    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.0m Views 68 Watching
    • C Offline
      codac
      I keep getting this error:
      0|mm       | [15.04.2021 15:10.29.116] [ERROR] TypeError: Cannot set property 'omx_stream1' of undefined
      0|mm       |     at Timeout.worker [as _onTimeout] (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:367:87)
      0|mm       |     at listOnTimeout (internal/timers.js:549:17)
      0|mm       |     at processTimers (internal/timers.js:492:7)
        mnyqvist
        Hi
        I just get a white border when my MM starts. I´m using VLC and in the player I can see the stream. Here are the error codes.
        [17.06.2021 08:31.58.706] [LOG] Starting stream stream1 using VLC with args --width 352 --height 242 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream1 http://admin:password@192.168.1.79/video.cgi…
        [17.06.2021 08:31.58.728] [ERROR] Failed to start subprocess: [object Object].
        [17.06.2021 08:31.58.751] [LOG] DP2: Config File Saved!
        [17.06.2021 08:31.58.752] [INFO] DP2: Running window resizers…
        [17.06.2021 08:31.58.768] [ERROR] DP2: Failed to start.
        [17.06.2021 08:32.05.769] [INFO] DP2: Running window resizers…
        [17.06.2021 08:32.05.779] [ERROR] DP2: Failed to start.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! magicmirror@2.15.0 start: electron js/electron.js
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.15.0 start script.
        • 57
        • 58
        • 59
        • 60
        • 61
        • 61 / 61
