    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.0m Views 68 Watching
    • bheplerB Offline
      bhepler Module Developer
      This may be a bit weird, but I’m trying to install this on a non-RaspberryPi piece of hardware running Ubuntu 20. Is there a manual installation process that doesn’t require OMXPlayer?I realize that it will limit my options to VLC, but I’m willing to try. I’m getting caught up on it trying to install a player that isn’t available on Ubuntu.
      I tried installing OMXPlayer through the Snap store, but because the hardware is AMD64, it’s not available.
      • E Offline
        Egnos
        Hi everyone,
        I believe that the MMM - RTSPStream module is incompatible with the MMM-Pages multi page module!
        By removing MMM-Pages, the RTSPStream module works again.
        The link for the video stream works correctly both with VLC and with the “omxplayer” command.
        The version of MM I am using is the latest available 2.14.0.
        The error I find in the console is the following:
        MMM-RTSPStream.js:164 MMM-RTSPStream has resumed... rotateStreams: true, autoStart: true
        MMM-RTSPStream.js:368 Uncaught TypeError: Cannot read property 'getBoundingClientRect' of null
            at Class.playStream (MMM-RTSPStream.js:368)
            at Class.rotateStream (MMM-RTSPStream.js:123)
            at Class.setupStreamRotation (MMM-RTSPStream.js:94)
            at Class.resumed (MMM-RTSPStream.js:168)
            at newCallback (MMM-RTSPStream.js:186)
            at main.js:324
        Here is my configuration:
        		   module: "MMM-RTSPStream",
        		   position: "bottom_right",
        		   header: "Test",
        			    //initialSetup: true,
        				autoStart: true,
        				rotateStreamTimeout: 10,
        				moduleWidth: 354,
        				moduleHeight: 240,
        				localPlayer: 'omxplayer',
        				remotePlayer: 'none',
        				showSnapWhenPaused: false,
        				remoteSnaps: false,
        				stream1: {
        					url: 'rtsp://xxxxxxxxxxx:xxxxxxxxx@xxx.xxx.x.xxx:554/stream1',
        					frameRate: 'undefined',
        					//width: undefined,
        					//height: undefined,
        In the “bottom_right” region what I see:
        alt text
        Have any of you noticed this incompatibility?
        Any advice / help is welcome.
        Thanks.
        BKeyportB JerryPJ 2 Replies Last reply Reply Quote 0
        • BKeyportB Offline
          BKeyport Module Developer @Egnos
          @Egnos Don’t have a clue myself, and this module is no longer supported. :(
          • E Offline
            Egnos @BKeyport
            @BKeyport thanks.
            Do you know any other module that can show the stream of surveillance cameras?
            • Cr4z33C Offline
              Cr4z33 @Egnos
              @Egnos as I wrote already some pages ago there’s MMM-FreeboxTV.
              Similar this module, but most of all it works.
              • E Offline
                Egnos @Cr4z33
                @Cr4z33 many thanks.
                If I understand correctly the stream is started only if I ask the Google assistant to launch it, correct?
                • E Offline
                  Egnos
                  …maybe I can use this “onStart” parameter to launch the stream that interests me at startup without asking the assistant.
                  With this parameter it would also be possible to launch multiple streams at startup?
                  Many thanks.
                  • Cr4z33C Offline
                    Cr4z33 @Egnos
                    @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                    It’s up to you.
                    Either have it streaming 24/7 or upon command. :)
                      drx1984 @Cr4z33
                      @Cr4z33 how does a config look like with MMM-FreeboxTV?
                      can I insert a link under stream: rtsp-stream?
                      • Cr4z33C Offline
                        Cr4z33 @drx1984
                        @drx1984 find out by yourself and… happy studying. ;)
                        https://github.com/bugsounet/MMM-FreeboxTV/
                        • 57
                        • 58
                        • 59
                        • 60
                        • 61
                        • 59 / 61
