    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.0m Views 68 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      OK, that’s weird (but expected)
      I never could get VLC to work. I can’t recall if OMX was working or not in the last public release, the developer branch was opposite.
      I use OMX independently now, using @evroom 's method, however, that requires the may 2020 update to fix a number of bugs in my case.
      • Cr4z33C Offline
        Cr4z33 @BKeyport
        @BKeyport could you please share the link here?
        I would like to give it a try because right now OMXplayer embedded streams are playing in a wrong resize (almost full screen lol). :D
        • BKeyportB Offline
          BKeyport Module Developer @Cr4z33
          @Cr4z33 It’s sprinkled throughout this post. This will take you to where I talk about it, Evroom’s convo is earlier, but there’s a link in my post about it. Feel free to use this post for help on this.
          https://forum.magicmirror.builders/post/69779
          • twosquirrelsT Offline
            twosquirrels @dwburger
            This post is deleted!
              • Cr4z33C Offline
                Cr4z33
                I am trying to have this module running succesfully in Ubuntu Desktop, but it doesn’t work right now.
                I ran the bash setup command and choosed the master build (dev build gave the same errors).
                [2020-07-14 16:46:29.279] [LOG]    Starting MagicMirror: v2.12.0
                [2020-07-14 16:46:29.282] [LOG]    Loading config ...
                [2020-07-14 16:46:29.284] [LOG]    Loading module helpers ...
                [2020-07-14 16:46:29.286] [LOG]    Initializing new module helper ...
                [2020-07-14 16:46:29.286] [LOG]    Module helper loaded: MMM-WatchDog
                [2020-07-14 16:46:29.335] [LOG]    Initializing new module helper ...
                [2020-07-14 16:46:29.335] [LOG]    Module helper loaded: MMM-Remote-Control
                [2020-07-14 16:46:29.339] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-rtsp-stream-es6'
                Require stack:
                - /home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js
                - /home/cr4z33/MagicMirror/js/app.js
                - /home/cr4z33/MagicMirror/js/electron.js
                - /home/cr4z33/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                [2020-07-14 16:46:29.340] [LOG]    Loading module helpers ...
                [2020-07-14 16:46:29.340] [LOG]    Initializing new module helper ...
                [2020-07-14 16:46:29.340] [LOG]    Module helper loaded: MMM-WatchDog
                [2020-07-14 16:46:29.341] [LOG]    Module helper loaded: MMM-Remote-Control
                [2020-07-14 16:46:29.342] [ERROR]  App threw an error during load
                [2020-07-14 16:46:29.342] [ERROR]  Error: Cannot find module 'node-rtsp-stream-es6'
                Require stack:
                    at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                    at Function.Module._resolveFilename (/home/cr4z33/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                    at Function.Module._resolveFilename (/home/cr4z33/MagicMirror/node_modules/module-alias/index.js:49:29)
                    at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                    at Module.require (internal/modules/cjs/loader.js:685:19)
                    at require (internal/modules/cjs/helpers.js:16:16)
                    at Object.<anonymous> (/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js:10:14)
                    at Module._compile (internal/modules/cjs/loader.js:786:30)
                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                    at Module.load (internal/modules/cjs/loader.js:645:32)
                [2020-07-14 16:46:29.343] [ERROR]  Whoops! There was an uncaught exception...
                [2020-07-14 16:46:29.343] [ERROR]  Error: Cannot find module 'node-rtsp-stream-es6'
                Require stack:
                    at Module.load (internal/modules/cjs/loader.js:645:32) {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: [
                    '/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js',
                    '/home/cr4z33/MagicMirror/js/app.js',
                    '/home/cr4z33/MagicMirror/js/electron.js',
                    '/home/cr4z33/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                    undefined
                [2020-07-14 16:46:29.345] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2020-07-14 16:46:29.346] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                [2020-07-14 16:46:29.414] [LOG]    Launching application.
                  sdetweil @Cr4z33
                  @Cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                  Error: Cannot find module ‘node-rtsp-stream-es6’
                  did u do npm install in the “/home/cr4z33/MagicMirror/modules/MMM-RTSPStream” folder?
                  • Cr4z33C Offline
                    Cr4z33 @sdetweil
                    @sdetweil yep.
                      sdetweil @Cr4z33
                      @Cr4z33 can u try this
                      cd ~/MagicMirror/modules/shbatm/MMM-RTSPStream
                      ls node_modules/node-rtsp-stream-es6
                      rm -rf node_modules/node-rtsp-stream-es6
                      rm package-lock.json
                      npm install
                      then try restarting MM
                      • Cr4z33C Offline
                        Cr4z33 @sdetweil
                        @sdetweil thanks for helping! :)
                        Last command showed an error that looks like (translated from Italian):
                        cr4z33@Cr4z33-UbuntuDesktop-VM-Synology:~/MagicMirror/modules/MMM-RTSPStream$
                        ls: Cannot access 'node_modules/node-rtsp-stream-es6': File or directory does not exist
                        In fact looking in the node_modules folder there’s no node-rtsp-stream-es6 directory. :thinking_face:
                        I then thought it was a good idea running npm install node-rtsp-stream-es6 in the MMM-RTSPStream directory.
                        The folder was created at last, but then I kept getting errors at MM launch:
                        cr4z33@Cr4z33-UbuntuDesktop-VM-Synology:~/MagicMirror$ npm start
                        > magicmirror@2.12.0 start /home/cr4z33/MagicMirror
                        [2020-07-15 08:58:08.182] [LOG]    Starting MagicMirror: v2.12.0
                        [2020-07-15 08:58:08.184] [LOG]    Loading config ...
                        [2020-07-15 08:58:08.186] [LOG]    Loading module helpers ...
                        [2020-07-15 08:58:08.188] [LOG]    Initializing new module helper ...
                        [2020-07-15 08:58:08.188] [LOG]    Module helper loaded: MMM-WatchDog
                        [2020-07-15 08:58:08.231] [LOG]    Initializing new module helper ...
                        [2020-07-15 08:58:08.232] [LOG]    Module helper loaded: MMM-Remote-Control
                        [2020-07-15 08:58:08.354] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'datauri'
                        Require stack:
                        [2020-07-15 08:58:08.354] [LOG]    Loading module helpers ...
                        [2020-07-15 08:58:08.355] [LOG]    Initializing new module helper ...
                        [2020-07-15 08:58:08.355] [LOG]    Module helper loaded: MMM-WatchDog
                        [2020-07-15 08:58:08.355] [LOG]    Module helper loaded: MMM-Remote-Control
                        [2020-07-15 08:58:08.356] [ERROR]  App threw an error during load
                        [2020-07-15 08:58:08.356] [ERROR]  Error: Cannot find module 'datauri'
                        Require stack:
                            at Object.<anonymous> (/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js:14:17)
                        [2020-07-15 08:58:08.357] [ERROR]  Whoops! There was an uncaught exception...
                        [2020-07-15 08:58:08.357] [ERROR]  Error: Cannot find module 'datauri'
                        Require stack:
                          requireStack: [
                            undefined
                        [2020-07-15 08:58:08.359] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        [2020-07-15 08:58:08.359] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        [2020-07-15 08:58:08.412] [LOG]    Launching application.
                        • 52
                        • 53
                        • 54
                        • 55
                        • 56
                        • 60
                        • 61
                        • 54 / 61
