            Hram2008 @evroom
                            @evroom
                            Thank you for the details, I am happy to report that the shared config also works for the Axis
                            Q3615. Thank you assist.
                            • W
                              warrendt @evroom
                              @evroom thanks for this, I am trying to get my vivotek cameras working,
                              omxplayer --avdict rtsp_transport:tcp --win 85,65,725,425 --live --video_queue 4 --fps 30 --no-osd rtsp://user:password@192.168.1.###/live1s3.sdp
                              This works great, and I see the feed perfect in the OMX player,
                              However, my config in the plugin doesn’t. I just get a black box. Any ideas would be appreciated.
                              			//disabled: false,
                              			//disabled: true,
                              			header: "Cameras",
                              				autoStart: true,
                              				moduleWidth: 640,
                              				moduleHeight: 480,
                              				remoteSnaps: false,
                              				stream1: {
                              					url: 'rtsp://user:password@192.168.1.###/live1s3.sdp',
                              					frameRate: "30",
                              					protocol: "tcp",
                              					width: 640,
                              					height: 480,
                              					omxRestart: 1,
                              					hwAccel: true,
                              • evroomE
                                evroom @warrendt
                                @warrendt
                                Can you check following ?
                                Process omx_stream1 present:
                                $ pm2 status
                                $ ps -eaf | grep -v grep | grep omxplayer
                                Entries in pm2 log:
                                $ pm2 logs --lines 100
                                Might need to flush the logs and restart MM in order to show new RTSPStream log entries:
                                $ pm2 flush
                                $ pm2 restart MagicMirror
                                omxplayer version:
                                $ omxplayer -version
                                MMM-RTSPStream git status
                                $ cd ~/MagicMirror/modules/MMM-RTSPStream
                                $ git status
                                I am on the develop branch, you might need o switch to that too.
                                $ git checkout develop
                                $ npm install
                                  rhopkins7428 @Hram2008
                                  @Hram2008
                                  TLDR, I switched from VLC to omxplayer and my previously working config started working again
                                  I’m using hikvision cameras,
                                  I was having a similar issue, migrating from an working configuration on an old PI3 to a new fresh image on PI4,
                                  fresh Magic Mirror/ and MMM-RTSPStream install, copied original config over but both VLC windows black.
                                  You can click pause on each window, (then shows correct window name) but when you resume it’s just black windows. I confirmed running VLC standalone, using the open network URL, pasted same URL in config and it worked fine. (Like I mentioned running on an older PI no problems)
                                  Anyway, I changed player to omxplayer in the config and it worked immediately, not sure why VLC in MM not working…
                                  my config:
                                  module: “MMM-RTSPStream”,
                                  position: “top_left”,
                                  autoStart: true,
                                  rotateStreamTimeout: 10,
                                  moduleWidth: 354,
                                  moduleHeight: 240,
                                  localPlayer: ‘omxplayer’,
                                  remotePlayer: ‘none’,
                                  showSnapWhenPaused: true,
                                  remoteSnaps: false,
                                  shutdownDelay: 12,
                                  stream1: {
                                  url: ‘rtsp://admin:secret@10.99.98.101:554//Streaming/Channels/2’,
                                  frameRate: ‘undefined’,
                                  snapshotType: ‘url’,
                                  snapshotRefresh: 10,
                                  width: undefined,
                                  height: undefined,
                                  stream2: {
                                  url: ‘rtsp://admin:secret@10.99.98.37:554//Streaming/Channels/2’,
                                  width: undefined,
                                  height: undefined,
                                  • BKeyportB
                                    Sometimes with this app you gotta jiggle the handle.
                                      bhepler Module Developer
                                      This may be a bit weird, but I’m trying to install this on a non-RaspberryPi piece of hardware running Ubuntu 20. Is there a manual installation process that doesn’t require OMXPlayer?I realize that it will limit my options to VLC, but I’m willing to try. I’m getting caught up on it trying to install a player that isn’t available on Ubuntu.
                                      I tried installing OMXPlayer through the Snap store, but because the hardware is AMD64, it’s not available.
                                      • E
                                        Egnos
                                        Hi everyone,
                                        I believe that the MMM - RTSPStream module is incompatible with the MMM-Pages multi page module!
                                        By removing MMM-Pages, the RTSPStream module works again.
                                        The link for the video stream works correctly both with VLC and with the “omxplayer” command.
                                        The version of MM I am using is the latest available 2.14.0.
                                        The error I find in the console is the following:
                                        MMM-RTSPStream.js:164 MMM-RTSPStream has resumed... rotateStreams: true, autoStart: true
                                        MMM-RTSPStream.js:368 Uncaught TypeError: Cannot read property 'getBoundingClientRect' of null
                                            at Class.playStream (MMM-RTSPStream.js:368)
                                            at Class.rotateStream (MMM-RTSPStream.js:123)
                                            at Class.setupStreamRotation (MMM-RTSPStream.js:94)
                                            at Class.resumed (MMM-RTSPStream.js:168)
                                            at newCallback (MMM-RTSPStream.js:186)
                                            at main.js:324
                                        Here is my configuration:
                                        		   position: "bottom_right",
                                        		   header: "Test",
                                        			    //initialSetup: true,
                                        				autoStart: true,
                                        				moduleWidth: 354,
                                        				moduleHeight: 240,
                                        				remoteSnaps: false,
                                        				stream1: {
                                        					url: 'rtsp://xxxxxxxxxxx:xxxxxxxxx@xxx.xxx.x.xxx:554/stream1',
                                        					frameRate: 'undefined',
                                        					//width: undefined,
                                        					//height: undefined,
                                        In the “bottom_right” region what I see:
                                        alt text
                                        Have any of you noticed this incompatibility?
                                        Any advice / help is welcome.
                                        Thanks.
                                        BKeyportB JerryPJ 2 Replies Last reply Reply Quote 0
                                        • BKeyportB
                                          BKeyport Module Developer @Egnos
                                          @Egnos Don’t have a clue myself, and this module is no longer supported. :(
                                          • E
                                            Egnos @BKeyport
                                            @BKeyport thanks.
                                            Do you know any other module that can show the stream of surveillance cameras?
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 29 / 31
